I want to get inverting and non inverting square wave at the same time. I am using EL2444 quad op amp, gain not required. My input is approx. 550 kHz, 50% duty cycle square wave. I assume that I will get the same output from non inverting op amp and inverted output from inverting op amp. But actually I am getting inverted output ok but non inverting output is differ, its duty factor was changed.
What should I do? Is there any problem in my circuit OR should I change op amp?
Our EL2444 has been obsolete since 2007 and we no support this part. This was a part originally designed by engineers at Elantec prior to the Intersil (now Renesas) acquisition. All of the original designers and apps engineers are no longer with the company. I apologize we cannot support your questions.
Best regards, Cindy, Renesas Online Apps Engineer
