Hi Renesus Technical Support team
We are manufacture of Connector & Cable.
We are proposing Camera Connector & Cable for our customers who are using Renesus AHL chip for their Automotive surround view system.
We would like to know required configuration of cable between Camera and Camera ECU. Please let us know following points.
Q1 What will be the typical cable configuration for Renesus AHL chip ?
Q2 Which of following 3 options will be able to consider using for AHL Camera ?
Thank you
Hi ,
AHL can be used with UTP, STP, and Coax cable. I will check on more details get back to you
Thanks AB
AHL is designed to work with cheap 2-wire UTP, STP cables which are used in SD CVBS signal transferring, see below.
It’s not recommended to use 4-wire cable which 2 of them may be for power.
AB
