We are using ISL79987 for our custom board with IMX8MP, Renesas provided some files regarding Linux support for this chip with imx6 from NXP but the provided files are outdated and they're for kernel version 3.10. But our configuration is with the current BSP, kernel version 6.1 so are there any updated documents or source codes for this IC available? If not, is drivers/media/i2c/isl7998x.c driver sufficient existing in the source tree?
Thank you in advance!
Best Regards.
