Is there a design recommendation for input and output conditioning resistor values? Basically I am using an op amp to reduce the level coming in to the AUX inputs and then increase the value coming out of the headphone outputs. I need stereo line in and out. I am unsure if using value ranges like 2k and 10k for a 5 X gain will have noise and stability issues.
Hi Loki,Thank you for posting your question online.We are aware that you have raised a private ticket as well.Let us continue the conversation on the private ticket.Best Regards,OV_Renesas
I will check with concern team and get back to you.
AB
