I'll use the DA7400 with next apps, I looking for an EVK of that. But, I could not to find detail information of EVK. Also, that needs a SDK-file. Can someone let me know the download link for the SDK-file?
Regards,ACGUY
DA7400-DEVKT is EVK for DA7400 , You can buy it through authorized/ online distributor
DA7400-DEVKT - DA7400 Development Kit | Renesas.
With EVK you will get all necessary files
AB
Hi AB_REL,
Thank you for reply.
Does this mean I can't view detailed information unless I purchase the EVK? What a so unkind... orz
OK, I understood.
Thank!
ACGUY
Hi ,
Since you're reviewing both the file and EVK, so I suggested as above
To get the link you will need to submit a Technical Support ticket by going to our support portal from the following link: https://en-support.renesas.com
