SLG46826V PWM Frequency Conversion
For one of our customers, Im am trying to implement a PWM Frequency Converter from 400Hz fixed frequency to 2KHz fixed frequency using SLG46826V. However, I couldn't make it.
I have checked the PWM Frequency Conversion example, there is a PWM Block which SLG46826V doesn't have. I have checked other PWM examples. The concept is okay but, I couldn't get the DUTY adjusted.
Ideally, I want to read the duty from the 400Hz PWM signal and write it to 2KHz PWM signal.
How can I achieve this application using SLG46826V?
I have a board with SLG46826V, and we have some in stock. Also the quantity is low, therefore the customer will program them during production.
Caner
Alp Electronix
