Programming NVM Memory via I2C on SLG46855V
I am working with the SLG46855V device and have a question regarding its configuration. Is it possible to program the NVM (Non-Volatile Memory) through the I2C bus in such a way that, upon power-up, the device configures itself with a different configuration than the one previously programmed?
My goal is that after this initial power-up, I can reconfigure it for a different operating mode, also using I2C, to change the configuration as needed.
Has anyone had experience with this type of configuration on the SLG46855V? Is it possible to achieve this in this way?
Thank you in advance for your help.
