Dear Expert,
I am using the part "HN58V256AT12E" as a replacement for the ATMEL part - AT28HC256-12TU. I know that it's an obsolete part but I found a huge quantity at ROCHESTER distributor.
After reviewing the datasheets for this component and comparing it to the ATMEL component, I came to the conclusion that it is a compatible component with the same programming process, but unfortunately I am unable to program it. Is there a special programming process for this component that is not the same as the ATMEL component?
By the way, I was able to program a single address using a manual programming process.
Hi There,Thank you for posting your question online.
Menachem said:I am using the part "HN58V256AT12E" as a replacement for the ATMEL part - AT28HC256-12TU. I know that it's an obsolete part but I found a huge quantity at ROCHESTER distributor.
This specific part number does not belong in our portfolio.If you search online you will see that this specific part number belongs to another company.I am afraid we cannot support you further because we can only provide support on Renesas Electronics devices.Best Regards,OV_Renesas
