Hello! I have some questions about ZSC31050. Firstly, I hope you can provide me with the DLL files of ZSC31050 to suppor me design. Secondly, I had brought the ZSC31050 SSC Evaluation Kit form taobao. But when I choose IIC--COMM--BOARD, there are some mistakes happen: 1. It seems, activating of command mode (CM) failedor transmission speed is to fast! Power off the $sC and execute start procedure again orreduce tramsmission speed in -dialog! Communication error detected, error code = 032. 2. I check the voltage of the Comm board, only 5P and 12P has correctly voltage, other pin(KS5V、KS12V、VPP、VDD-LS、KS-LS) is zero,the voltage of SSC Board ZSC31050's VDDA pin is zero, could you tell me what should I do? 3.In the section 5.3 of ZSC31050 Functional Description, the default value of Configuration Word CFGSIF SIFOUTP=1; SIFOUTT1=1, how to relaize the readout of them? (if we want to the value of T1,Ijust set SIFOUTT1=1, SIFOUTP=0) 4.In the section 2.3.3 of ZSC3105 Datasheet , I want to know the meaning of Measurement count n and the different about it.
Please let me inform you that regarding custom pcb designs we provide in our website Altium libraries for our sensor signal conditioners:
https://www.renesas.com/us/en/document/gde/renesas-cad-altium-libraries-aid-products-rev-20210820?r=179826
Here you can find lot's of documentation regarding the SSC you requested:
https://www.renesas.com/us/en/products/sensor-products/sensor-signal-conditioners-ssc-afe/zsc31015-resistive-sensor-signal-conditioner-analog-output-and-diagnostic-features#documents
And also please check the webpage of ZSC31015 EVK:
https://www.renesas.com/us/en/products/sensor-products/sensor-signal-conditioners-ssc-afe/zsc31015kit-evaluation-kit-zsc31015#design_development
Please refer specifically to ZSC31015 EVK user's manual:
https://www.renesas.com/us/en/document/mat/zsc31010zsc31015zssc3015-zacwire-ssc-modular-evaluation-kit-description?r=182156
In the manual you can also find a more detailed schematic of the EVK.
If you have further questions, please let us know.
IK_Renesas
