Hi, Sir:
How could I set XF device registers by I2C? it not describle in datasheet.
Best regards
Ok, you are correct on the I2C programming of the device. Again you can have the device pre-configured to a start-up setting by our factory.
That is done by using our Configuration / Customization link on our web. This will generate a specific part number for your order as well as an addendum Data Sheet for your specific device.
Programming the device configuration is done using Timing Commander Software and the Personality file.
How to program the device if no setting up a custom configuration in the guide below. But on a power cycle the device will go back to the default configuration.
ProXO Register Descriptions and Programming Guide
