Hi Developers and Renesas Support Team
According to Kingfisher Board Layout (R-Car/Boards/Kingfisher - eLinux.org)Power Measurement pins are located on J10, as shown in the figure belowIs it mean measuring Board Power Consumption?
I want to confirm how to monitor J10 to read power data,Will I connect only the Multimeter between pins and read data? Which type of value will be monitored? (Voltage or Current)Also, what is the internal (shunt) resistor value between pins to calculate power value?
If there is a manual to answer these questions, it will be helpful.Thank you in advance for your support.
Amir
M.Amir said:If there is a manual to answer these questions, it will be helpful.
Hi Amir, did you find the hardware documentation linked from the elinux.org page http://www.shimafuji.co.jp/en/products/1…
Thank you, Mr.SteveAccording to the following manual: sbev-rcar-kf-m06 (shimafuji.co.jp)
I think the internal (shunt) resistor value between pins is R651 = 0.651Ω
Hi Amir, did you find the hardware documentation linked from the elinux.org page http://www.shimafuji.co.jp/en/products/1416That page contains the schematics and h/w manual.RegardsSteve
Hi, I am not a h/w engineer and do not have an answer to your specific question about where to measure but I am glad the link to the manuals was helpful.
