Boot Failure After Flashing Android12 Image: tee_supplicant Initialization Issue
Dear all,
After flasing IPL with R-Car M3, I follow the spec to flash image.
I am facing some issues as follow
* cpuset cgroup controller is not mounted!
* cannot setexeccon('u:r:tee_recovery:s0') for tee_supplicant: Invalid argument
* Service 'tee_supplicant' exits with status 6
These reason preventing the device from booting successfully.
- boot message screenshot
- Fastboot log in linux:
ANDROID_PRODUCT_OUT is set. Using images from output dir: /home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/target/product/salvator
Fastboot - device detected: 7062
Product...: salvator
Platform..: r8a7796-3.0
Slot......: a
fastboot..: /home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/host/linux-x86/bin/fastboot
SUCCESS. File [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/target/product/salvator/dtbo.img] found
SUCCESS. File [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/target/product/salvator/boot.img] found
SUCCESS. File [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/target/product/salvator/vendor_boot.img] found
SUCCESS. File [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/target/product/salvator/vbmeta.img] found
SUCCESS. File [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/target/product/salvator/super.img] found
Setting current slot to 'a'                        OKAY [  0.005s]
Finished. Total time: 0.005s
SUCCESS. Last command [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/host/linux-x86/bin/fastboot --set-active=a] finished with result [0]
--boot_first is not specified - skipping boot and adb flashing..
SUCCESS. File [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/target/product/salvator/bootparam_sa0.srec] found
SUCCESS. File [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/target/product/salvator/bl2.srec] found
SUCCESS. File [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/target/product/salvator/cert_header_sa6.srec] found
SUCCESS. File [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/target/product/salvator/bl31.srec] found
SUCCESS. File [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/target/product/salvator/tee.srec] found
SUCCESS. File [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/target/product/salvator/u-boot-elf.srec] found
Flash HF bootloaders
Sending 'param.srec' (10 KB)                       OKAY [  0.009s]
Writing 'param.srec'                               OKAY [  1.368s]
Finished. Total time: 1.381s
SUCCESS. Last command [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/host/linux-x86/bin/fastboot flash param.srec /home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/target/product/salvator/bootparam_sa0.srec] finished with result [0]Sending 'bl2.srec' (488 KB)                        OKAY [  0.056s]
Writing 'bl2.srec'                                 OKAY [  1.432s]
Finished. Total time: 1.493s
SUCCESS. Last command [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/host/linux-x86/bin/fastboot flash bl2.srec /home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/target/product/salvator/bl2.srec] finished with result [0]
Sending 'cert.srec' (58 KB)                        OKAY [  0.015s]
Writing 'cert.srec'                                OKAY [  1.299s]
Finished. Total time: 1.318s
SUCCESS. Last command [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/host/linux-x86/bin/fastboot flash cert.srec /home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/target/product/salvator/cert_header_sa6.srec] finished with result [0]
Sending 'bl31.srec' (141 KB)                       OKAY [  0.023s]
Writing 'bl31.srec'                                OKAY [  1.332s]
Finished. Total time: 1.359s
SUCCESS. Last command [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/host/linux-x86/bin/fastboot flash bl31.srec /home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/target/product/salvator/bl31.srec] finished with result [0]
Sending 'optee.srec' (1119 KB)                     OKAY [  0.112s]
Writing 'optee.srec'                               OKAY [  2.774s]
Finished. Total time: 2.890s
SUCCESS. Last command [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/host/linux-x86/bin/fastboot flash optee.srec /home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/target/product/salvator/tee.srec] finished with result [0]
Sending 'uboot.srec' (3318 KB)                     OKAY [  0.342s]
Writing 'uboot.srec'                               OKAY [  6.659s]
Finished. Total time: 7.006s
SUCCESS. Last command [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/host/linux-x86/bin/fastboot flash uboot.srec /home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/target/product/salvator/u-boot-elf.srec] finished with result [0]
Flash EMMC bootloader
Sending 'bootloader' (3153 KB)                     OKAY [  0.300s]
Writing 'bootloader'                               OKAY [  0.042s]
Finished. Total time: 0.346s
SUCCESS. Last command [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/host/linux-x86/bin/fastboot flash bootloader /home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/target/product/salvator/bootloader.img] finished with result [0]
Rebooting into bootloader                          OKAY [  0.002s]
Finished. Total time: 0.103s
SUCCESS. Last command [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/host/linux-x86/bin/fastboot reboot-bootloader] finished with result [0]
Waiting for device about 30 sec: .
**************** --noresetenv argument is set
**************** Skipping operation of reset default environment
(bootloader)  eMMC: Man 000015 Snr e9be53e0 BGUF4R 3.9 29824MiB
(bootloader)  Created new GPT partition table:
(bootloader)      /misc (512 KiB, raw)
(bootloader)      /logo (8192 KiB, raw)
(bootloader)      /vbmeta_a (512 KiB, raw)
(bootloader)      /vbmeta_b (512 KiB, raw)
(bootloader)      /dtbo_a (512 KiB, raw)
(bootloader)      /dtbo_b (512 KiB, raw)
(bootloader)      /boot_a (131072 KiB, raw)
(bootloader)      /boot_b (131072 KiB, raw)
(bootloader)      /vendor_boot_a (131072 KiB, raw)
(bootloader)      /vendor_boot_b (131072 KiB, raw)
(bootloader)      /metadata (16384 KiB, ext4)
(bootloader)      /super (3208192 KiB, raw)
(bootloader)      /userdata (26779631 KiB, f2fs)
OKAY [  0.044s]
Finished. Total time: 0.044s
SUCCESS. Last command [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/host/linux-x86/bin/fastboot oem format] finished with result [0]
Rebooting into bootloader                          OKAY [  0.001s]
Finished. Total time: 0.101s
Flash Android partitions
< waiting for any device >
Finished. Total time: 0.006s
Sending 'dtbo_a' (512 KB)                          OKAY [  0.056s]
Writing 'dtbo_a'                                   OKAY [  0.015s]
Finished. Total time: 0.079s
SUCCESS. Last command [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/host/linux-x86/bin/fastboot flash dtbo /home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/target/product/salvator/dtbo.img] finished with result [0]
Invalid sparse file format at header magic
Sending sparse 'boot_a' 1/2 (32764 KB)             OKAY [  3.132s]
Writing 'boot_a'                                   OKAY [  0.811s]
Sending sparse 'boot_a' 2/2 (8372 KB)              OKAY [  0.821s]
Writing 'boot_a'                                   OKAY [  1.486s]
Finished. Total time: 6.339s
SUCCESS. Last command [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/host/linux-x86/bin/fastboot flash boot /home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/target/product/salvator/boot.img] finished with result [0]
Sending sparse 'vendor_boot_a' 1/1 (1172 KB)       OKAY [  0.122s]
Writing 'vendor_boot_a'                            OKAY [  1.822s]
Finished. Total time: 1.988s
SUCCESS. Last command [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/host/linux-x86/bin/fastboot flash vendor_boot /home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/target/product/salvator/vendor_boot.img] finished with result [0]
Sending 'vbmeta_a' (8 KB)                          OKAY [  0.009s]
Writing 'vbmeta_a'                                 OKAY [  0.008s]
Finished. Total time: 0.026s
SUCCESS. Last command [/home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/host/linux-x86/bin/fastboot flash vbmeta /home/tk/code/renesas/android12/RENESAS_RCH3M3_Android_12_ReleaseNote_2023_06E/mydroid/out/target/product/salvator/vbmeta.img] finished with result [0]
Rebooting into fastboot                            OKAY [  0.001s]
- boot log with R-Car M3:
boot_log_teraTerm.txt
I have no idea how to solve the issue.
If anyone has experience with similar issues or suggestions on resolving the tee_supplicant initialization problem during the image flashing process, I would greatly appreciate your insights.
Thank you for your assistance in advance!
Parents
  • Hi Tony:
    From the log, it seems that you didn't perform "fastboot oem format" step.
    Please help to confirm if you performed attached procedure in release note.
  • Hi Hank:
    I previously followed the instructions in the guide and entered commands line by line.
    So, in reality, I did perform the 'fastboot oem format' step.
    Below is the output when I entered this line. Are these the normal outputs for executing this command?
    By the way, I found that it seems like the 'reboot fastboot' command on line 221 of the fastboot.sh script might be causing the "Service  tee_supplicant" error. In theory, entering this command should put the r-car m3 into fastboot mode, but it seems like it's not happening.
  • Hi,
    I have also found the same issue with Android 12 and not able to boot on M3 custom H/W.
    [ 7.562798][ T49] android_work: sent uevent USB_STATE=CONFIGURED
    [ 11.744892][ T1] init: starting service 'tee_supplicant'...
    [ 11.754652][ T305] init: cpuset cgroup controller is not mounted!
    [ 11.761852][ T305] init: cannot setexeccon('u:r:tee_recovery:s0') for tee_supplicant: Invalid argument
    [ 11.775955][ T1] init: Service 'tee_supplicant' (pid 305) exited with status 6
    [ 11.783528][ T1] init: Sending signal 9 to service 'tee_supplicant' (pid 305) process group...
    [ 11.792710][ T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 305 in 0ms
    [ 16.759695][ T1] init: starting service 'tee_supplicant'...
    [ 16.769582][ T306] init: cpuset cgroup controller is not mounted!
    [ 16.776639][ T306] init: cannot setexeccon('u:r:tee_recovery:s0') for tee_supplicant: Invalid argument
    [ 16.790645][ T1] init: Service 'tee_supplicant' (pid 306) exited with status 6
    [ 16.798219][ T1] init: Sending signal 9 to service 'tee_supplicant' (pid 306) process group...
    [ 16.807408][ T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 306 in 0ms
    If anyone have the workaround solution, please share.
    Ravi
  • Hello Tony,
    This question has been opened but there is no reply for a long time.
    I'll close this ticket. If you have any updates or want to ask another question, please post new question.
    If you have any quetion about  Salvator board, please contact Renesas official support(en-support.renesas.com/dashboard)
    Please chek the "GroupPolicy" of this forum before posting question.
Reply Children
No Data
