can module inline in can.h file.
with HSM disabled and with CAN module inline enabled : Can_SetControllerMode(0,CAN_T_START) will executed and exit correctly.
with HSM enabled and with CAN module inline disabled: Can_SetControllerMode(0,CAN_T_START) will executed and exit correctly.
with HSM enabled and with CAN module inline enabled: Can_SetControllerMode(0,CAN_T_START) will not exit.
can anyone tell me what could be the cause of the issue?
Can you provide the assembly code for the two versions with the HSM active
