Hello! Help me please!I want to use ISL81601 or ISL81401 as a bi-directional battery charger-discharger! The most difficult thing for me is to determine the maximum discharge current! I want to select a choke and mosfet transistors to operate on a 50A (12V) load. My battery is 4S7P voltage from 10V to 16.8V. System voltage 12V (system current more than 100A).Tell me ISL81601 or ISL81401 can operate in 50A (12V) discharge mode. Choke coil e.g. 7443556082 (WURTH ELEKTRONIK)
Created ticket Name ISL81601 / ISL81401Number 380515.Help me! I need to understand how to use the ISL81601 to operate with a load current of 50A (12V)
I see you submitted this ticket but you did not use a company email address as instructed. We are unable to request factory apps support from customers using a non-company email address. Please log in using your company’s email address and resubmit your questions.
If you are not registered with your company email address, you will need to first register with it to create an account prior to resubmitting your questions. https://www.renesas.com/register
Make sure when you resubmit your questions you are logged into our website with this company email address and not your personal one.
