I used GHS for compilation and debugging, and the Stack overflow occurred in the program, but I increased the stack size in the LD file, but the stack overflow could not be prevented, so I wonder whether GreenHills can check the stack usage during debugging
Yin
You are trying to build a Synergy application using the GHS ARM tools?
I don't know what Synergy application you mentioned refers to. The main reason for my problem is that there is a large demand for Stack, but when I increase the size of stack, it cannot take effect
You posted this question in the SYNERGY forum
