Bin file too large
         I created a  bin file for a project containing code for ADC by selecting Project properties -> C++ build -> settings -> GNU ARM Cross Create Flash image -> General ->output file format -> Raw binary. The created bin file was of 1 Gb size as shown in the image attached. Is there any way to reduce that size?
  • With a bin, the linker is going to have to put in 0x00 or 0xff to put the sections where you placed them. Look at the .map file to see where they are going.  You may have a large code or ram section you've specified.  Reduce the sizes of each section if you can will also help.
    Did you ask the linker to fill unused flash with a pattern using =fill? That could do it as well.
    Post your .ld also.
  • It could be caused by the ID_CODE section, or maybe you have constant data in the Data Flash section.
  • I  checked section : - j .text and section : -j . data checkbox . after that , the bin file has gone down to 22 KB .But  don't know what it does. can u share any document or details regarding the project settings that are available in e2 studio? Thanks.
  • All you are doing with those options is only copying the .text and .data sections from the elf object into the binary file (https://sourceware.org/binutils/docs/binutils/objcopy.html)
    You need to look at the .map file that is output from the linker to work out the sections that are causing the binary file to be so large.
  • Hi Ramm, I can suggest to use srec_cat.exe (https://sourceforge.net/projects/srecord/files/srecord-win32/1.64/srecord-1.64-win32.zip/download) with a syntax like (example for 4Mbytes binary file fixed dimension):
    srec_cat.exe <srecname>.srec -crop 0x0 0x400000 -fill 0xFF 0x0 0x3FFFFC -c-p-l-e 0x400000 -o <binmane>.bin -binary
    to convert srec into binary file.
    Roberto
  • Just randomly removing sections from the binary file with understanding what is being removed is not a very good idea. Also, objcopy can remove specific section using the -R option without the need for an intermediate tool like srec_cat.
    @Ramm if you post the .map file from your project, I can have a look and see which sections are causing the issue (the .map file is located in the build output directory)
  • Here is the map file . fyi , The program reads adc value from adc channel 0 and 1. has a seperate thread for it. thats all what the prog does.
    Archive member included to satisfy reference by file (symbol) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_create.o) ./src/synergy_gen/main.o (_txe_semaphore_create) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_get.o) ./src/synergy_gen/main.o (_txe_semaphore_get) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_put.o) ./src/synergy_gen/main.o (_txe_semaphore_put) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_thread_create.o) ./src/synergy_gen/new_thread0.o (_txe_thread_create) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_create.o) (_tx_semaphore_created_ptr) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_kernel_enter.o) ./src/synergy_gen/main.o (_tx_initialize_kernel_enter) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_end.o) ./synergy/ssp/src/driver/r_adc/r_adc.o (tx_isr_end) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_start.o) ./synergy/ssp/src/driver/r_adc/r_adc.o (tx_isr_start) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_create.o) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_create.o) (_tx_semaphore_create) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_get.o) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_get.o) (_tx_semaphore_get) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_put.o) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_put.o) (_tx_semaphore_put) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_create.o) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_thread_create.o) (_tx_thread_create) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) (_tx_thread_initialize) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_shell_entry.o) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_create.o) (_tx_thread_shell_entry) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_sleep.o) ./src/new_thread0_entry.o (_tx_thread_sleep) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_preempt_check.o) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_create.o) (_tx_thread_system_preempt_check) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_resume.o) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_put.o) (_tx_thread_system_resume) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_suspend.o) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_get.o) (_tx_thread_system_suspend) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_timeout.o) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_create.o) (_tx_thread_timeout) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) (_tx_timer_initialize) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_activate.o) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_suspend.o) (_tx_timer_system_activate) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_deactivate.o) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_resume.o) (_tx_timer_system_deactivate) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_low_level.o) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_kernel_enter.o) (_tx_initialize_low_level) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_schedule.o) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_kernel_enter.o) (_tx_thread_schedule) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_stack_build.o) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_create.o) (_tx_thread_stack_build) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_interrupt.o) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_schedule.o) (_tx_timer_interrupt) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_cleanup.o) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_get.o) (_tx_semaphore_cleanup) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_time_slice.o) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_interrupt.o) (_tx_thread_time_slice) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_expiration_process.o) F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_interrupt.o) (_tx_timer_expiration_process) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-errno.o) ./synergy/ssp/src/bsp/mcu/all/bsp_sbrk.o (__errno) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-exit.o) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard/rdimon-crt0.o (exit) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-impure.o) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-exit.o) (_global_impure_ptr) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-init.o) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard/rdimon-crt0.o (__libc_init_array) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-memcmp.o) ./synergy/ssp/src/driver/r_fmi/r_fmi.o (memcmp) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-memset.o) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard/rdimon-crt0.o (memset) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-rand.o) ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/system_S7G2.o (srand) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-malloc.o) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-rand.o) (malloc) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-nano-freer.o) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-malloc.o) (_free_r) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-nano-mallocr.o) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-malloc.o) (_malloc_r) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-sbrkr.o) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-nano-mallocr.o) (_sbrk_r) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-mlock.o) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-nano-freer.o) (__malloc_lock) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-reent.o) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-sbrkr.o) (errno) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard/rdimon-crt0.o (initialise_monitor_handles) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-_exit.o) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-exit.o) (_exit) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-_kill.o) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-_exit.o) (_kill) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) (__sinit) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-fwalk.o) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) (_fwalk) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-stdio.o) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) (__sread) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-strlen.o) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) (strlen) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-writer.o) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-stdio.o) (_write_r) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-closer.o) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-stdio.o) (_close_r) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-fflush.o) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) (_fflush_r) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-lseekr.o) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-stdio.o) (_lseek_r) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-readr.o) c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-stdio.o) (_read_r) Allocating common symbols Common symbol size file _tx_thread_priority_list 0x80 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) g_adc0_ctrl 0x38 ./src/synergy_gen/new_thread0.o _tx_timer_current_ptr 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) _tx_timer_list 0x80 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) _tx_thread_mutex_release 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) _tx_thread_priority_maps 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) errno 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-reent.o) _tx_event_flags_created_ptr 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) _tx_mutex_created_count 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) _tx_mutex_created_ptr 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) _tx_queue_created_count 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) _tx_semaphore_created_ptr 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) _tx_byte_pool_created_ptr 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) _tx_thread_created_ptr 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) _tx_timer_expired 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) _tx_initialize_unused_memory 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) _tx_build_options 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) _tx_timer_time_slice 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) _tx_thread_created_count 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) g_ssp_common_initialized 0x1 ./src/synergy_gen/main.o _tx_block_pool_created_count 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) _tx_thread_system_stack_ptr 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) g_ssp_common_initialized_semaphore 0x1c ./src/synergy_gen/main.o _tx_timer_list_end 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) _tx_timer_processing_active 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) _tx_timer_expired_timer_ptr 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) _tx_thread_preempt_disable 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) _tx_timer_list_start 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) _tx_thread_current_ptr 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) _tx_timer_created_ptr 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) err 0x4 ./src/new_thread0_entry.o new_thread0 0xb8 ./src/synergy_gen/new_thread0.o _tx_thread_execute_ptr 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) _tx_timer_created_count 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) _tx_semaphore_created_count 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) _tx_thread_highest_priority 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) g_ssp_common_thread_count 0x4 ./src/synergy_gen/main.o _tx_timer_expired_time_slice 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) _tx_timer_system_clock 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) ADC_Result 0x14 ./src/new_thread0_entry.o _tx_event_flags_created_count 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) _tx_block_pool_created_ptr 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) _tx_queue_created_ptr 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) _tx_byte_pool_created_count 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) Discarded input sections .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crti.o .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crti.o .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crti.o .data 0x00000000 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtbegin.o .text 0x00000000 0xe8 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard/rdimon-crt0.o .data 0x00000000 0x118 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard/rdimon-crt0.o .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard/rdimon-crt0.o .ARM.extab 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard/rdimon-crt0.o .ARM.exidx 0x00000000 0x8 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard/rdimon-crt0.o .ARM.attributes 0x00000000 0x20 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard/rdimon-crt0.o .text 0x00000000 0x0 ./synergy/ssp/src/driver/r_ioport/r_ioport.o .data 0x00000000 0x0 ./synergy/ssp/src/driver/r_ioport/r_ioport.o .bss 0x00000000 0x0 ./synergy/ssp/src/driver/r_ioport/r_ioport.o .text 0x00000000 0x0 ./synergy/ssp/src/driver/r_fmi/r_fmi.o .data 0x00000000 0x0 ./synergy/ssp/src/driver/r_fmi/r_fmi.o .bss 0x00000000 0x0 ./synergy/ssp/src/driver/r_fmi/r_fmi.o .text 0x00000000 0x0 ./synergy/ssp/src/driver/r_elc/r_elc.o .data 0x00000000 0x0 ./synergy/ssp/src/driver/r_elc/r_elc.o .bss 0x00000000 0x0 ./synergy/ssp/src/driver/r_elc/r_elc.o .text 0x00000000 0x0 ./synergy/ssp/src/driver/r_cgc/r_cgc.o .data 0x00000000 0x0 ./synergy/ssp/src/driver/r_cgc/r_cgc.o .bss 0x00000000 0x0 ./synergy/ssp/src/driver/r_cgc/r_cgc.o .text.r_cgc_operating_mode_get 0x00000000 0x14 ./synergy/ssp/src/driver/r_cgc/r_cgc.o .text.r_cgc_hoco_wait_control_set 0x00000000 0x24 ./synergy/ssp/src/driver/r_cgc/r_cgc.o .text 0x00000000 0x0 ./synergy/ssp/src/driver/r_adc/r_adc.o .data 0x00000000 0x0 ./synergy/ssp/src/driver/r_adc/r_adc.o .bss 0x00000000 0x0 ./synergy/ssp/src/driver/r_adc/r_adc.o .text.r_adc_open_configure_pga_settings 0x00000000 0xc ./synergy/ssp/src/driver/r_adc/r_adc.o .text.adc_scan_end_b_isr 0x00000000 0x58 ./synergy/ssp/src/driver/r_adc/r_adc.o .text 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_cache.o .data 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_cache.o .bss 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_cache.o .text 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_clocks.o .data 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_clocks.o .bss 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_clocks.o .text 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o .data 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o .bss 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o .text.R_BSP_FeatureSciGet 0x00000000 0x8 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o .text.R_BSP_FeatureRspiGet 0x00000000 0x14 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o .text.R_BSP_FeatureLvdGet 0x00000000 0x24 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o .text.R_BSP_FeatureAcmphsGet 0x00000000 0x8 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o .text.R_BSP_FeatureCanGet 0x00000000 0x14 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o .text.R_BSP_FeatureDacGet 0x00000000 0x10 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o .text.R_BSP_FeatureCtsuGet 0x00000000 0x1c ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o .text.R_BSP_FeatureSdhiGet 0x00000000 0x14 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o .text.R_BSP_FeatureSsiGet 0x00000000 0x8 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o .text.R_BSP_FeatureICUGet 0x00000000 0xc ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o .text.R_BSP_FeatureLPMV2Get 0x00000000 0xc ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o .text 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_fmi_R7FS7G27G3A01CFB.o .data 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_fmi_R7FS7G27G3A01CFB.o .bss 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_fmi_R7FS7G27G3A01CFB.o .text 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_group_irq.o .data 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_group_irq.o .bss 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_group_irq.o .text.bsp_group_irq_call 0x00000000 0x18 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_group_irq.o .text 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o .data 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o .bss 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o .text 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_module_stop.o .data 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_module_stop.o .bss 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_module_stop.o .text.R_BSP_ModuleStopAlways 0x00000000 0x8 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_module_stop.o .text.R_BSP_ModuleStateGet 0x00000000 0x40 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_module_stop.o .text 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_rom_registers.o .data 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_rom_registers.o .bss 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_rom_registers.o .text 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/all/bsp_common.o .data 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/all/bsp_common.o .bss 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/all/bsp_common.o .text.R_BSP_VersionGet 0x00000000 0x14 ./synergy/ssp/src/bsp/mcu/all/bsp_common.o .text.R_SSP_VersionGet 0x00000000 0x14 ./synergy/ssp/src/bsp/mcu/all/bsp_common.o .text 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/all/bsp_common_leds.o .data 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/all/bsp_common_leds.o .bss 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/all/bsp_common_leds.o .text.R_BSP_LedsGet 0x00000000 0x20 ./synergy/ssp/src/bsp/mcu/all/bsp_common_leds.o .debug_info 0x00000000 0x1f21 ./synergy/ssp/src/bsp/mcu/all/bsp_common_leds.o .debug_abbrev 0x00000000 0x1e5 ./synergy/ssp/src/bsp/mcu/all/bsp_common_leds.o .debug_loc 0x00000000 0x34 ./synergy/ssp/src/bsp/mcu/all/bsp_common_leds.o .debug_aranges 0x00000000 0x20 ./synergy/ssp/src/bsp/mcu/all/bsp_common_leds.o .debug_ranges 0x00000000 0x10 ./synergy/ssp/src/bsp/mcu/all/bsp_common_leds.o .debug_line 0x00000000 0x3a9 ./synergy/ssp/src/bsp/mcu/all/bsp_common_leds.o .debug_str 0x00000000 0x5d6c ./synergy/ssp/src/bsp/mcu/all/bsp_common_leds.o .comment 0x00000000 0x7f ./synergy/ssp/src/bsp/mcu/all/bsp_common_leds.o .debug_frame 0x00000000 0x20 ./synergy/ssp/src/bsp/mcu/all/bsp_common_leds.o .ARM.attributes 0x00000000 0x39 ./synergy/ssp/src/bsp/mcu/all/bsp_common_leds.o .text 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/all/bsp_delay.o .data 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/all/bsp_delay.o .bss 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/all/bsp_delay.o .text 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/all/bsp_irq.o .data 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/all/bsp_irq.o .bss 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/all/bsp_irq.o .text 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/all/bsp_locking.o .data 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/all/bsp_locking.o .bss 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/all/bsp_locking.o .text.R_BSP_SoftwareLock 0x00000000 0x20 ./synergy/ssp/src/bsp/mcu/all/bsp_locking.o .text.R_BSP_SoftwareUnlock 0x00000000 0x8 ./synergy/ssp/src/bsp/mcu/all/bsp_locking.o .text.R_BSP_SoftwareLockInit 0x00000000 0x8 ./synergy/ssp/src/bsp/mcu/all/bsp_locking.o .text 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/all/bsp_register_protection.o .data 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/all/bsp_register_protection.o .bss 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/all/bsp_register_protection.o .text 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/all/bsp_sbrk.o .data 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/all/bsp_sbrk.o .bss 0x00000000 0x0 ./synergy/ssp/src/bsp/mcu/all/bsp_sbrk.o .text 0x00000000 0x0 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/startup_S7G2.o .data 0x00000000 0x0 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/startup_S7G2.o .bss 0x00000000 0x0 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/startup_S7G2.o .text 0x00000000 0x0 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/system_S7G2.o .data 0x00000000 0x0 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/system_S7G2.o .bss 0x00000000 0x0 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/system_S7G2.o .text.SystemCoreClockUpdate 0x00000000 0x10 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/system_S7G2.o .text 0x00000000 0x0 ./src/synergy_gen/common_data.o .data 0x00000000 0x0 ./src/synergy_gen/common_data.o .bss 0x00000000 0x0 ./src/synergy_gen/common_data.o .rodata.g_cgc 0x00000000 0x8 ./src/synergy_gen/common_data.o .rodata.g_elc 0x00000000 0x8 ./src/synergy_gen/common_data.o .rodata.g_fmi 0x00000000 0x4 ./src/synergy_gen/common_data.o .rodata.g_ioport 0x00000000 0x8 ./src/synergy_gen/common_data.o .text 0x00000000 0x0 ./src/synergy_gen/hal_data.o .data 0x00000000 0x0 ./src/synergy_gen/hal_data.o .bss 0x00000000 0x0 ./src/synergy_gen/hal_data.o .text 0x00000000 0x0 ./src/synergy_gen/main.o .data 0x00000000 0x0 ./src/synergy_gen/main.o .bss 0x00000000 0x0 ./src/synergy_gen/main.o .text 0x00000000 0x0 ./src/synergy_gen/new_thread0.o .data 0x00000000 0x0 ./src/synergy_gen/new_thread0.o .bss 0x00000000 0x0 ./src/synergy_gen/new_thread0.o .text 0x00000000 0x0 ./src/synergy_gen/pin_data.o .data 0x00000000 0x0 ./src/synergy_gen/pin_data.o .bss 0x00000000 0x0 ./src/synergy_gen/pin_data.o .text 0x00000000 0x0 ./src/hal_entry.o .data 0x00000000 0x0 ./src/hal_entry.o .bss 0x00000000 0x0 ./src/hal_entry.o .text.hal_entry 0x00000000 0x4c ./src/hal_entry.o .debug_info 0x00000000 0x2d09 ./src/hal_entry.o .debug_abbrev 0x00000000 0x2a7 ./src/hal_entry.o .debug_loc 0x00000000 0x4a ./src/hal_entry.o .debug_aranges 0x00000000 0x20 ./src/hal_entry.o .debug_ranges 0x00000000 0x10 ./src/hal_entry.o .debug_line 0x00000000 0x43d ./src/hal_entry.o .debug_str 0x00000000 0x6cde ./src/hal_entry.o .comment 0x00000000 0x7f ./src/hal_entry.o .debug_frame 0x00000000 0x30 ./src/hal_entry.o .ARM.attributes 0x00000000 0x39 ./src/hal_entry.o .text 0x00000000 0x0 ./src/new_thread0_entry.o .data 0x00000000 0x0 ./src/new_thread0_entry.o .bss 0x00000000 0x0 ./src/new_thread0_entry.o .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_create.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_create.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_create.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_get.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_get.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_get.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_put.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_put.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_put.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_thread_create.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_thread_create.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_thread_create.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_kernel_enter.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_kernel_enter.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_kernel_enter.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_end.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_end.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_end.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_start.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_start.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_start.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_create.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_create.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_create.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_get.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_get.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_get.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_put.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_put.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_put.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_create.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_create.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_create.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) .data._tx_version_id 0x00000000 0x62 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) .rodata._tx_thread_special_string 0x00000000 0x57 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_shell_entry.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_shell_entry.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_shell_entry.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_sleep.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_sleep.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_sleep.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_preempt_check.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_preempt_check.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_preempt_check.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_resume.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_resume.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_resume.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_suspend.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_suspend.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_suspend.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_timeout.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_timeout.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_timeout.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_activate.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_activate.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_activate.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_deactivate.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_deactivate.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_deactivate.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_low_level.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_low_level.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_low_level.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_schedule.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_schedule.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_schedule.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_stack_build.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_stack_build.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_stack_build.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_interrupt.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_interrupt.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_interrupt.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_cleanup.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_cleanup.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_cleanup.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_time_slice.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_time_slice.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_time_slice.o) .text 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_expiration_process.o) .data 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_expiration_process.o) .bss 0x00000000 0x0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_expiration_process.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-errno.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-errno.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-errno.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-exit.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-exit.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-exit.o) .text.exit 0x00000000 0x28 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-exit.o) .debug_frame 0x00000000 0x28 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-exit.o) .ARM.attributes 0x00000000 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-exit.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-impure.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-impure.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-impure.o) .rodata._global_impure_ptr 0x00000000 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-impure.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-init.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-init.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-init.o) .text.__libc_init_array 0x00000000 0x48 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-init.o) .debug_frame 0x00000000 0x2c c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-init.o) .ARM.attributes 0x00000000 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-init.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-memcmp.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-memcmp.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-memcmp.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-memset.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-memset.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-memset.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-rand.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-rand.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-rand.o) .text.rand 0x00000000 0x68 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-rand.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-malloc.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-malloc.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-malloc.o) .text.free 0x00000000 0x10 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-malloc.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-nano-freer.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-nano-freer.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-nano-freer.o) .text._free_r 0x00000000 0x9c c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-nano-freer.o) .debug_frame 0x00000000 0x38 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-nano-freer.o) .ARM.attributes 0x00000000 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-nano-freer.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-nano-mallocr.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-nano-mallocr.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-nano-mallocr.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-sbrkr.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-sbrkr.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-sbrkr.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-mlock.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-mlock.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-mlock.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-reent.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-reent.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-reent.o) .text.cleanup_glue 0x00000000 0x1a c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-reent.o) .text._reclaim_reent 0x00000000 0xb8 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-reent.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text.findslot 0x00000000 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text.checkerror 0x00000000 0x20 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text.error 0x00000000 0x1c c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._swiread 0x00000000 0x20 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._read 0x00000000 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._swilseek 0x00000000 0x7a c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._lseek 0x00000000 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._swiwrite 0x00000000 0x20 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._write 0x00000000 0x40 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._swiclose 0x00000000 0x1c c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._close 0x00000000 0x4c c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._getpid 0x00000000 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._sbrk 0x00000000 0x48 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._swistat 0x00000000 0x42 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._fstat 0x00000000 0x1c c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._stat 0x00000000 0x3a c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._swiopen 0x00000000 0xb8 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._open 0x00000000 0x12 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._get_semihosting_exts 0x00000000 0xb4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text.initialise_semihosting_exts 0x00000000 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._has_ext_exit_extended 0x00000000 0x18 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._has_ext_stdout_stderr 0x00000000 0x18 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text.initialise_monitor_handles 0x00000000 0xbc c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._link 0x00000000 0x10 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._unlink 0x00000000 0x28 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._gettimeofday 0x00000000 0x2a c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._clock 0x00000000 0x12 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._times 0x00000000 0x16 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._isatty 0x00000000 0x38 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._system 0x00000000 0x3e c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text._rename 0x00000000 0x36 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .bss.heap_end.7521 0x00000000 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .bss.monitor_stderr 0x00000000 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .bss.monitor_stdin 0x00000000 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .bss.monitor_stdout 0x00000000 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .bss.openfiles 0x00000000 0xa0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .data.__heap_limit 0x00000000 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .data.supports_ext_exit_extended 0x00000000 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .data.supports_ext_stdout_stderr 0x00000000 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .rodata._get_semihosting_exts.str1.1 0x00000000 0x16 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .rodata.initialise_monitor_handles.str1.1 0x00000000 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .debug_frame 0x00000000 0x3ac c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .ARM.attributes 0x00000000 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-syscalls.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-_exit.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-_exit.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-_exit.o) .text._exit 0x00000000 0x8 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-_exit.o) .debug_frame 0x00000000 0x20 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-_exit.o) .ARM.attributes 0x00000000 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-_exit.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-_kill.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-_kill.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-_kill.o) .text._kill 0x00000000 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-_kill.o) .debug_frame 0x00000000 0x2c c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-_kill.o) .ARM.attributes 0x00000000 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a(rdimon-_kill.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) .text.__fp_lock 0x00000000 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) .text.std 0x00000000 0x48 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) .text._cleanup_r 0x00000000 0xc c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) .text.__fp_unlock 0x00000000 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) .text.__sfmoreglue 0x00000000 0x2c c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) .text._cleanup 0x00000000 0xc c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) .text.__sinit 0x00000000 0x60 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) .text.__sfp 0x00000000 0x78 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) .text.__sfp_lock_acquire 0x00000000 0x2 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) .text.__sfp_lock_release 0x00000000 0x2 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) .text.__sinit_lock_acquire 0x00000000 0x2 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) .text.__sinit_lock_release 0x00000000 0x2 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) .text.__fp_lock_all 0x00000000 0x14 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) .text.__fp_unlock_all 0x00000000 0x14 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-fwalk.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-fwalk.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-fwalk.o) .text._fwalk 0x00000000 0x38 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-fwalk.o) .text._fwalk_reent 0x00000000 0x3c c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-fwalk.o) .debug_frame 0x00000000 0x54 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-fwalk.o) .ARM.attributes 0x00000000 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-fwalk.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-stdio.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-stdio.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-stdio.o) .text.__sread 0x00000000 0x22 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-stdio.o) .text.__seofread 0x00000000 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-stdio.o) .text.__swrite 0x00000000 0x38 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-stdio.o) .text.__sseek 0x00000000 0x24 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-stdio.o) .text.__sclose 0x00000000 0x8 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-stdio.o) .debug_frame 0x00000000 0x88 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-stdio.o) .ARM.attributes 0x00000000 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-stdio.o) .text 0x00000000 0x10 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-strlen.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-strlen.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-strlen.o) .ARM.attributes 0x00000000 0x1b c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-strlen.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-writer.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-writer.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-writer.o) .text._write_r 0x00000000 0x24 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-writer.o) .debug_frame 0x00000000 0x2c c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-writer.o) .ARM.attributes 0x00000000 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-writer.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-closer.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-closer.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-closer.o) .text._close_r 0x00000000 0x20 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-closer.o) .debug_frame 0x00000000 0x2c c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-closer.o) .ARM.attributes 0x00000000 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-closer.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-fflush.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-fflush.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-fflush.o) .text.__sflush_r 0x00000000 0x10c c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-fflush.o) .text._fflush_r 0x00000000 0x54 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-fflush.o) .text.fflush 0x00000000 0x24 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-fflush.o) .debug_frame 0x00000000 0x68 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-fflush.o) .ARM.attributes 0x00000000 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-fflush.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-lseekr.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-lseekr.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-lseekr.o) .text._lseek_r 0x00000000 0x24 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-lseekr.o) .debug_frame 0x00000000 0x2c c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-lseekr.o) .ARM.attributes 0x00000000 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-lseekr.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-readr.o) .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-readr.o) .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-readr.o) .text._read_r 0x00000000 0x24 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-readr.o) .debug_frame 0x00000000 0x2c c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-readr.o) .ARM.attributes 0x00000000 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-readr.o) .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtend.o .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtend.o .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtend.o .text 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtn.o .data 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtn.o .bss 0x00000000 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtn.o Memory Configuration Name Origin Length Attributes FLASH 0x00000000 0x00400000 xr RAM 0x1ffe0000 0x000a0000 xrw DATA_FLASH 0x40100000 0x00010000 xr QSPI_FLASH 0x60000000 0x04000000 xr SDRAM 0x90000000 0x02000000 xrw ID_CODES 0x40120050 0x00000010 xr *default* 0x00000000 0xffffffff Linker script and memory map LOAD c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crti.o LOAD c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtbegin.o LOAD c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard/rdimon-crt0.o START GROUP LOAD ./synergy/ssp/src/driver/r_ioport/r_ioport.o LOAD ./synergy/ssp/src/driver/r_fmi/r_fmi.o LOAD ./synergy/ssp/src/driver/r_elc/r_elc.o LOAD ./synergy/ssp/src/driver/r_cgc/r_cgc.o LOAD ./synergy/ssp/src/driver/r_adc/r_adc.o LOAD ./synergy/ssp/src/bsp/mcu/s7g2/bsp_cache.o LOAD ./synergy/ssp/src/bsp/mcu/s7g2/bsp_clocks.o LOAD ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o LOAD ./synergy/ssp/src/bsp/mcu/s7g2/bsp_fmi_R7FS7G27G3A01CFB.o LOAD ./synergy/ssp/src/bsp/mcu/s7g2/bsp_group_irq.o LOAD ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o LOAD ./synergy/ssp/src/bsp/mcu/s7g2/bsp_module_stop.o LOAD ./synergy/ssp/src/bsp/mcu/s7g2/bsp_rom_registers.o LOAD ./synergy/ssp/src/bsp/mcu/all/bsp_common.o LOAD ./synergy/ssp/src/bsp/mcu/all/bsp_common_leds.o LOAD ./synergy/ssp/src/bsp/mcu/all/bsp_delay.o LOAD ./synergy/ssp/src/bsp/mcu/all/bsp_irq.o LOAD ./synergy/ssp/src/bsp/mcu/all/bsp_locking.o LOAD ./synergy/ssp/src/bsp/mcu/all/bsp_register_protection.o LOAD ./synergy/ssp/src/bsp/mcu/all/bsp_sbrk.o LOAD ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/startup_S7G2.o LOAD ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/system_S7G2.o LOAD ./src/synergy_gen/common_data.o LOAD ./src/synergy_gen/hal_data.o LOAD ./src/synergy_gen/main.o LOAD ./src/synergy_gen/new_thread0.o LOAD ./src/synergy_gen/pin_data.o LOAD ./src/hal_entry.o LOAD ./src/new_thread0_entry.o LOAD F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\bsp\cmsis\DSP_Lib\cm4_gcc\libDSP_Lib.a LOAD F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a END GROUP START GROUP LOAD c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard\libgcc.a LOAD c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a LOAD c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a END GROUP START GROUP LOAD c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard\libgcc.a LOAD c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a LOAD c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a END GROUP START GROUP LOAD c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard\libgcc.a LOAD c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a LOAD c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\librdimon_nano.a END GROUP LOAD c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtend.o LOAD c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtn.o START GROUP LOAD c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard\libgcc.a LOAD c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc.a LOAD c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libm.a LOAD c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libnosys.a END GROUP .text 0x00000000 0x5488 0x00000000 __ROM_Start = . *(.vectors) .vectors 0x00000000 0x40 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/startup_S7G2.o 0x00000000 __Vectors *(SORT_BY_NAME(.vector.*)) .vector.ADC_1_SCAN_END 0x00000040 0x4 ./src/synergy_gen/new_thread0.o 0x00000040 g_vector_ADC_1_SCAN_END 0x00000044 __Vectors_End = . 0x00000044 __end__ = . 0x00000400 . = (__ROM_Start + 0x400) *fill* 0x00000044 0x3bc ff *(.rom_registers*) .rom_registers 0x00000400 0x3c ./synergy/ssp/src/bsp/mcu/s7g2/bsp_rom_registers.o 0x00000500 . = (__ROM_Start + 0x500) *fill* 0x0000043c 0xc4 ff 0x00000500 __Vector_Info_Start = . *(SORT_BY_NAME(.vector_info.*)) .vector_info.ADC_1_SCAN_END 0x00000500 0x8 ./src/synergy_gen/new_thread0.o 0x00000500 g_vector_info_ADC_1_SCAN_END 0x00000508 __Vector_Info_End = . 0x00000508 __Lock_Lookup_Start = . *(SORT_BY_NAME(.hw_lock_lookup.*)) .hw_lock_lookup.ADC_0U_0U 0x00000508 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000508 g_lock_lookup_ADC_0U_0U .hw_lock_lookup.ADC_0U_1U 0x0000050c 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x0000050c g_lock_lookup_ADC_0U_1U .hw_lock_lookup.AGT_0U_0U 0x00000510 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000510 g_lock_lookup_AGT_0U_0U .hw_lock_lookup.AGT_0U_1U 0x00000514 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000514 g_lock_lookup_AGT_0U_1U .hw_lock_lookup.BSC_0U_1U 0x00000518 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000518 g_lock_lookup_BSC_0U_1U .hw_lock_lookup.CAC_0U_0U 0x0000051c 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x0000051c g_lock_lookup_CAC_0U_0U .hw_lock_lookup.CAN_0U_0U 0x00000520 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000520 g_lock_lookup_CAN_0U_0U .hw_lock_lookup.CAN_0U_1U 0x00000524 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000524 g_lock_lookup_CAN_0U_1U .hw_lock_lookup.COMP_HS_0U_0U 0x00000528 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000528 g_lock_lookup_COMP_HS_0U_0U .hw_lock_lookup.COMP_HS_0U_1U 0x0000052c 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x0000052c g_lock_lookup_COMP_HS_0U_1U .hw_lock_lookup.COMP_HS_0U_2U 0x00000530 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000530 g_lock_lookup_COMP_HS_0U_2U .hw_lock_lookup.COMP_HS_0U_3U 0x00000534 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000534 g_lock_lookup_COMP_HS_0U_3U .hw_lock_lookup.COMP_HS_0U_4U 0x00000538 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000538 g_lock_lookup_COMP_HS_0U_4U .hw_lock_lookup.COMP_HS_0U_5U 0x0000053c 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x0000053c g_lock_lookup_COMP_HS_0U_5U .hw_lock_lookup.CRC_0U_0U 0x00000540 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000540 g_lock_lookup_CRC_0U_0U .hw_lock_lookup.CTSU_0U_0U 0x00000544 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000544 g_lock_lookup_CTSU_0U_0U .hw_lock_lookup.DAAD_0U_0U 0x00000548 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000548 g_lock_lookup_DAAD_0U_0U .hw_lock_lookup.DAC_0U_0U 0x0000054c 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x0000054c g_lock_lookup_DAC_0U_0U .hw_lock_lookup.DAC_0U_1U 0x00000550 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000550 g_lock_lookup_DAC_0U_1U .hw_lock_lookup.DMAC_0U_0U 0x00000554 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000554 g_lock_lookup_DMAC_0U_0U .hw_lock_lookup.DMAC_0U_1U 0x00000558 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000558 g_lock_lookup_DMAC_0U_1U .hw_lock_lookup.DMAC_0U_2U 0x0000055c 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x0000055c g_lock_lookup_DMAC_0U_2U .hw_lock_lookup.DMAC_0U_3U 0x00000560 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000560 g_lock_lookup_DMAC_0U_3U .hw_lock_lookup.DMAC_0U_4U 0x00000564 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000564 g_lock_lookup_DMAC_0U_4U .hw_lock_lookup.DMAC_0U_5U 0x00000568 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000568 g_lock_lookup_DMAC_0U_5U .hw_lock_lookup.DMAC_0U_6U 0x0000056c 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x0000056c g_lock_lookup_DMAC_0U_6U .hw_lock_lookup.DMAC_0U_7U 0x00000570 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000570 g_lock_lookup_DMAC_0U_7U .hw_lock_lookup.DOC_0U_0U 0x00000574 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000574 g_lock_lookup_DOC_0U_0U .hw_lock_lookup.DRW_0U_0U 0x00000578 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000578 g_lock_lookup_DRW_0U_0U .hw_lock_lookup.DTC_0U_0U 0x0000057c 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x0000057c g_lock_lookup_DTC_0U_0U .hw_lock_lookup.ELC_0U_0U 0x00000580 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000580 g_lock_lookup_ELC_0U_0U .hw_lock_lookup.EPTPC_0U_0U 0x00000584 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000584 g_lock_lookup_EPTPC_0U_0U .hw_lock_lookup.ETHER_0U_0U 0x00000588 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000588 g_lock_lookup_ETHER_0U_0U .hw_lock_lookup.ETHER_0U_1U 0x0000058c 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x0000058c g_lock_lookup_ETHER_0U_1U .hw_lock_lookup.FCU_0U_0U 0x00000590 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000590 g_lock_lookup_FCU_0U_0U .hw_lock_lookup.GLCDC_0U_0U 0x00000594 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000594 g_lock_lookup_GLCDC_0U_0U .hw_lock_lookup.GPT_0U_0U 0x00000598 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000598 g_lock_lookup_GPT_0U_0U .hw_lock_lookup.GPT_0U_10U 0x0000059c 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x0000059c g_lock_lookup_GPT_0U_10U .hw_lock_lookup.GPT_0U_11U 0x000005a0 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005a0 g_lock_lookup_GPT_0U_11U .hw_lock_lookup.GPT_0U_12U 0x000005a4 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005a4 g_lock_lookup_GPT_0U_12U .hw_lock_lookup.GPT_0U_13U 0x000005a8 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005a8 g_lock_lookup_GPT_0U_13U .hw_lock_lookup.GPT_0U_1U 0x000005ac 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005ac g_lock_lookup_GPT_0U_1U .hw_lock_lookup.GPT_0U_2U 0x000005b0 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005b0 g_lock_lookup_GPT_0U_2U .hw_lock_lookup.GPT_0U_3U 0x000005b4 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005b4 g_lock_lookup_GPT_0U_3U .hw_lock_lookup.GPT_0U_4U 0x000005b8 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005b8 g_lock_lookup_GPT_0U_4U .hw_lock_lookup.GPT_0U_5U 0x000005bc 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005bc g_lock_lookup_GPT_0U_5U .hw_lock_lookup.GPT_0U_6U 0x000005c0 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005c0 g_lock_lookup_GPT_0U_6U .hw_lock_lookup.GPT_0U_7U 0x000005c4 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005c4 g_lock_lookup_GPT_0U_7U .hw_lock_lookup.GPT_0U_8U 0x000005c8 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005c8 g_lock_lookup_GPT_0U_8U .hw_lock_lookup.GPT_0U_9U 0x000005cc 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005cc g_lock_lookup_GPT_0U_9U .hw_lock_lookup.ICU_0U_0U 0x000005d0 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005d0 g_lock_lookup_ICU_0U_0U .hw_lock_lookup.ICU_0U_10U 0x000005d4 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005d4 g_lock_lookup_ICU_0U_10U .hw_lock_lookup.ICU_0U_11U 0x000005d8 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005d8 g_lock_lookup_ICU_0U_11U .hw_lock_lookup.ICU_0U_12U 0x000005dc 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005dc g_lock_lookup_ICU_0U_12U .hw_lock_lookup.ICU_0U_13U 0x000005e0 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005e0 g_lock_lookup_ICU_0U_13U .hw_lock_lookup.ICU_0U_14U 0x000005e4 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005e4 g_lock_lookup_ICU_0U_14U .hw_lock_lookup.ICU_0U_15U 0x000005e8 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005e8 g_lock_lookup_ICU_0U_15U .hw_lock_lookup.ICU_0U_1U 0x000005ec 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005ec g_lock_lookup_ICU_0U_1U .hw_lock_lookup.ICU_0U_2U 0x000005f0 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005f0 g_lock_lookup_ICU_0U_2U .hw_lock_lookup.ICU_0U_3U 0x000005f4 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005f4 g_lock_lookup_ICU_0U_3U .hw_lock_lookup.ICU_0U_4U 0x000005f8 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005f8 g_lock_lookup_ICU_0U_4U .hw_lock_lookup.ICU_0U_5U 0x000005fc 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000005fc g_lock_lookup_ICU_0U_5U .hw_lock_lookup.ICU_0U_6U 0x00000600 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000600 g_lock_lookup_ICU_0U_6U .hw_lock_lookup.ICU_0U_7U 0x00000604 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000604 g_lock_lookup_ICU_0U_7U .hw_lock_lookup.ICU_0U_8U 0x00000608 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000608 g_lock_lookup_ICU_0U_8U .hw_lock_lookup.ICU_0U_9U 0x0000060c 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x0000060c g_lock_lookup_ICU_0U_9U .hw_lock_lookup.IIC_0U_0U 0x00000610 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000610 g_lock_lookup_IIC_0U_0U .hw_lock_lookup.IIC_0U_1U 0x00000614 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000614 g_lock_lookup_IIC_0U_1U .hw_lock_lookup.IIC_0U_2U 0x00000618 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000618 g_lock_lookup_IIC_0U_2U .hw_lock_lookup.IRDA_0U_0U 0x0000061c 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x0000061c g_lock_lookup_IRDA_0U_0U .hw_lock_lookup.IWDT_0U_0U 0x00000620 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000620 g_lock_lookup_IWDT_0U_0U .hw_lock_lookup.JPEG_0U_0U 0x00000624 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000624 g_lock_lookup_JPEG_0U_0U .hw_lock_lookup.KEY_0U_0U 0x00000628 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000628 g_lock_lookup_KEY_0U_0U .hw_lock_lookup.LPM_1U_0U 0x0000062c 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x0000062c g_lock_lookup_LPM_1U_0U .hw_lock_lookup.LVD_0U_0U 0x00000630 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000630 g_lock_lookup_LVD_0U_0U .hw_lock_lookup.LVD_0U_1U 0x00000634 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000634 g_lock_lookup_LVD_0U_1U .hw_lock_lookup.MMF_0U_0U 0x00000638 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000638 g_lock_lookup_MMF_0U_0U .hw_lock_lookup.MPU_0U_0U 0x0000063c 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x0000063c g_lock_lookup_MPU_0U_0U .hw_lock_lookup.OPS_0U_0U 0x00000640 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000640 g_lock_lookup_OPS_0U_0U .hw_lock_lookup.PDC_0U_0U 0x00000644 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000644 g_lock_lookup_PDC_0U_0U .hw_lock_lookup.POEG_0U_0U 0x00000648 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000648 g_lock_lookup_POEG_0U_0U .hw_lock_lookup.POEG_0U_1U 0x0000064c 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x0000064c g_lock_lookup_POEG_0U_1U .hw_lock_lookup.POEG_0U_2U 0x00000650 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000650 g_lock_lookup_POEG_0U_2U .hw_lock_lookup.POEG_0U_3U 0x00000654 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000654 g_lock_lookup_POEG_0U_3U .hw_lock_lookup.QSPI_0U_0U 0x00000658 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000658 g_lock_lookup_QSPI_0U_0U .hw_lock_lookup.RTC_0U_0U 0x0000065c 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x0000065c g_lock_lookup_RTC_0U_0U .hw_lock_lookup.SCE_0U_0U 0x00000660 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000660 g_lock_lookup_SCE_0U_0U .hw_lock_lookup.SCI_0U_0U 0x00000664 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000664 g_lock_lookup_SCI_0U_0U .hw_lock_lookup.SCI_0U_1U 0x00000668 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000668 g_lock_lookup_SCI_0U_1U .hw_lock_lookup.SCI_0U_2U 0x0000066c 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x0000066c g_lock_lookup_SCI_0U_2U .hw_lock_lookup.SCI_0U_3U 0x00000670 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000670 g_lock_lookup_SCI_0U_3U .hw_lock_lookup.SCI_0U_4U 0x00000674 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000674 g_lock_lookup_SCI_0U_4U .hw_lock_lookup.SCI_0U_5U 0x00000678 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000678 g_lock_lookup_SCI_0U_5U .hw_lock_lookup.SCI_0U_6U 0x0000067c 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x0000067c g_lock_lookup_SCI_0U_6U .hw_lock_lookup.SCI_0U_7U 0x00000680 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000680 g_lock_lookup_SCI_0U_7U .hw_lock_lookup.SCI_0U_8U 0x00000684 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000684 g_lock_lookup_SCI_0U_8U .hw_lock_lookup.SCI_0U_9U 0x00000688 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000688 g_lock_lookup_SCI_0U_9U .hw_lock_lookup.SDHIMMC_0U_0U 0x0000068c 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x0000068c g_lock_lookup_SDHIMMC_0U_0U .hw_lock_lookup.SDHIMMC_0U_1U 0x00000690 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000690 g_lock_lookup_SDHIMMC_0U_1U .hw_lock_lookup.SPI_0U_0U 0x00000694 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000694 g_lock_lookup_SPI_0U_0U .hw_lock_lookup.SPI_0U_1U 0x00000698 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x00000698 g_lock_lookup_SPI_0U_1U .hw_lock_lookup.SRC_0U_0U 0x0000069c 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x0000069c g_lock_lookup_SRC_0U_0U .hw_lock_lookup.SSI_0U_0U 0x000006a0 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000006a0 g_lock_lookup_SSI_0U_0U .hw_lock_lookup.SSI_0U_1U 0x000006a4 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000006a4 g_lock_lookup_SSI_0U_1U .hw_lock_lookup.TSN_0U_0U 0x000006a8 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000006a8 g_lock_lookup_TSN_0U_0U .hw_lock_lookup.USB_0U_0U 0x000006ac 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000006ac g_lock_lookup_USB_0U_0U .hw_lock_lookup.USB_1U_0U 0x000006b0 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000006b0 g_lock_lookup_USB_1U_0U .hw_lock_lookup.WDT_0U_0U 0x000006b4 0x4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x000006b4 g_lock_lookup_WDT_0U_0U 0x000006b8 __Lock_Lookup_End = . *(.text*) .text 0x000006b8 0x40 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtbegin.o .text.R_IOPORT_PinRead 0x000006f8 0x4c ./synergy/ssp/src/driver/r_ioport/r_ioport.o 0x000006f8 R_IOPORT_PinRead .text.R_IOPORT_PortRead 0x00000744 0x28 ./synergy/ssp/src/driver/r_ioport/r_ioport.o 0x00000744 R_IOPORT_PortRead .text.R_IOPORT_PortEventInputRead 0x0000076c 0x28 ./synergy/ssp/src/driver/r_ioport/r_ioport.o 0x0000076c R_IOPORT_PortEventInputRead .text.R_IOPORT_PinEventInputRead 0x00000794 0x54 ./synergy/ssp/src/driver/r_ioport/r_ioport.o 0x00000794 R_IOPORT_PinEventInputRead .text.R_IOPORT_PortEventOutputWrite 0x000007e8 0x38 ./synergy/ssp/src/driver/r_ioport/r_ioport.o 0x000007e8 R_IOPORT_PortEventOutputWrite .text.R_IOPORT_PinEventOutputWrite 0x00000820 0x58 ./synergy/ssp/src/driver/r_ioport/r_ioport.o 0x00000820 R_IOPORT_PinEventOutputWrite .text.R_IOPORT_VersionGet 0x00000878 0x14 ./synergy/ssp/src/driver/r_ioport/r_ioport.o 0x00000878 R_IOPORT_VersionGet .text.R_IOPORT_PinWrite 0x0000088c 0x54 ./synergy/ssp/src/driver/r_ioport/r_ioport.o 0x0000088c R_IOPORT_PinWrite .text.R_IOPORT_PinDirectionSet 0x000008e0 0xd0 ./synergy/ssp/src/driver/r_ioport/r_ioport.o 0x000008e0 R_IOPORT_PinDirectionSet .text.R_IOPORT_PortWrite 0x000009b0 0x38 ./synergy/ssp/src/driver/r_ioport/r_ioport.o 0x000009b0 R_IOPORT_PortWrite .text.R_IOPORT_PortDirectionSet 0x000009e8 0x40 ./synergy/ssp/src/driver/r_ioport/r_ioport.o 0x000009e8 R_IOPORT_PortDirectionSet .text.bsp_vbatt_init.isra.4 0x00000a28 0x8c ./synergy/ssp/src/driver/r_ioport/r_ioport.o .text.R_IOPORT_EthernetModeCfg 0x00000ab4 0x54 ./synergy/ssp/src/driver/r_ioport/r_ioport.o 0x00000ab4 R_IOPORT_EthernetModeCfg .text.R_IOPORT_PinsCfg.part.5 0x00000b08 0xc0 ./synergy/ssp/src/driver/r_ioport/r_ioport.o .text.R_IOPORT_PinsCfg 0x00000bc8 0x10 ./synergy/ssp/src/driver/r_ioport/r_ioport.o 0x00000bc8 R_IOPORT_PinsCfg .text.R_IOPORT_Init 0x00000bd8 0x88 ./synergy/ssp/src/driver/r_ioport/r_ioport.o 0x00000bd8 R_IOPORT_Init .text.R_IOPORT_PinCfg 0x00000c60 0xcc ./synergy/ssp/src/driver/r_ioport/r_ioport.o 0x00000c60 R_IOPORT_PinCfg .text.R_FMI_ProductInfoGet 0x00000d2c 0x30 ./synergy/ssp/src/driver/r_fmi/r_fmi.o .text.R_FMI_VersionGet 0x00000d5c 0x14 ./synergy/ssp/src/driver/r_fmi/r_fmi.o .text.R_FMI_Init 0x00000d70 0x6c ./synergy/ssp/src/driver/r_fmi/r_fmi.o .text.R_FMI_UniqueIdGet 0x00000ddc 0x40 ./synergy/ssp/src/driver/r_fmi/r_fmi.o .text.R_FMI_EventInfoGet 0x00000e1c 0x84 ./synergy/ssp/src/driver/r_fmi/r_fmi.o .text.R_FMI_FeatureGet 0x00000ea0 0x244 ./synergy/ssp/src/driver/r_fmi/r_fmi.o .text.R_ELC_LinkSet 0x000010e4 0x14 ./synergy/ssp/src/driver/r_elc/r_elc.o 0x000010e4 R_ELC_LinkSet .text.R_ELC_LinkBreak 0x000010f8 0x14 ./synergy/ssp/src/driver/r_elc/r_elc.o 0x000010f8 R_ELC_LinkBreak .text.R_ELC_Enable 0x0000110c 0x14 ./synergy/ssp/src/driver/r_elc/r_elc.o 0x0000110c R_ELC_Enable .text.R_ELC_Disable 0x00001120 0x14 ./synergy/ssp/src/driver/r_elc/r_elc.o 0x00001120 R_ELC_Disable .text.R_ELC_VersionGet 0x00001134 0x14 ./synergy/ssp/src/driver/r_elc/r_elc.o 0x00001134 R_ELC_VersionGet .text.R_ELC_SoftwareEventGenerate 0x00001148 0x30 ./synergy/ssp/src/driver/r_elc/r_elc.o 0x00001148 R_ELC_SoftwareEventGenerate .text.R_ELC_Init 0x00001178 0x7c ./synergy/ssp/src/driver/r_elc/r_elc.o 0x00001178 R_ELC_Init .text.R_CGC_LCDClockCfg 0x000011f4 0x4 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x000011f4 R_CGC_LCDClockCfg .text.R_CGC_LCDClockEnable 0x000011f8 0x4 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x000011f8 R_CGC_LCDClockEnable .text.R_CGC_VersionGet 0x000011fc 0x14 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x000011fc R_CGC_VersionGet .text.r_cgc_init_pllfreq 0x00001210 0xd8 ./synergy/ssp/src/driver/r_cgc/r_cgc.o .text.R_CGC_SystemClockFreqGet 0x000012e8 0xb4 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x000012e8 R_CGC_SystemClockFreqGet .text.r_cgc_system_dividers_set 0x0000139c 0x44 ./synergy/ssp/src/driver/r_cgc/r_cgc.o .text.R_CGC_OscStopStatusClear 0x000013e0 0x64 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x000013e0 R_CGC_OscStopStatusClear .text.R_CGC_BusClockOutCfg 0x00001444 0x28 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x00001444 R_CGC_BusClockOutCfg .text.R_CGC_BusClockOutEnable 0x0000146c 0x28 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x0000146c R_CGC_BusClockOutEnable .text.R_CGC_BusClockOutDisable 0x00001494 0x28 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x00001494 R_CGC_BusClockOutDisable .text.R_CGC_ClockOutEnable 0x000014bc 0x28 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x000014bc R_CGC_ClockOutEnable .text.R_CGC_ClockOutDisable 0x000014e4 0x28 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x000014e4 R_CGC_ClockOutDisable .text.R_CGC_SDRAMClockOutEnable 0x0000150c 0x28 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x0000150c R_CGC_SDRAMClockOutEnable .text.R_CGC_SDRAMClockOutDisable 0x00001534 0x28 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x00001534 R_CGC_SDRAMClockOutDisable .text.R_CGC_USBClockCfg 0x0000155c 0x28 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x0000155c R_CGC_USBClockCfg .text.r_cgc_check_dividers 0x00001584 0x34 ./synergy/ssp/src/driver/r_cgc/r_cgc.o .text.R_CGC_SystickUpdate.part.6 0x000015b8 0x84 ./synergy/ssp/src/driver/r_cgc/r_cgc.o .text.R_CGC_SystickUpdate 0x0000163c 0xc ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x0000163c R_CGC_SystickUpdate .text.R_CGC_ClockOutCfg 0x00001648 0x5c ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x00001648 R_CGC_ClockOutCfg .text.R_CGC_OscStopDetect 0x000016a4 0x118 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x000016a4 R_CGC_OscStopDetect .text.r_cgc_subclock_drive_set.constprop.16 0x000017bc 0x34 ./synergy/ssp/src/driver/r_cgc/r_cgc.o .text.R_CGC_SDADCClockCfg 0x000017f0 0x4 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x000017f0 R_CGC_SDADCClockCfg .text.R_CGC_LCDClockDisable 0x000017f4 0x4 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x000017f4 R_CGC_LCDClockDisable .text.R_CGC_SDADCClockEnable 0x000017f8 0x4 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x000017f8 R_CGC_SDADCClockEnable .text.R_CGC_SDADCClockDisable 0x000017fc 0x4 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x000017fc R_CGC_SDADCClockDisable .text.R_CGC_SystemClockGet 0x00001800 0x58 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x00001800 R_CGC_SystemClockGet .text.r_cgc_clock_run_state_get 0x00001858 0x68 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x00001858 r_cgc_clock_run_state_get .text.r_cgc_wait_to_complete 0x000018c0 0x44 ./synergy/ssp/src/driver/r_cgc/r_cgc.o .text.R_CGC_Init 0x00001904 0xe0 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x00001904 R_CGC_Init .text.R_CGC_ClockStop 0x000019e4 0x154 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x000019e4 R_CGC_ClockStop .text.R_CGC_ClockCheck 0x00001b38 0x8c ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x00001b38 R_CGC_ClockCheck .text.r_cgc_stabilization_wait 0x00001bc4 0x30 ./synergy/ssp/src/driver/r_cgc/r_cgc.o .text.r_cgc_operating_hw_modeset 0x00001bf4 0xfc ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x00001bf4 r_cgc_operating_hw_modeset .text.r_cgc_operating_mode_set 0x00001cf0 0x50 ./synergy/ssp/src/driver/r_cgc/r_cgc.o .text.R_CGC_ClockStart 0x00001d40 0x358 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x00001d40 R_CGC_ClockStart .text.r_cgc_clock_start_stop 0x00002098 0x54 ./synergy/ssp/src/driver/r_cgc/r_cgc.o .text.R_CGC_SystemClockSet 0x000020ec 0x1b8 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x000020ec R_CGC_SystemClockSet .text.R_CGC_ClocksCfg 0x000022a4 0x14c ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x000022a4 R_CGC_ClocksCfg .text.R_ADC_SetSampleStateCount 0x000023f0 0x24 ./synergy/ssp/src/driver/r_adc/r_adc.o 0x000023f0 R_ADC_SetSampleStateCount .text.R_ADC_Read 0x00002414 0x28 ./synergy/ssp/src/driver/r_adc/r_adc.o 0x00002414 R_ADC_Read .text.R_ADC_Read32 0x0000243c 0x38 ./synergy/ssp/src/driver/r_adc/r_adc.o 0x0000243c R_ADC_Read32 .text.R_ADC_VersionGet 0x00002474 0x10 ./synergy/ssp/src/driver/r_adc/r_adc.o 0x00002474 R_ADC_VersionGet .text.R_ADC_OffsetSet 0x00002484 0x4 ./synergy/ssp/src/driver/r_adc/r_adc.o 0x00002484 R_ADC_OffsetSet .text.R_ADC_ScanStart 0x00002488 0x3c ./synergy/ssp/src/driver/r_adc/r_adc.o 0x00002488 R_ADC_ScanStart .text.R_ADC_ScanStop 0x000024c4 0x2c ./synergy/ssp/src/driver/r_adc/r_adc.o 0x000024c4 R_ADC_ScanStop .text.R_ADC_CheckScanDone 0x000024f0 0x20 ./synergy/ssp/src/driver/r_adc/r_adc.o 0x000024f0 R_ADC_CheckScanDone .text.R_ADC_InfoGet 0x00002510 0xcc ./synergy/ssp/src/driver/r_adc/r_adc.o 0x00002510 R_ADC_InfoGet .text.R_ADC_Calibrate 0x000025dc 0x44 ./synergy/ssp/src/driver/r_adc/r_adc.o 0x000025dc R_ADC_Calibrate .text.r_adc_close_sub 0x00002620 0x68 ./synergy/ssp/src/driver/r_adc/r_adc.o .text.r_adc_open_configure_pga_settings.part.25 0x00002688 0x1f0 ./synergy/ssp/src/driver/r_adc/r_adc.o .text.R_ADC_Close 0x00002878 0xf4 ./synergy/ssp/src/driver/r_adc/r_adc.o 0x00002878 R_ADC_Close .text.R_ADC_Open 0x0000296c 0x414 ./synergy/ssp/src/driver/r_adc/r_adc.o 0x0000296c R_ADC_Open .text.R_ADC_ScanConfigure 0x00002d80 0x2d4 ./synergy/ssp/src/driver/r_adc/r_adc.o 0x00002d80 R_ADC_ScanConfigure .text.adc_scan_end_isr 0x00003054 0x58 ./synergy/ssp/src/driver/r_adc/r_adc.o 0x00003054 adc_scan_end_isr .text.R_BSP_CacheOff 0x000030ac 0x28 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_cache.o 0x000030ac R_BSP_CacheOff .text.R_BSP_CacheSet 0x000030d4 0x48 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_cache.o 0x000030d4 R_BSP_CacheSet .text.bsp_clock_init 0x0000311c 0xa0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_clocks.o 0x0000311c bsp_clock_init .text.bsp_cpu_clock_get 0x000031bc 0x20 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_clocks.o 0x000031bc bsp_cpu_clock_get .text.bsp_clock_set_callback 0x000031dc 0x138 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_clocks.o 0x000031dc bsp_clock_set_callback .text.R_BSP_FeatureAdcGet 0x00003314 0x34 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o 0x00003314 R_BSP_FeatureAdcGet .text.R_BSP_FeatureIoportGet 0x00003348 0xc ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o 0x00003348 R_BSP_FeatureIoportGet .text.R_BSP_FeatureCgcGet 0x00003354 0xc ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o 0x00003354 R_BSP_FeatureCgcGet .text.bsp_group_interrupt_open 0x00003360 0x18 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_group_irq.o 0x00003360 bsp_group_interrupt_open .text.R_BSP_GroupIrqWrite 0x00003378 0x10 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_group_irq.o 0x00003378 R_BSP_GroupIrqWrite .text.NMI_Handler 0x00003388 0x1c8 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_group_irq.o 0x00003388 NMI_Handler .text.r_bsp_get_mstp_mask 0x00003550 0x4c ./synergy/ssp/src/bsp/mcu/s7g2/bsp_module_stop.o .text.r_bsp_module_start_stop 0x0000359c 0x6c ./synergy/ssp/src/bsp/mcu/s7g2/bsp_module_stop.o .text.R_BSP_ModuleStop 0x00003608 0x8 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_module_stop.o 0x00003608 R_BSP_ModuleStop .text.R_BSP_ModuleStart 0x00003610 0x8 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_module_stop.o 0x00003610 R_BSP_ModuleStart .text.bsp_init_internal 0x00003618 0x4 ./synergy/ssp/src/bsp/mcu/all/bsp_common.o 0x00003618 bsp_init_internal 0x00003618 bsp_init .text.software_delay_loop 0x0000361c 0xc ./synergy/ssp/src/bsp/mcu/all/bsp_delay.o .text.R_BSP_SoftwareDelay 0x00003628 0x60 ./synergy/ssp/src/bsp/mcu/all/bsp_delay.o 0x00003628 R_BSP_SoftwareDelay .text.R_BSP_IrqStatusClear 0x00003688 0x18 ./synergy/ssp/src/bsp/mcu/all/bsp_irq.o 0x00003688 R_BSP_IrqStatusClear .text.bsp_irq_cfg 0x000036a0 0x40 ./synergy/ssp/src/bsp/mcu/all/bsp_irq.o 0x000036a0 bsp_irq_cfg .text.R_BSP_HardwareLock 0x000036e0 0x68 ./synergy/ssp/src/bsp/mcu/all/bsp_locking.o 0x000036e0 R_BSP_HardwareLock .text.R_BSP_HardwareUnlock 0x00003748 0x4c ./synergy/ssp/src/bsp/mcu/all/bsp_locking.o 0x00003748 R_BSP_HardwareUnlock .text.bsp_init_hardware_locks 0x00003794 0x68 ./synergy/ssp/src/bsp/mcu/all/bsp_locking.o 0x00003794 bsp_init_hardware_locks .text.R_BSP_RegisterProtectEnable 0x000037fc 0x60 ./synergy/ssp/src/bsp/mcu/all/bsp_register_protection.o 0x000037fc R_BSP_RegisterProtectEnable .text.R_BSP_RegisterProtectDisable 0x0000385c 0x4c ./synergy/ssp/src/bsp/mcu/all/bsp_register_protection.o 0x0000385c R_BSP_RegisterProtectDisable .text.bsp_register_protect_open 0x000038a8 0x10 ./synergy/ssp/src/bsp/mcu/all/bsp_register_protection.o 0x000038a8 bsp_register_protect_open .text._sbrk 0x000038b8 0x40 ./synergy/ssp/src/bsp/mcu/all/bsp_sbrk.o 0x000038b8 _sbrk .text.Default_Handler 0x000038f8 0x4 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/startup_S7G2.o 0x000038f8 HardFault_Handler 0x000038f8 UsageFault_Handler 0x000038f8 Default_Handler 0x000038f8 MemManage_Handler 0x000038f8 SVC_Handler 0x000038f8 BusFault_Handler 0x000038f8 DebugMon_Handler .text.Reset_Handler 0x000038fc 0xc ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/startup_S7G2.o 0x000038fc Reset_Handler .text.R_BSP_WarmStart 0x00003908 0x4 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/system_S7G2.o 0x00003908 R_BSP_WarmStart *fill* 0x0000390c 0x4 ff .text.SystemInit 0x00003910 0x160 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/system_S7G2.o 0x00003910 SystemInit .text.g_common_init 0x00003a70 0x4 ./src/synergy_gen/common_data.o 0x00003a70 g_common_init .text.g_hal_init 0x00003a74 0x4 ./src/synergy_gen/hal_data.o 0x00003a74 g_hal_init .text.tx_application_define_internal 0x00003a78 0x4 ./src/synergy_gen/main.o 0x00003a78 tx_application_define_user 0x00003a78 tx_application_define_internal .text.tx_startup_err_callback_internal 0x00003a7c 0x4 ./src/synergy_gen/main.o 0x00003a7c tx_startup_err_callback_internal 0x00003a7c tx_startup_err_callback .text.tx_application_define 0x00003a80 0x40 ./src/synergy_gen/main.o 0x00003a80 tx_application_define .text.tx_startup_common_init 0x00003ac0 0x64 ./src/synergy_gen/main.o 0x00003ac0 tx_startup_common_init .text.startup.main 0x00003b24 0xc ./src/synergy_gen/main.o 0x00003b24 main .text.new_thread0_func 0x00003b30 0x10 ./src/synergy_gen/new_thread0.o .text.new_thread0_create 0x00003b40 0x5c ./src/synergy_gen/new_thread0.o 0x00003b40 new_thread0_create .text.new_thread0_entry 0x00003b9c 0x54 ./src/new_thread0_entry.o 0x00003b9c new_thread0_entry .text.ADC_callback 0x00003bf0 0x38 ./src/new_thread0_entry.o 0x00003bf0 ADC_callback .text._txe_semaphore_create 0x00003c28 0xa4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_create.o) 0x00003c28 _txe_semaphore_create .text._txe_semaphore_get 0x00003ccc 0x2c F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_get.o) 0x00003ccc _txe_semaphore_get .text._txe_semaphore_put 0x00003cf8 0x18 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_put.o) 0x00003cf8 _txe_semaphore_put .text._txe_thread_create 0x00003d10 0x150 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_thread_create.o) 0x00003d10 _txe_thread_create .text._tx_initialize_high_level 0x00003e60 0x70 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) 0x00003e60 _tx_initialize_high_level .text._tx_initialize_kernel_enter 0x00003ed0 0x48 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_kernel_enter.o) 0x00003ed0 _tx_initialize_kernel_enter .text.tx_isr_end 0x00003f18 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_end.o) 0x00003f18 tx_isr_end .text.tx_isr_start 0x00003f1c 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_start.o) 0x00003f1c tx_isr_start .text._tx_semaphore_create 0x00003f20 0x54 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_create.o) 0x00003f20 _tx_semaphore_create .text._tx_semaphore_get 0x00003f74 0x84 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_get.o) 0x00003f74 _tx_semaphore_get .text._tx_semaphore_put 0x00003ff8 0x54 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_put.o) 0x00003ff8 _tx_semaphore_put .text._tx_thread_create 0x0000404c 0x138 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_create.o) 0x0000404c _tx_thread_create .text._tx_thread_initialize 0x00004184 0x64 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) 0x00004184 _tx_thread_initialize .text._tx_thread_shell_entry 0x000041e8 0x48 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_shell_entry.o) 0x000041e8 _tx_thread_shell_entry .text._tx_thread_sleep 0x00004230 0x60 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_sleep.o) 0x00004230 _tx_thread_sleep .text._tx_thread_system_preempt_check 0x00004290 0x3c F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_preempt_check.o) 0x00004290 _tx_thread_system_preempt_check .text._tx_thread_system_resume 0x000042cc 0xec F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_resume.o) 0x000042cc _tx_thread_system_resume .text._tx_thread_system_suspend 0x000043b8 0x104 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_suspend.o) 0x000043b8 _tx_thread_system_suspend .text._tx_thread_timeout 0x000044bc 0x40 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_timeout.o) 0x000044bc _tx_thread_timeout .text._tx_timer_initialize 0x000044fc 0x74 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) 0x000044fc _tx_timer_initialize .text._tx_timer_system_activate 0x00004570 0x54 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_activate.o) 0x00004570 _tx_timer_system_activate .text._tx_timer_system_deactivate 0x000045c4 0x2c F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_deactivate.o) 0x000045c4 _tx_timer_system_deactivate .text._tx_initialize_low_level 0x000045f0 0x8c F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_low_level.o) 0x000045f0 _tx_initialize_low_level .text._tx_thread_schedule 0x0000467c 0x5c F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_schedule.o) 0x0000467c _tx_thread_schedule .text._tx_port_wait_thread_ready 0x000046d8 0xa8 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_schedule.o) 0x000046d8 _tx_port_wait_thread_ready .text.PendSV_Handler 0x00004780 0xb4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_schedule.o) 0x00004780 PendSV_Handler .text.SysTick_Handler 0x00004834 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_schedule.o) 0x00004834 SysTick_Handler .text._tx_thread_stack_build 0x00004838 0x48 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_stack_build.o) 0x00004838 _tx_thread_stack_build .text._tx_timer_interrupt 0x00004880 0xc0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_interrupt.o) 0x00004880 _tx_timer_interrupt .text._tx_semaphore_cleanup 0x00004940 0x80 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_cleanup.o) 0x00004940 _tx_semaphore_cleanup .text._tx_thread_time_slice 0x000049c0 0x74 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_time_slice.o) 0x000049c0 _tx_thread_time_slice .text._tx_timer_expiration_process 0x00004a34 0x104 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_expiration_process.o) 0x00004a34 _tx_timer_expiration_process .text.__errno 0x00004b38 0xc c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-errno.o) 0x00004b38 __errno .text.memcmp 0x00004b44 0x1e c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-memcmp.o) 0x00004b44 memcmp .text.memset 0x00004b62 0x10 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-memset.o) 0x00004b62 memset *fill* 0x00004b72 0x2 ff .text.srand 0x00004b74 0x48 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-rand.o) 0x00004b74 srand .text.malloc 0x00004bbc 0x10 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-malloc.o) 0x00004bbc malloc .text._malloc_r 0x00004bcc 0xb4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-nano-mallocr.o) 0x00004bcc _malloc_r .text._sbrk_r 0x00004c80 0x20 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-sbrkr.o) 0x00004c80 _sbrk_r .text.__malloc_lock 0x00004ca0 0x2 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-mlock.o) 0x00004ca0 __malloc_lock .text.__malloc_unlock 0x00004ca2 0x2 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-mlock.o) 0x00004ca2 __malloc_unlock *(.version) .version 0x00004ca4 0x60 ./synergy/ssp/src/bsp/mcu/all/bsp_common.o *(.init) .init 0x00004d04 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crti.o 0x00004d04 _init .init 0x00004d08 0x8 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtn.o *(.fini) .fini 0x00004d10 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crti.o 0x00004d10 _fini .fini 0x00004d14 0x8 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtn.o *crtbegin.o(.ctors) *crtbegin?.o(.ctors) *(EXCLUDE_FILE(*crtend.o *crtend?.o) .ctors) *(SORT_BY_NAME(.ctors.*)) *(.ctors) *crtbegin.o(.dtors) *crtbegin?.o(.dtors) *(EXCLUDE_FILE(*crtend.o *crtend?.o) .dtors) *(SORT_BY_NAME(.dtors.*)) *(.dtors) *(.rodata*) .rodata.g_ioport_on_ioport 0x00004d1c 0x3c ./synergy/ssp/src/driver/r_ioport/r_ioport.o 0x00004d1c g_ioport_on_ioport .rodata.g_vbatt_pins_input 0x00004d58 0x6 ./synergy/ssp/src/driver/r_ioport/r_ioport.o *fill* 0x00004d5e 0x2 ff .rodata.bit_count 0x00004d60 0x80 ./synergy/ssp/src/driver/r_fmi/r_fmi.o .rodata.bit_count_mask 0x00004de0 0x8 ./synergy/ssp/src/driver/r_fmi/r_fmi.o .rodata.g_fmi_on_fmi 0x00004de8 0x18 ./synergy/ssp/src/driver/r_fmi/r_fmi.o 0x00004de8 g_fmi_on_fmi .rodata.g_fmi_version 0x00004e00 0x4 ./synergy/ssp/src/driver/r_fmi/r_fmi.o .rodata.g_elc_on_elc 0x00004e04 0x1c ./synergy/ssp/src/driver/r_elc/r_elc.o 0x00004e04 g_elc_on_elc .rodata.s_elc_version 0x00004e20 0x4 ./synergy/ssp/src/driver/r_elc/r_elc.o .rodata.g_cgc_on_cgc 0x00004e24 0x6c ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x00004e24 g_cgc_on_cgc .rodata.g_cgc_version 0x00004e90 0x4 ./synergy/ssp/src/driver/r_cgc/r_cgc.o .rodata.g_pllccr2_div_setting 0x00004e94 0x8 ./synergy/ssp/src/driver/r_cgc/r_cgc.o .rodata.g_pllccr2_div_value 0x00004e9c 0x6 ./synergy/ssp/src/driver/r_cgc/r_cgc.o *fill* 0x00004ea2 0x2 ff .rodata.g_pllccr_div_setting 0x00004ea4 0x6 ./synergy/ssp/src/driver/r_cgc/r_cgc.o *fill* 0x00004eaa 0x2 ff .rodata.g_pllccr_div_value 0x00004eac 0x6 ./synergy/ssp/src/driver/r_cgc/r_cgc.o *fill* 0x00004eb2 0x2 ff .rodata.g_adc_on_adc 0x00004eb4 0x34 ./synergy/ssp/src/driver/r_adc/r_adc.o 0x00004eb4 g_adc_on_adc .rodata.s_adc_version 0x00004ee8 0x4 ./synergy/ssp/src/driver/r_adc/r_adc.o .rodata.g_cgc_feature 0x00004eec 0x2c ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o .rodata.g_fmi_data 0x00004f18 0x400 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_fmi_R7FS7G27G3A01CFB.o 0x00004f18 g_fmi_data .rodata.g_bsp_module_stop 0x00005318 0x46 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_module_stop.o *fill* 0x0000535e 0x2 ff .rodata.gp_mstp 0x00005360 0x10 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_module_stop.o .rodata.gp_vector_information 0x00005370 0x4 ./synergy/ssp/src/bsp/mcu/all/bsp_irq.o 0x00005370 gp_vector_information .rodata.g_prcr_masks 0x00005374 0x6 ./synergy/ssp/src/bsp/mcu/all/bsp_register_protection.o *fill* 0x0000537a 0x2 ff .rodata.g_elc_cfg 0x0000537c 0xc ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/system_S7G2.o .rodata.tx_application_define.str1.4 0x00005388 0x14 ./src/synergy_gen/main.o .rodata.g_adc0 0x0000539c 0x10 ./src/synergy_gen/new_thread0.o 0x0000539c g_adc0 .rodata.g_adc0_cfg 0x000053ac 0x24 ./src/synergy_gen/new_thread0.o 0x000053ac g_adc0_cfg .rodata.g_adc0_channel_cfg 0x000053d0 0x14 ./src/synergy_gen/new_thread0.o 0x000053d0 g_adc0_channel_cfg .rodata.new_thread0_create.str1.4 0x000053e4 0x4 ./src/synergy_gen/new_thread0.o .rodata.g_bsp_pin_cfg 0x000053e8 0x8 ./src/synergy_gen/pin_data.o 0x000053e8 g_bsp_pin_cfg .rodata.g_bsp_pin_cfg_data 0x000053f0 0x30 ./src/synergy_gen/pin_data.o 0x000053f0 g_bsp_pin_cfg_data .rodata.g_vfp_offset 0x00005420 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_schedule.o) 0x00005420 g_vfp_offset .rodata.__sf_fake_stderr 0x00005424 0x20 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) 0x00005424 __sf_fake_stderr .rodata.__sf_fake_stdin 0x00005444 0x20 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) 0x00005444 __sf_fake_stdin .rodata.__sf_fake_stdout 0x00005464 0x20 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) 0x00005464 __sf_fake_stdout 0x00005484 __usb_dev_descriptor_start_fs = . *(.usb_device_desc_fs*) 0x00005484 __usb_cfg_descriptor_start_fs = . *(.usb_config_desc_fs*) 0x00005484 __usb_interface_descriptor_start_fs = . *(.usb_interface_desc_fs*) 0x00005484 __usb_descriptor_end_fs = . 0x00005484 __usb_dev_descriptor_start_hs = . *(.usb_device_desc_hs*) 0x00005484 __usb_cfg_descriptor_start_hs = . *(.usb_config_desc_hs*) 0x00005484 __usb_interface_descriptor_start_hs = . *(.usb_interface_desc_hs*) 0x00005484 __usb_descriptor_end_hs = . *(.eh_frame*) .eh_frame 0x00005484 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtbegin.o .eh_frame 0x00005484 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtend.o 0x00005488 __ROM_End = . 0x00000044 __Vectors_Size = (__Vectors_End - __Vectors) 0x00000008 __Vector_Info_Size = (__Vector_Info_End - __Vector_Info_Start) 0x000001b0 __Lock_Lookup_Size = (__Lock_Lookup_End - __Lock_Lookup_Start) .glue_7 0x00005488 0x0 .glue_7 0x00005488 0x0 linker stubs .glue_7t 0x00005488 0x0 .glue_7t 0x00005488 0x0 linker stubs .vfp11_veneer 0x00005488 0x0 .vfp11_veneer 0x00005488 0x0 linker stubs .v4_bx 0x00005488 0x0 .v4_bx 0x00005488 0x0 linker stubs .iplt 0x00005488 0x0 .iplt 0x00005488 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtbegin.o .ARM.extab *(.ARM.extab* .gnu.linkonce.armextab.*) 0x00005488 __exidx_start = . .ARM.exidx *(.ARM.exidx* .gnu.linkonce.armexidx.*) 0x00005488 __exidx_end = . 0x00005488 __etext = . .ssp_dtc_vector_table 0x1ffe0000 0x0 0x1ffe0000 . = ORIGIN (RAM) *(.ssp_dtc_vector_table) .data 0x1ffe0000 0xdc load address 0x00005488 0x1ffe0000 __data_start__ = . *(vtable) *(.data*) .data._tx_thread_system_state 0x1ffe0000 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) 0x1ffe0000 _tx_thread_system_state .data._impure_ptr 0x1ffe0004 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-impure.o) 0x1ffe0004 _impure_ptr .data.impure_data 0x1ffe0008 0x60 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-impure.o) 0x1ffe0068 . = ALIGN (0x4) 0x1ffe0068 PROVIDE (__preinit_array_start, .) *(.preinit_array) 0x1ffe0068 PROVIDE (__preinit_array_end, .) 0x1ffe0068 . = ALIGN (0x4) 0x1ffe0068 PROVIDE (__init_array_start, .) *(SORT_BY_NAME(.init_array.*)) *(.init_array) .init_array 0x1ffe0068 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtbegin.o 0x1ffe006c PROVIDE (__init_array_end, .) 0x1ffe006c . = ALIGN (0x4) [!provide] PROVIDE (__fini_array_start, .) *(SORT_BY_NAME(.fini_array.*)) *(.fini_array) .fini_array 0x1ffe006c 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtbegin.o [!provide] PROVIDE (__fini_array_end, .) *(.jcr*) 0x1ffe0070 . = ALIGN (0x4) 0x1ffe0070 __Code_In_RAM_Start = . *(.code_in_ram*) 0x1ffe0070 __Code_In_RAM_End = . 0x1ffe0070 __Lock_Start = . *(SORT_BY_NAME(.hw_lock*)) .hw_lock.ADC_0U_0U 0x1ffe0070 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0070 g_hw_lock_ADC_0U_0U .hw_lock.ADC_0U_1U 0x1ffe0071 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0071 g_hw_lock_ADC_0U_1U .hw_lock.AGT_0U_0U 0x1ffe0072 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0072 g_hw_lock_AGT_0U_0U .hw_lock.AGT_0U_1U 0x1ffe0073 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0073 g_hw_lock_AGT_0U_1U .hw_lock.BSC_0U_1U 0x1ffe0074 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0074 g_hw_lock_BSC_0U_1U .hw_lock.CAC_0U_0U 0x1ffe0075 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0075 g_hw_lock_CAC_0U_0U .hw_lock.CAN_0U_0U 0x1ffe0076 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0076 g_hw_lock_CAN_0U_0U .hw_lock.CAN_0U_1U 0x1ffe0077 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0077 g_hw_lock_CAN_0U_1U .hw_lock.COMP_HS_0U_0U 0x1ffe0078 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0078 g_hw_lock_COMP_HS_0U_0U .hw_lock.COMP_HS_0U_1U 0x1ffe0079 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0079 g_hw_lock_COMP_HS_0U_1U .hw_lock.COMP_HS_0U_2U 0x1ffe007a 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe007a g_hw_lock_COMP_HS_0U_2U .hw_lock.COMP_HS_0U_3U 0x1ffe007b 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe007b g_hw_lock_COMP_HS_0U_3U .hw_lock.COMP_HS_0U_4U 0x1ffe007c 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe007c g_hw_lock_COMP_HS_0U_4U .hw_lock.COMP_HS_0U_5U 0x1ffe007d 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe007d g_hw_lock_COMP_HS_0U_5U .hw_lock.CRC_0U_0U 0x1ffe007e 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe007e g_hw_lock_CRC_0U_0U .hw_lock.CTSU_0U_0U 0x1ffe007f 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe007f g_hw_lock_CTSU_0U_0U .hw_lock.DAAD_0U_0U 0x1ffe0080 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0080 g_hw_lock_DAAD_0U_0U .hw_lock.DAC_0U_0U 0x1ffe0081 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0081 g_hw_lock_DAC_0U_0U .hw_lock.DAC_0U_1U 0x1ffe0082 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0082 g_hw_lock_DAC_0U_1U .hw_lock.DMAC_0U_0U 0x1ffe0083 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0083 g_hw_lock_DMAC_0U_0U .hw_lock.DMAC_0U_1U 0x1ffe0084 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0084 g_hw_lock_DMAC_0U_1U .hw_lock.DMAC_0U_2U 0x1ffe0085 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0085 g_hw_lock_DMAC_0U_2U .hw_lock.DMAC_0U_3U 0x1ffe0086 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0086 g_hw_lock_DMAC_0U_3U .hw_lock.DMAC_0U_4U 0x1ffe0087 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0087 g_hw_lock_DMAC_0U_4U .hw_lock.DMAC_0U_5U 0x1ffe0088 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0088 g_hw_lock_DMAC_0U_5U .hw_lock.DMAC_0U_6U 0x1ffe0089 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0089 g_hw_lock_DMAC_0U_6U .hw_lock.DMAC_0U_7U 0x1ffe008a 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe008a g_hw_lock_DMAC_0U_7U .hw_lock.DOC_0U_0U 0x1ffe008b 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe008b g_hw_lock_DOC_0U_0U .hw_lock.DRW_0U_0U 0x1ffe008c 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe008c g_hw_lock_DRW_0U_0U .hw_lock.DTC_0U_0U 0x1ffe008d 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe008d g_hw_lock_DTC_0U_0U .hw_lock.ELC_0U_0U 0x1ffe008e 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe008e g_hw_lock_ELC_0U_0U .hw_lock.EPTPC_0U_0U 0x1ffe008f 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe008f g_hw_lock_EPTPC_0U_0U .hw_lock.ETHER_0U_0U 0x1ffe0090 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0090 g_hw_lock_ETHER_0U_0U .hw_lock.ETHER_0U_1U 0x1ffe0091 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0091 g_hw_lock_ETHER_0U_1U .hw_lock.FCU_0U_0U 0x1ffe0092 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0092 g_hw_lock_FCU_0U_0U .hw_lock.GLCDC_0U_0U 0x1ffe0093 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0093 g_hw_lock_GLCDC_0U_0U .hw_lock.GPT_0U_0U 0x1ffe0094 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0094 g_hw_lock_GPT_0U_0U .hw_lock.GPT_0U_10U 0x1ffe0095 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0095 g_hw_lock_GPT_0U_10U .hw_lock.GPT_0U_11U 0x1ffe0096 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0096 g_hw_lock_GPT_0U_11U .hw_lock.GPT_0U_12U 0x1ffe0097 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0097 g_hw_lock_GPT_0U_12U .hw_lock.GPT_0U_13U 0x1ffe0098 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0098 g_hw_lock_GPT_0U_13U .hw_lock.GPT_0U_1U 0x1ffe0099 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe0099 g_hw_lock_GPT_0U_1U .hw_lock.GPT_0U_2U 0x1ffe009a 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe009a g_hw_lock_GPT_0U_2U .hw_lock.GPT_0U_3U 0x1ffe009b 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe009b g_hw_lock_GPT_0U_3U .hw_lock.GPT_0U_4U 0x1ffe009c 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe009c g_hw_lock_GPT_0U_4U .hw_lock.GPT_0U_5U 0x1ffe009d 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe009d g_hw_lock_GPT_0U_5U .hw_lock.GPT_0U_6U 0x1ffe009e 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe009e g_hw_lock_GPT_0U_6U .hw_lock.GPT_0U_7U 0x1ffe009f 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe009f g_hw_lock_GPT_0U_7U .hw_lock.GPT_0U_8U 0x1ffe00a0 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00a0 g_hw_lock_GPT_0U_8U .hw_lock.GPT_0U_9U 0x1ffe00a1 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00a1 g_hw_lock_GPT_0U_9U .hw_lock.ICU_0U_0U 0x1ffe00a2 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00a2 g_hw_lock_ICU_0U_0U .hw_lock.ICU_0U_10U 0x1ffe00a3 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00a3 g_hw_lock_ICU_0U_10U .hw_lock.ICU_0U_11U 0x1ffe00a4 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00a4 g_hw_lock_ICU_0U_11U .hw_lock.ICU_0U_12U 0x1ffe00a5 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00a5 g_hw_lock_ICU_0U_12U .hw_lock.ICU_0U_13U 0x1ffe00a6 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00a6 g_hw_lock_ICU_0U_13U .hw_lock.ICU_0U_14U 0x1ffe00a7 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00a7 g_hw_lock_ICU_0U_14U .hw_lock.ICU_0U_15U 0x1ffe00a8 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00a8 g_hw_lock_ICU_0U_15U .hw_lock.ICU_0U_1U 0x1ffe00a9 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00a9 g_hw_lock_ICU_0U_1U .hw_lock.ICU_0U_2U 0x1ffe00aa 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00aa g_hw_lock_ICU_0U_2U .hw_lock.ICU_0U_3U 0x1ffe00ab 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00ab g_hw_lock_ICU_0U_3U .hw_lock.ICU_0U_4U 0x1ffe00ac 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00ac g_hw_lock_ICU_0U_4U .hw_lock.ICU_0U_5U 0x1ffe00ad 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00ad g_hw_lock_ICU_0U_5U .hw_lock.ICU_0U_6U 0x1ffe00ae 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00ae g_hw_lock_ICU_0U_6U .hw_lock.ICU_0U_7U 0x1ffe00af 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00af g_hw_lock_ICU_0U_7U .hw_lock.ICU_0U_8U 0x1ffe00b0 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00b0 g_hw_lock_ICU_0U_8U .hw_lock.ICU_0U_9U 0x1ffe00b1 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00b1 g_hw_lock_ICU_0U_9U .hw_lock.IIC_0U_0U 0x1ffe00b2 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00b2 g_hw_lock_IIC_0U_0U .hw_lock.IIC_0U_1U 0x1ffe00b3 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00b3 g_hw_lock_IIC_0U_1U .hw_lock.IIC_0U_2U 0x1ffe00b4 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00b4 g_hw_lock_IIC_0U_2U .hw_lock.IRDA_0U_0U 0x1ffe00b5 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00b5 g_hw_lock_IRDA_0U_0U .hw_lock.IWDT_0U_0U 0x1ffe00b6 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00b6 g_hw_lock_IWDT_0U_0U .hw_lock.JPEG_0U_0U 0x1ffe00b7 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00b7 g_hw_lock_JPEG_0U_0U .hw_lock.KEY_0U_0U 0x1ffe00b8 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00b8 g_hw_lock_KEY_0U_0U .hw_lock.LPM_1U_0U 0x1ffe00b9 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00b9 g_hw_lock_LPM_1U_0U .hw_lock.LVD_0U_0U 0x1ffe00ba 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00ba g_hw_lock_LVD_0U_0U .hw_lock.LVD_0U_1U 0x1ffe00bb 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00bb g_hw_lock_LVD_0U_1U .hw_lock.MMF_0U_0U 0x1ffe00bc 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00bc g_hw_lock_MMF_0U_0U .hw_lock.MPU_0U_0U 0x1ffe00bd 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00bd g_hw_lock_MPU_0U_0U .hw_lock.OPS_0U_0U 0x1ffe00be 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00be g_hw_lock_OPS_0U_0U .hw_lock.PDC_0U_0U 0x1ffe00bf 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00bf g_hw_lock_PDC_0U_0U .hw_lock.POEG_0U_0U 0x1ffe00c0 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00c0 g_hw_lock_POEG_0U_0U .hw_lock.POEG_0U_1U 0x1ffe00c1 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00c1 g_hw_lock_POEG_0U_1U .hw_lock.POEG_0U_2U 0x1ffe00c2 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00c2 g_hw_lock_POEG_0U_2U .hw_lock.POEG_0U_3U 0x1ffe00c3 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00c3 g_hw_lock_POEG_0U_3U .hw_lock.QSPI_0U_0U 0x1ffe00c4 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00c4 g_hw_lock_QSPI_0U_0U .hw_lock.RTC_0U_0U 0x1ffe00c5 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00c5 g_hw_lock_RTC_0U_0U .hw_lock.SCE_0U_0U 0x1ffe00c6 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00c6 g_hw_lock_SCE_0U_0U .hw_lock.SCI_0U_0U 0x1ffe00c7 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00c7 g_hw_lock_SCI_0U_0U .hw_lock.SCI_0U_1U 0x1ffe00c8 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00c8 g_hw_lock_SCI_0U_1U .hw_lock.SCI_0U_2U 0x1ffe00c9 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00c9 g_hw_lock_SCI_0U_2U .hw_lock.SCI_0U_3U 0x1ffe00ca 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00ca g_hw_lock_SCI_0U_3U .hw_lock.SCI_0U_4U 0x1ffe00cb 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00cb g_hw_lock_SCI_0U_4U .hw_lock.SCI_0U_5U 0x1ffe00cc 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00cc g_hw_lock_SCI_0U_5U .hw_lock.SCI_0U_6U 0x1ffe00cd 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00cd g_hw_lock_SCI_0U_6U .hw_lock.SCI_0U_7U 0x1ffe00ce 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00ce g_hw_lock_SCI_0U_7U .hw_lock.SCI_0U_8U 0x1ffe00cf 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00cf g_hw_lock_SCI_0U_8U .hw_lock.SCI_0U_9U 0x1ffe00d0 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00d0 g_hw_lock_SCI_0U_9U .hw_lock.SDHIMMC_0U_0U 0x1ffe00d1 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00d1 g_hw_lock_SDHIMMC_0U_0U .hw_lock.SDHIMMC_0U_1U 0x1ffe00d2 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00d2 g_hw_lock_SDHIMMC_0U_1U .hw_lock.SPI_0U_0U 0x1ffe00d3 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00d3 g_hw_lock_SPI_0U_0U .hw_lock.SPI_0U_1U 0x1ffe00d4 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00d4 g_hw_lock_SPI_0U_1U .hw_lock.SRC_0U_0U 0x1ffe00d5 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00d5 g_hw_lock_SRC_0U_0U .hw_lock.SSI_0U_0U 0x1ffe00d6 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00d6 g_hw_lock_SSI_0U_0U .hw_lock.SSI_0U_1U 0x1ffe00d7 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00d7 g_hw_lock_SSI_0U_1U .hw_lock.TSN_0U_0U 0x1ffe00d8 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00d8 g_hw_lock_TSN_0U_0U .hw_lock.USB_0U_0U 0x1ffe00d9 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00d9 g_hw_lock_USB_0U_0U .hw_lock.USB_1U_0U 0x1ffe00da 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00da g_hw_lock_USB_1U_0U .hw_lock.WDT_0U_0U 0x1ffe00db 0x1 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x1ffe00db g_hw_lock_WDT_0U_0U 0x1ffe00dc __Lock_End = . 0x1ffe00dc . = ALIGN (0x4) 0x1ffe00dc __data_end__ = . 0x0000006c __Lock_Size = (__Lock_End - __Lock_Start) .igot.plt 0x1ffe00dc 0x0 load address 0x00005564 .igot.plt 0x1ffe00dc 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtbegin.o .qspi_flash 0x60000000 0x0 0x60000000 __qspi_flash_start__ = . *(.qspi_flash*) 0x60000000 __qspi_flash_end__ = . 0x00000000 __qspi_flash_code_size__ = (__qspi_flash_end__ - __qspi_flash_start__) 0x00005564 __qspi_flash_code_addr__ = (__etext + (__data_end__ - __data_start__)) .qspi_non_retentive 0x60000000 0x0 load address 0x00005564 0x60000000 __qspi_non_retentive_start__ = . *(.qspi_non_retentive*) 0x60000000 __qspi_non_retentive_end__ = . 0x00000000 __qspi_non_retentive_size__ = (__qspi_non_retentive_end__ - __qspi_non_retentive_start__) 0x04000000 __qspi_region_max_size__ = 0x4000000 0x60000000 __qspi_region_start_address__ = __qspi_flash_start__ 0x64000000 __qspi_region_end_address__ = (__qspi_flash_start__ + __qspi_region_max_size__) .noinit 0x1ffe00e0 0x40 0x1ffe00e0 . = ALIGN (0x4) 0x1ffe00e0 __noinit_start = . *(.noinit*) .noinit 0x1ffe00e0 0x14 ./synergy/ssp/src/driver/r_ioport/r_ioport.o .noinit 0x1ffe00f4 0x4 ./synergy/ssp/src/driver/r_fmi/r_fmi.o .noinit 0x1ffe00f8 0x20 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x1ffe00f8 gp_cgc_feature .noinit 0x1ffe0118 0x8 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/system_S7G2.o 0x1ffe0120 __noinit_end = . .bss 0x1ffe0120 0x34c 0x1ffe0120 . = ALIGN (0x4) 0x1ffe0120 __bss_start__ = . *(.bss*) .bss 0x1ffe0120 0x1c c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtbegin.o .bss.g_protect_pfswe_counter 0x1ffe013c 0x2 ./synergy/ssp/src/driver/r_ioport/r_ioport.o 0x1ffe013c g_protect_pfswe_counter *fill* 0x1ffe013e 0x2 .bss.gp_elc_reg 0x1ffe0140 0x4 ./synergy/ssp/src/driver/r_elc/r_elc.o .bss.g_adc_valid_channels 0x1ffe0144 0x8 ./synergy/ssp/src/driver/r_adc/r_adc.o .bss.g_bsp_group_irq_sources 0x1ffe014c 0x30 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_group_irq.o .bss.g_vector_information_size 0x1ffe017c 0x4 ./synergy/ssp/src/bsp/mcu/all/bsp_irq.o 0x1ffe017c g_vector_information_size .bss.g_bsp_lock_lookup_size 0x1ffe0180 0x4 ./synergy/ssp/src/bsp/mcu/all/bsp_locking.o .bss.gp_bsp_lock_lookup 0x1ffe0184 0x4 ./synergy/ssp/src/bsp/mcu/all/bsp_locking.o .bss.gp_bsp_locks 0x1ffe0188 0x4 ./synergy/ssp/src/bsp/mcu/all/bsp_locking.o .bss.g_protect_counters 0x1ffe018c 0x6 ./synergy/ssp/src/bsp/mcu/all/bsp_register_protection.o *fill* 0x1ffe0192 0x2 .bss.current_heap_end.23697 0x1ffe0194 0x4 ./synergy/ssp/src/bsp/mcu/all/bsp_sbrk.o .bss.SystemCoreClock 0x1ffe0198 0x4 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/system_S7G2.o 0x1ffe0198 SystemCoreClock .bss.gp_ctrl_ADC_1_SCAN_END 0x1ffe019c 0x4 ./src/synergy_gen/new_thread0.o .bss.Conversion_Complete 0x1ffe01a0 0x1 ./src/new_thread0_entry.o 0x1ffe01a0 Conversion_Complete *fill* 0x1ffe01a1 0x3 .bss.g_prcr 0x1ffe01a4 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_schedule.o) .bss.g_sbycr_ssby 0x1ffe01a8 0x4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_schedule.o) .bss.__malloc_free_list 0x1ffe01ac 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-nano-mallocr.o) 0x1ffe01ac __malloc_free_list .bss.__malloc_sbrk_start 0x1ffe01b0 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-nano-mallocr.o) 0x1ffe01b0 __malloc_sbrk_start *(COMMON) COMMON 0x1ffe01b4 0x24 ./src/synergy_gen/main.o 0x1ffe01b4 g_ssp_common_initialized 0x1ffe01b8 g_ssp_common_initialized_semaphore 0x1ffe01d4 g_ssp_common_thread_count COMMON 0x1ffe01d8 0xf0 ./src/synergy_gen/new_thread0.o 0x1ffe01d8 g_adc0_ctrl 0x1ffe0210 new_thread0 COMMON 0x1ffe02c8 0x18 ./src/new_thread0_entry.o 0x1ffe02c8 err 0x1ffe02cc ADC_Result COMMON 0x1ffe02e0 0x34 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) 0x1ffe02e0 _tx_event_flags_created_ptr 0x1ffe02e4 _tx_mutex_created_count 0x1ffe02e8 _tx_mutex_created_ptr 0x1ffe02ec _tx_queue_created_count 0x1ffe02f0 _tx_semaphore_created_ptr 0x1ffe02f4 _tx_byte_pool_created_ptr 0x1ffe02f8 _tx_initialize_unused_memory 0x1ffe02fc _tx_block_pool_created_count 0x1ffe0300 _tx_semaphore_created_count 0x1ffe0304 _tx_event_flags_created_count 0x1ffe0308 _tx_block_pool_created_ptr 0x1ffe030c _tx_queue_created_ptr 0x1ffe0310 _tx_byte_pool_created_count COMMON 0x1ffe0314 0xa8 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) 0x1ffe0314 _tx_thread_priority_list 0x1ffe0394 _tx_thread_mutex_release 0x1ffe0398 _tx_thread_priority_maps 0x1ffe039c _tx_thread_created_ptr 0x1ffe03a0 _tx_build_options 0x1ffe03a4 _tx_thread_created_count 0x1ffe03a8 _tx_thread_system_stack_ptr 0x1ffe03ac _tx_thread_preempt_disable 0x1ffe03b0 _tx_thread_current_ptr 0x1ffe03b4 _tx_thread_execute_ptr 0x1ffe03b8 _tx_thread_highest_priority COMMON 0x1ffe03bc 0xac F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) 0x1ffe03bc _tx_timer_current_ptr 0x1ffe03c0 _tx_timer_list 0x1ffe0440 _tx_timer_expired 0x1ffe0444 _tx_timer_time_slice 0x1ffe0448 _tx_timer_list_end 0x1ffe044c _tx_timer_processing_active 0x1ffe0450 _tx_timer_expired_timer_ptr 0x1ffe0454 _tx_timer_list_start 0x1ffe0458 _tx_timer_created_ptr 0x1ffe045c _tx_timer_created_count 0x1ffe0460 _tx_timer_expired_time_slice 0x1ffe0464 _tx_timer_system_clock COMMON 0x1ffe0468 0x4 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-reent.o) 0x1ffe0468 errno 0x1ffe046c . = ALIGN (0x4) 0x1ffe046c __bss_end__ = . .heap 0x1ffe0470 0x1000 0x1ffe0470 . = ALIGN (0x8) *(.heap_d1) 0x1ffe0470 . = ALIGN (0x8) 0x1ffe0470 __HeapBase = . 0x1ffe0470 __end__ = . 0x1ffe0470 end = __end__ *(.heap*) .heap 0x1ffe0470 0x1000 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/startup_S7G2.o 0x1ffe1470 __HeapLimit = . .stack_dummy 0x1ffe1470 0xc00 0x1ffe1470 . = ALIGN (0x8) 0x1ffe1470 __StackLimit = . *(.stack) .stack 0x1ffe1470 0x800 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/startup_S7G2.o 0x1ffe1c70 __StackTop = . *(.stack*) .stack.new_thread0 0x1ffe1c70 0x400 ./src/synergy_gen/new_thread0.o 0x1ffe2070 __StackTopAll = . [!provide] PROVIDE (__stack, __StackTopAll) 0x1ffe2070 __RAM_segment_used_end__ = ALIGN (__StackTopAll, 0x4) .dflash 0x40100000 0x0 0x40100000 __Data_Flash_Start = . *(.dflash*) 0x40100000 __Data_Flash_End = . .sdram 0x90000000 0x0 0x90000000 __SDRAM_Start = . *(.sdram*) *(.frame*) 0x90000000 __SDRAM_End = . .id_code_1 0x40120050 0x10 0x40120050 __ID_Codes_Start = . *(.id_code_1*) .id_code_1 0x40120050 0x10 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_rom_registers.o 0x40120060 __ID_Codes_End = . OUTPUT(sample.elf elf32-littlearm) .rel.dyn 0x40120060 0x0 .rel.iplt 0x40120060 0x0 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtbegin.o .ARM.attributes 0x00000000 0x30 .ARM.attributes 0x00000000 0x22 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crti.o .ARM.attributes 0x00000022 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtbegin.o .ARM.attributes 0x00000056 0x39 ./synergy/ssp/src/driver/r_ioport/r_ioport.o .ARM.attributes 0x0000008f 0x39 ./synergy/ssp/src/driver/r_fmi/r_fmi.o .ARM.attributes 0x000000c8 0x39 ./synergy/ssp/src/driver/r_elc/r_elc.o .ARM.attributes 0x00000101 0x39 ./synergy/ssp/src/driver/r_cgc/r_cgc.o .ARM.attributes 0x0000013a 0x39 ./synergy/ssp/src/driver/r_adc/r_adc.o .ARM.attributes 0x00000173 0x39 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_cache.o .ARM.attributes 0x000001ac 0x39 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_clocks.o .ARM.attributes 0x000001e5 0x39 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o .ARM.attributes 0x0000021e 0x39 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_fmi_R7FS7G27G3A01CFB.o .ARM.attributes 0x00000257 0x39 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_group_irq.o .ARM.attributes 0x00000290 0x39 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o .ARM.attributes 0x000002c9 0x39 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_module_stop.o .ARM.attributes 0x00000302 0x39 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_rom_registers.o .ARM.attributes 0x0000033b 0x39 ./synergy/ssp/src/bsp/mcu/all/bsp_common.o .ARM.attributes 0x00000374 0x39 ./synergy/ssp/src/bsp/mcu/all/bsp_delay.o .ARM.attributes 0x000003ad 0x39 ./synergy/ssp/src/bsp/mcu/all/bsp_irq.o .ARM.attributes 0x000003e6 0x39 ./synergy/ssp/src/bsp/mcu/all/bsp_locking.o .ARM.attributes 0x0000041f 0x39 ./synergy/ssp/src/bsp/mcu/all/bsp_register_protection.o .ARM.attributes 0x00000458 0x39 ./synergy/ssp/src/bsp/mcu/all/bsp_sbrk.o .ARM.attributes 0x00000491 0x39 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/startup_S7G2.o .ARM.attributes 0x000004ca 0x39 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/system_S7G2.o .ARM.attributes 0x00000503 0x39 ./src/synergy_gen/common_data.o .ARM.attributes 0x0000053c 0x39 ./src/synergy_gen/hal_data.o .ARM.attributes 0x00000575 0x39 ./src/synergy_gen/main.o .ARM.attributes 0x000005ae 0x39 ./src/synergy_gen/new_thread0.o .ARM.attributes 0x000005e7 0x39 ./src/synergy_gen/pin_data.o .ARM.attributes 0x00000620 0x39 ./src/new_thread0_entry.o .ARM.attributes 0x00000659 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_create.o) .ARM.attributes 0x00000692 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_get.o) .ARM.attributes 0x000006cb 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_put.o) .ARM.attributes 0x00000704 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_thread_create.o) .ARM.attributes 0x0000073d 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) .ARM.attributes 0x00000776 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_kernel_enter.o) .ARM.attributes 0x000007af 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_end.o) .ARM.attributes 0x000007e8 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_start.o) .ARM.attributes 0x00000821 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_create.o) .ARM.attributes 0x0000085a 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_get.o) .ARM.attributes 0x00000893 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_put.o) .ARM.attributes 0x000008cc 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_create.o) .ARM.attributes 0x00000905 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) .ARM.attributes 0x0000093e 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_shell_entry.o) .ARM.attributes 0x00000977 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_sleep.o) .ARM.attributes 0x000009b0 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_preempt_check.o) .ARM.attributes 0x000009e9 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_resume.o) .ARM.attributes 0x00000a22 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_suspend.o) .ARM.attributes 0x00000a5b 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_timeout.o) .ARM.attributes 0x00000a94 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) .ARM.attributes 0x00000acd 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_activate.o) .ARM.attributes 0x00000b06 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_deactivate.o) .ARM.attributes 0x00000b3f 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_low_level.o) .ARM.attributes 0x00000b78 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_schedule.o) .ARM.attributes 0x00000bb1 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_stack_build.o) .ARM.attributes 0x00000bea 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_interrupt.o) .ARM.attributes 0x00000c23 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_cleanup.o) .ARM.attributes 0x00000c5c 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_time_slice.o) .ARM.attributes 0x00000c95 0x39 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_expiration_process.o) .ARM.attributes 0x00000cce 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-errno.o) .ARM.attributes 0x00000d02 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-impure.o) .ARM.attributes 0x00000d36 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-memcmp.o) .ARM.attributes 0x00000d6a 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-memset.o) .ARM.attributes 0x00000d9e 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-rand.o) .ARM.attributes 0x00000dd2 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-malloc.o) .ARM.attributes 0x00000e06 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-nano-mallocr.o) .ARM.attributes 0x00000e3a 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-sbrkr.o) .ARM.attributes 0x00000e6e 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-mlock.o) .ARM.attributes 0x00000ea2 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-reent.o) .ARM.attributes 0x00000ed6 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o) .ARM.attributes 0x00000f0a 0x34 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtend.o .ARM.attributes 0x00000f3e 0x22 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/thumb/v7e-m/fpv4-sp/hard/crtn.o .comment 0x00000000 0x7e .comment 0x00000000 0x7e ./synergy/ssp/src/driver/r_ioport/r_ioport.o 0x7f (size before relaxing) .comment 0x0000007e 0x7f ./synergy/ssp/src/driver/r_fmi/r_fmi.o .comment 0x0000007e 0x7f ./synergy/ssp/src/driver/r_elc/r_elc.o .comment 0x0000007e 0x7f ./synergy/ssp/src/driver/r_cgc/r_cgc.o .comment 0x0000007e 0x7f ./synergy/ssp/src/driver/r_adc/r_adc.o .comment 0x0000007e 0x7f ./synergy/ssp/src/bsp/mcu/s7g2/bsp_cache.o .comment 0x0000007e 0x7f ./synergy/ssp/src/bsp/mcu/s7g2/bsp_clocks.o .comment 0x0000007e 0x7f ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o .comment 0x0000007e 0x7f ./synergy/ssp/src/bsp/mcu/s7g2/bsp_fmi_R7FS7G27G3A01CFB.o .comment 0x0000007e 0x7f ./synergy/ssp/src/bsp/mcu/s7g2/bsp_group_irq.o .comment 0x0000007e 0x7f ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o .comment 0x0000007e 0x7f ./synergy/ssp/src/bsp/mcu/s7g2/bsp_module_stop.o .comment 0x0000007e 0x7f ./synergy/ssp/src/bsp/mcu/s7g2/bsp_rom_registers.o .comment 0x0000007e 0x7f ./synergy/ssp/src/bsp/mcu/all/bsp_common.o .comment 0x0000007e 0x7f ./synergy/ssp/src/bsp/mcu/all/bsp_delay.o .comment 0x0000007e 0x7f ./synergy/ssp/src/bsp/mcu/all/bsp_irq.o .comment 0x0000007e 0x7f ./synergy/ssp/src/bsp/mcu/all/bsp_locking.o .comment 0x0000007e 0x7f ./synergy/ssp/src/bsp/mcu/all/bsp_register_protection.o .comment 0x0000007e 0x7f ./synergy/ssp/src/bsp/mcu/all/bsp_sbrk.o .comment 0x0000007e 0x7f ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/startup_S7G2.o .comment 0x0000007e 0x7f ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/system_S7G2.o .comment 0x0000007e 0x7f ./src/synergy_gen/common_data.o .comment 0x0000007e 0x7f ./src/synergy_gen/hal_data.o .comment 0x0000007e 0x7f ./src/synergy_gen/main.o .comment 0x0000007e 0x7f ./src/synergy_gen/new_thread0.o .comment 0x0000007e 0x7f ./src/synergy_gen/pin_data.o .comment 0x0000007e 0x7f ./src/new_thread0_entry.o .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_create.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_get.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_put.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_thread_create.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_kernel_enter.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_end.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_start.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_create.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_get.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_put.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_create.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_shell_entry.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_sleep.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_preempt_check.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_resume.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_suspend.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_timeout.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_activate.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_deactivate.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_low_level.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_schedule.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_stack_build.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_interrupt.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_cleanup.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_time_slice.o) .comment 0x0000007e 0x7f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_expiration_process.o) .debug_info 0x00000000 0x7c16d .debug_info 0x00000000 0xf8b2 ./synergy/ssp/src/driver/r_ioport/r_ioport.o .debug_info 0x0000f8b2 0x2fdb ./synergy/ssp/src/driver/r_fmi/r_fmi.o .debug_info 0x0001288d 0x22d6 ./synergy/ssp/src/driver/r_elc/r_elc.o .debug_info 0x00014b63 0x7f7c ./synergy/ssp/src/driver/r_cgc/r_cgc.o .debug_info 0x0001cadf 0x7d00 ./synergy/ssp/src/driver/r_adc/r_adc.o .debug_info 0x000247df 0x1b68 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_cache.o .debug_info 0x00026347 0x2932 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_clocks.o .debug_info 0x00028c79 0x2899 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o .debug_info 0x0002b512 0x1ab8 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_fmi_R7FS7G27G3A01CFB.o .debug_info 0x0002cfca 0x2710 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_group_irq.o .debug_info 0x0002f6da 0x29e7 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o .debug_info 0x000320c1 0x3f2a ./synergy/ssp/src/bsp/mcu/s7g2/bsp_module_stop.o .debug_info 0x00035feb 0x1ae2 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_rom_registers.o .debug_info 0x00037acd 0x1bdd ./synergy/ssp/src/bsp/mcu/all/bsp_common.o .debug_info 0x000396aa 0x1a71 ./synergy/ssp/src/bsp/mcu/all/bsp_delay.o .debug_info 0x0003b11b 0x24b6 ./synergy/ssp/src/bsp/mcu/all/bsp_irq.o .debug_info 0x0003d5d1 0x1ee8 ./synergy/ssp/src/bsp/mcu/all/bsp_locking.o .debug_info 0x0003f4b9 0x3907 ./synergy/ssp/src/bsp/mcu/all/bsp_register_protection.o .debug_info 0x00042dc0 0x2223 ./synergy/ssp/src/bsp/mcu/all/bsp_sbrk.o .debug_info 0x00044fe3 0x1b6b ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/startup_S7G2.o .debug_info 0x00046b4e 0x3ea7 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/system_S7G2.o .debug_info 0x0004a9f5 0x2d6e ./src/synergy_gen/common_data.o .debug_info 0x0004d763 0x2bfd ./src/synergy_gen/hal_data.o .debug_info 0x00050360 0x294e ./src/synergy_gen/main.o .debug_info 0x00052cae 0x4840 ./src/synergy_gen/new_thread0.o .debug_info 0x000574ee 0x2544 ./src/synergy_gen/pin_data.o .debug_info 0x00059a32 0x4028 ./src/new_thread0_entry.o .debug_info 0x0005da5a 0x1123 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_create.o) .debug_info 0x0005eb7d 0xfd5 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_get.o) .debug_info 0x0005fb52 0xdaf F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_put.o) .debug_info 0x00060901 0x1154 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_thread_create.o) .debug_info 0x00061a55 0x1376 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) .debug_info 0x00062dcb 0xf14 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_kernel_enter.o) .debug_info 0x00063cdf 0x94a F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_end.o) .debug_info 0x00064629 0x94a F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_start.o) .debug_info 0x00064f73 0xe4a F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_create.o) .debug_info 0x00065dbd 0xf84 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_get.o) .debug_info 0x00066d41 0xf4d F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_put.o) .debug_info 0x00067c8e 0x109a F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_create.o) .debug_info 0x00068d28 0xeb8 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) .debug_info 0x00069be0 0xe63 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_shell_entry.o) .debug_info 0x0006aa43 0x1006 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_sleep.o) .debug_info 0x0006ba49 0x109e F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_preempt_check.o) .debug_info 0x0006cae7 0x12a3 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_resume.o) .debug_info 0x0006dd8a 0x12e3 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_suspend.o) .debug_info 0x0006f06d 0xfbd F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_timeout.o) .debug_info 0x0007002a 0xf81 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) .debug_info 0x00070fab 0xb53 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_activate.o) .debug_info 0x00071afe 0xb26 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_deactivate.o) .debug_info 0x00072624 0x14a8 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_low_level.o) .debug_info 0x00073acc 0x391c F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_schedule.o) .debug_info 0x000773e8 0xdc6 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_stack_build.o) .debug_info 0x000781ae 0x109f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_interrupt.o) .debug_info 0x0007924d 0xf8c F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_cleanup.o) .debug_info 0x0007a1d9 0xf45 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_time_slice.o) .debug_info 0x0007b11e 0x104f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_expiration_process.o) .debug_abbrev 0x00000000 0x9630 .debug_abbrev 0x00000000 0x4ef ./synergy/ssp/src/driver/r_ioport/r_ioport.o .debug_abbrev 0x000004ef 0x439 ./synergy/ssp/src/driver/r_fmi/r_fmi.o .debug_abbrev 0x00000928 0x33b ./synergy/ssp/src/driver/r_elc/r_elc.o .debug_abbrev 0x00000c63 0x62e ./synergy/ssp/src/driver/r_cgc/r_cgc.o .debug_abbrev 0x00001291 0x5a6 ./synergy/ssp/src/driver/r_adc/r_adc.o .debug_abbrev 0x00001837 0x244 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_cache.o .debug_abbrev 0x00001a7b 0x3a0 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_clocks.o .debug_abbrev 0x00001e1b 0x200 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o .debug_abbrev 0x0000201b 0x1c5 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_fmi_R7FS7G27G3A01CFB.o .debug_abbrev 0x000021e0 0x333 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_group_irq.o .debug_abbrev 0x00002513 0x200 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o .debug_abbrev 0x00002713 0x36b ./synergy/ssp/src/bsp/mcu/s7g2/bsp_module_stop.o .debug_abbrev 0x00002a7e 0x1c5 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_rom_registers.o .debug_abbrev 0x00002c43 0x253 ./synergy/ssp/src/bsp/mcu/all/bsp_common.o .debug_abbrev 0x00002e96 0x25f ./synergy/ssp/src/bsp/mcu/all/bsp_delay.o .debug_abbrev 0x000030f5 0x296 ./synergy/ssp/src/bsp/mcu/all/bsp_irq.o .debug_abbrev 0x0000338b 0x3ad ./synergy/ssp/src/bsp/mcu/all/bsp_locking.o .debug_abbrev 0x00003738 0x2ed ./synergy/ssp/src/bsp/mcu/all/bsp_register_protection.o .debug_abbrev 0x00003a25 0x2c2 ./synergy/ssp/src/bsp/mcu/all/bsp_sbrk.o .debug_abbrev 0x00003ce7 0x23b ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/startup_S7G2.o .debug_abbrev 0x00003f22 0x42a ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/system_S7G2.o .debug_abbrev 0x0000434c 0x21e ./src/synergy_gen/common_data.o .debug_abbrev 0x0000456a 0x232 ./src/synergy_gen/hal_data.o .debug_abbrev 0x0000479c 0x336 ./src/synergy_gen/main.o .debug_abbrev 0x00004ad2 0x376 ./src/synergy_gen/new_thread0.o .debug_abbrev 0x00004e48 0x1f8 ./src/synergy_gen/pin_data.o .debug_abbrev 0x00005040 0x305 ./src/new_thread0_entry.o .debug_abbrev 0x00005345 0x28d F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_create.o) .debug_abbrev 0x000055d2 0x235 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_get.o) .debug_abbrev 0x00005807 0x1f2 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_put.o) .debug_abbrev 0x000059f9 0x29e F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_thread_create.o) .debug_abbrev 0x00005c97 0x200 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) .debug_abbrev 0x00005e97 0x1f0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_kernel_enter.o) .debug_abbrev 0x00006087 0x1c2 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_end.o) .debug_abbrev 0x00006249 0x1c2 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_start.o) .debug_abbrev 0x0000640b 0x259 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_create.o) .debug_abbrev 0x00006664 0x285 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_get.o) .debug_abbrev 0x000068e9 0x277 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_put.o) .debug_abbrev 0x00006b60 0x2c4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_create.o) .debug_abbrev 0x00006e24 0x1fd F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) .debug_abbrev 0x00007021 0x26d F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_shell_entry.o) .debug_abbrev 0x0000728e 0x27b F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_sleep.o) .debug_abbrev 0x00007509 0x286 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_preempt_check.o) .debug_abbrev 0x0000778f 0x2dc F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_resume.o) .debug_abbrev 0x00007a6b 0x2eb F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_suspend.o) .debug_abbrev 0x00007d56 0x283 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_timeout.o) .debug_abbrev 0x00007fd9 0x1ec F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) .debug_abbrev 0x000081c5 0x1d1 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_activate.o) .debug_abbrev 0x00008396 0x1d1 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_deactivate.o) .debug_abbrev 0x00008567 0x29b F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_low_level.o) .debug_abbrev 0x00008802 0x327 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_schedule.o) .debug_abbrev 0x00008b29 0x1c2 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_stack_build.o) .debug_abbrev 0x00008ceb 0x1f1 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_interrupt.o) .debug_abbrev 0x00008edc 0x285 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_cleanup.o) .debug_abbrev 0x00009161 0x248 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_time_slice.o) .debug_abbrev 0x000093a9 0x287 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_expiration_process.o) .debug_loc 0x00000000 0x992b .debug_loc 0x00000000 0x15d9 ./synergy/ssp/src/driver/r_ioport/r_ioport.o .debug_loc 0x000015d9 0xeae ./synergy/ssp/src/driver/r_fmi/r_fmi.o .debug_loc 0x00002487 0x29e ./synergy/ssp/src/driver/r_elc/r_elc.o .debug_loc 0x00002725 0x2ace ./synergy/ssp/src/driver/r_cgc/r_cgc.o .debug_loc 0x000051f3 0x20ca ./synergy/ssp/src/driver/r_adc/r_adc.o .debug_loc 0x000072bd 0xbf ./synergy/ssp/src/bsp/mcu/s7g2/bsp_cache.o .debug_loc 0x0000737c 0x2e9 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_clocks.o .debug_loc 0x00007665 0x17f ./synergy/ssp/src/bsp/mcu/s7g2/bsp_group_irq.o .debug_loc 0x000077e4 0x390 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_module_stop.o .debug_loc 0x00007b74 0x74 ./synergy/ssp/src/bsp/mcu/all/bsp_common.o .debug_loc 0x00007be8 0x140 ./synergy/ssp/src/bsp/mcu/all/bsp_delay.o .debug_loc 0x00007d28 0x40 ./synergy/ssp/src/bsp/mcu/all/bsp_irq.o .debug_loc 0x00007d68 0x23e ./synergy/ssp/src/bsp/mcu/all/bsp_locking.o .debug_loc 0x00007fa6 0xe5 ./synergy/ssp/src/bsp/mcu/all/bsp_register_protection.o .debug_loc 0x0000808b 0xcc ./synergy/ssp/src/bsp/mcu/all/bsp_sbrk.o .debug_loc 0x00008157 0x9c ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/system_S7G2.o .debug_loc 0x000081f3 0x68 ./src/synergy_gen/main.o .debug_loc 0x0000825b 0x34 ./src/synergy_gen/new_thread0.o .debug_loc 0x0000828f 0x2c ./src/new_thread0_entry.o .debug_loc 0x000082bb 0x1ce F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_create.o) .debug_loc 0x00008489 0x9f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_get.o) .debug_loc 0x00008528 0x3a F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_put.o) .debug_loc 0x00008562 0x38d F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_thread_create.o) .debug_loc 0x000088ef 0xec F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_create.o) .debug_loc 0x000089db 0x16a F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_get.o) .debug_loc 0x00008b45 0xd9 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_put.o) .debug_loc 0x00008c1e 0x27a F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_create.o) .debug_loc 0x00008e98 0x1e F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_shell_entry.o) .debug_loc 0x00008eb6 0xdc F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_sleep.o) .debug_loc 0x00008f92 0x51 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_preempt_check.o) .debug_loc 0x00008fe3 0x123 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_resume.o) .debug_loc 0x00009106 0x254 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_suspend.o) .debug_loc 0x0000935a 0xff F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_timeout.o) .debug_loc 0x00009459 0xa0 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_activate.o) .debug_loc 0x000094f9 0x67 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_deactivate.o) .debug_loc 0x00009560 0xdc F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_low_level.o) .debug_loc 0x0000963c 0x157 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_cleanup.o) .debug_loc 0x00009793 0x5a F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_time_slice.o) .debug_loc 0x000097ed 0x13e F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_expiration_process.o) .debug_aranges 0x00000000 0xac8 .debug_aranges 0x00000000 0xa0 ./synergy/ssp/src/driver/r_ioport/r_ioport.o .debug_aranges 0x000000a0 0x48 ./synergy/ssp/src/driver/r_fmi/r_fmi.o .debug_aranges 0x000000e8 0x50 ./synergy/ssp/src/driver/r_elc/r_elc.o .debug_aranges 0x00000138 0x138 ./synergy/ssp/src/driver/r_cgc/r_cgc.o .debug_aranges 0x00000270 0xa8 ./synergy/ssp/src/driver/r_adc/r_adc.o .debug_aranges 0x00000318 0x28 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_cache.o .debug_aranges 0x00000340 0x30 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_clocks.o .debug_aranges 0x00000370 0x88 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o .debug_aranges 0x000003f8 0x18 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_fmi_R7FS7G27G3A01CFB.o .debug_aranges 0x00000410 0x38 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_group_irq.o .debug_aranges 0x00000448 0x18 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o .debug_aranges 0x00000460 0x48 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_module_stop.o .debug_aranges 0x000004a8 0x18 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_rom_registers.o .debug_aranges 0x000004c0 0x30 ./synergy/ssp/src/bsp/mcu/all/bsp_common.o .debug_aranges 0x000004f0 0x28 ./synergy/ssp/src/bsp/mcu/all/bsp_delay.o .debug_aranges 0x00000518 0x28 ./synergy/ssp/src/bsp/mcu/all/bsp_irq.o .debug_aranges 0x00000540 0x40 ./synergy/ssp/src/bsp/mcu/all/bsp_locking.o .debug_aranges 0x00000580 0x30 ./synergy/ssp/src/bsp/mcu/all/bsp_register_protection.o .debug_aranges 0x000005b0 0x20 ./synergy/ssp/src/bsp/mcu/all/bsp_sbrk.o .debug_aranges 0x000005d0 0x28 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/startup_S7G2.o .debug_aranges 0x000005f8 0x30 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/system_S7G2.o .debug_aranges 0x00000628 0x20 ./src/synergy_gen/common_data.o .debug_aranges 0x00000648 0x20 ./src/synergy_gen/hal_data.o .debug_aranges 0x00000668 0x40 ./src/synergy_gen/main.o .debug_aranges 0x000006a8 0x28 ./src/synergy_gen/new_thread0.o .debug_aranges 0x000006d0 0x18 ./src/synergy_gen/pin_data.o .debug_aranges 0x000006e8 0x28 ./src/new_thread0_entry.o .debug_aranges 0x00000710 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_create.o) .debug_aranges 0x00000730 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_get.o) .debug_aranges 0x00000750 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_put.o) .debug_aranges 0x00000770 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_thread_create.o) .debug_aranges 0x00000790 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) .debug_aranges 0x000007b0 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_kernel_enter.o) .debug_aranges 0x000007d0 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_end.o) .debug_aranges 0x000007f0 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_start.o) .debug_aranges 0x00000810 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_create.o) .debug_aranges 0x00000830 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_get.o) .debug_aranges 0x00000850 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_put.o) .debug_aranges 0x00000870 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_create.o) .debug_aranges 0x00000890 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) .debug_aranges 0x000008b0 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_shell_entry.o) .debug_aranges 0x000008d0 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_sleep.o) .debug_aranges 0x000008f0 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_preempt_check.o) .debug_aranges 0x00000910 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_resume.o) .debug_aranges 0x00000930 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_suspend.o) .debug_aranges 0x00000950 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_timeout.o) .debug_aranges 0x00000970 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) .debug_aranges 0x00000990 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_activate.o) .debug_aranges 0x000009b0 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_deactivate.o) .debug_aranges 0x000009d0 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_low_level.o) .debug_aranges 0x000009f0 0x38 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_schedule.o) .debug_aranges 0x00000a28 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_stack_build.o) .debug_aranges 0x00000a48 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_interrupt.o) .debug_aranges 0x00000a68 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_cleanup.o) .debug_aranges 0x00000a88 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_time_slice.o) .debug_aranges 0x00000aa8 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_expiration_process.o) .debug_ranges 0x00000000 0x1e38 .debug_ranges 0x00000000 0x468 ./synergy/ssp/src/driver/r_ioport/r_ioport.o .debug_ranges 0x00000468 0x170 ./synergy/ssp/src/driver/r_fmi/r_fmi.o .debug_ranges 0x000005d8 0xf0 ./synergy/ssp/src/driver/r_elc/r_elc.o .debug_ranges 0x000006c8 0xa18 ./synergy/ssp/src/driver/r_cgc/r_cgc.o .debug_ranges 0x000010e0 0x688 ./synergy/ssp/src/driver/r_adc/r_adc.o .debug_ranges 0x00001768 0x18 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_cache.o .debug_ranges 0x00001780 0xd8 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_clocks.o .debug_ranges 0x00001858 0x78 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o .debug_ranges 0x000018d0 0x28 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_group_irq.o .debug_ranges 0x000018f8 0x38 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_module_stop.o .debug_ranges 0x00001930 0x20 ./synergy/ssp/src/bsp/mcu/all/bsp_common.o .debug_ranges 0x00001950 0x18 ./synergy/ssp/src/bsp/mcu/all/bsp_delay.o .debug_ranges 0x00001968 0x18 ./synergy/ssp/src/bsp/mcu/all/bsp_irq.o .debug_ranges 0x00001980 0xe8 ./synergy/ssp/src/bsp/mcu/all/bsp_locking.o .debug_ranges 0x00001a68 0x38 ./synergy/ssp/src/bsp/mcu/all/bsp_register_protection.o .debug_ranges 0x00001aa0 0x10 ./synergy/ssp/src/bsp/mcu/all/bsp_sbrk.o .debug_ranges 0x00001ab0 0x18 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/startup_S7G2.o .debug_ranges 0x00001ac8 0x68 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/system_S7G2.o .debug_ranges 0x00001b30 0x10 ./src/synergy_gen/common_data.o .debug_ranges 0x00001b40 0x10 ./src/synergy_gen/hal_data.o .debug_ranges 0x00001b50 0x30 ./src/synergy_gen/main.o .debug_ranges 0x00001b80 0x18 ./src/synergy_gen/new_thread0.o .debug_ranges 0x00001b98 0x18 ./src/new_thread0_entry.o .debug_ranges 0x00001bb0 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_create.o) .debug_ranges 0x00001bc0 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_get.o) .debug_ranges 0x00001bd0 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_put.o) .debug_ranges 0x00001be0 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_thread_create.o) .debug_ranges 0x00001bf0 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) .debug_ranges 0x00001c00 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_kernel_enter.o) .debug_ranges 0x00001c10 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_end.o) .debug_ranges 0x00001c20 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_start.o) .debug_ranges 0x00001c30 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_create.o) .debug_ranges 0x00001c40 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_get.o) .debug_ranges 0x00001c50 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_put.o) .debug_ranges 0x00001c60 0x28 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_create.o) .debug_ranges 0x00001c88 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) .debug_ranges 0x00001c98 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_shell_entry.o) .debug_ranges 0x00001ca8 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_sleep.o) .debug_ranges 0x00001cb8 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_preempt_check.o) .debug_ranges 0x00001cc8 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_resume.o) .debug_ranges 0x00001cd8 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_suspend.o) .debug_ranges 0x00001ce8 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_timeout.o) .debug_ranges 0x00001cf8 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) .debug_ranges 0x00001d08 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_activate.o) .debug_ranges 0x00001d18 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_deactivate.o) .debug_ranges 0x00001d28 0x60 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_low_level.o) .debug_ranges 0x00001d88 0x28 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_schedule.o) .debug_ranges 0x00001db0 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_stack_build.o) .debug_ranges 0x00001dc0 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_interrupt.o) .debug_ranges 0x00001dd0 0x10 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_cleanup.o) .debug_ranges 0x00001de0 0x30 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_time_slice.o) .debug_ranges 0x00001e10 0x28 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_expiration_process.o) .debug_line 0x00000000 0xe01e .debug_line 0x00000000 0x930 ./synergy/ssp/src/driver/r_ioport/r_ioport.o .debug_line 0x00000930 0x747 ./synergy/ssp/src/driver/r_fmi/r_fmi.o .debug_line 0x00001077 0x52b ./synergy/ssp/src/driver/r_elc/r_elc.o .debug_line 0x000015a2 0x122f ./synergy/ssp/src/driver/r_cgc/r_cgc.o .debug_line 0x000027d1 0xd7a ./synergy/ssp/src/driver/r_adc/r_adc.o .debug_line 0x0000354b 0x382 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_cache.o .debug_line 0x000038cd 0x4b2 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_clocks.o .debug_line 0x00003d7f 0x50a ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o .debug_line 0x00004289 0x3b8 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_fmi_R7FS7G27G3A01CFB.o .debug_line 0x00004641 0x484 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_group_irq.o .debug_line 0x00004ac5 0x391 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o .debug_line 0x00004e56 0x47a ./synergy/ssp/src/bsp/mcu/s7g2/bsp_module_stop.o .debug_line 0x000052d0 0x385 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_rom_registers.o .debug_line 0x00005655 0x3cd ./synergy/ssp/src/bsp/mcu/all/bsp_common.o .debug_line 0x00005a22 0x3c5 ./synergy/ssp/src/bsp/mcu/all/bsp_delay.o .debug_line 0x00005de7 0x3ac ./synergy/ssp/src/bsp/mcu/all/bsp_irq.o .debug_line 0x00006193 0x4a6 ./synergy/ssp/src/bsp/mcu/all/bsp_locking.o .debug_line 0x00006639 0x42f ./synergy/ssp/src/bsp/mcu/all/bsp_register_protection.o .debug_line 0x00006a68 0x406 ./synergy/ssp/src/bsp/mcu/all/bsp_sbrk.o .debug_line 0x00006e6e 0x3bb ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/startup_S7G2.o .debug_line 0x00007229 0x6b5 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/system_S7G2.o .debug_line 0x000078de 0x3e7 ./src/synergy_gen/common_data.o .debug_line 0x00007cc5 0x391 ./src/synergy_gen/hal_data.o .debug_line 0x00008056 0x534 ./src/synergy_gen/main.o .debug_line 0x0000858a 0x57d ./src/synergy_gen/new_thread0.o .debug_line 0x00008b07 0x38f ./src/synergy_gen/pin_data.o .debug_line 0x00008e96 0x5a6 ./src/new_thread0_entry.o .debug_line 0x0000943c 0x2eb F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_create.o) .debug_line 0x00009727 0x26f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_get.o) .debug_line 0x00009996 0x239 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_put.o) .debug_line 0x00009bcf 0x2f9 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_thread_create.o) .debug_line 0x00009ec8 0x2de F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) .debug_line 0x0000a1a6 0x26d F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_kernel_enter.o) .debug_line 0x0000a413 0x20a F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_end.o) .debug_line 0x0000a61d 0x20c F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_start.o) .debug_line 0x0000a829 0x269 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_create.o) .debug_line 0x0000aa92 0x2ba F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_get.o) .debug_line 0x0000ad4c 0x293 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_put.o) .debug_line 0x0000afdf 0x360 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_create.o) .debug_line 0x0000b33f 0x290 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) .debug_line 0x0000b5cf 0x26a F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_shell_entry.o) .debug_line 0x0000b839 0x29c F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_sleep.o) .debug_line 0x0000bad5 0x25d F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_preempt_check.o) .debug_line 0x0000bd32 0x2e5 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_resume.o) .debug_line 0x0000c017 0x2fe F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_suspend.o) .debug_line 0x0000c315 0x276 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_timeout.o) .debug_line 0x0000c58b 0x288 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) .debug_line 0x0000c813 0x25c F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_activate.o) .debug_line 0x0000ca6f 0x24a F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_deactivate.o) .debug_line 0x0000ccb9 0x2f2 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_low_level.o) .debug_line 0x0000cfab 0x339 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_schedule.o) .debug_line 0x0000d2e4 0x27a F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_stack_build.o) .debug_line 0x0000d55e 0x2b5 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_interrupt.o) .debug_line 0x0000d813 0x29c F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_cleanup.o) .debug_line 0x0000daaf 0x286 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_time_slice.o) .debug_line 0x0000dd35 0x2e9 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_expiration_process.o) .debug_str 0x00000000 0x11fb7 .debug_str 0x00000000 0x8106 ./synergy/ssp/src/driver/r_ioport/r_ioport.o 0x8310 (size before relaxing) .debug_str 0x00008106 0x9d4 ./synergy/ssp/src/driver/r_fmi/r_fmi.o 0x5750 (size before relaxing) .debug_str 0x00008ada 0xae4 ./synergy/ssp/src/driver/r_elc/r_elc.o 0x57e7 (size before relaxing) .debug_str 0x000095be 0x1948 ./synergy/ssp/src/driver/r_cgc/r_cgc.o 0x7d38 (size before relaxing) .debug_str 0x0000af06 0x24f3 ./synergy/ssp/src/driver/r_adc/r_adc.o 0x88c8 (size before relaxing) .debug_str 0x0000d3f9 0x7b ./synergy/ssp/src/bsp/mcu/s7g2/bsp_cache.o 0x4d5b (size before relaxing) .debug_str 0x0000d474 0x250 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_clocks.o 0x5877 (size before relaxing) .debug_str 0x0000d6c4 0x547 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o 0x639d (size before relaxing) .debug_str 0x0000dc0b 0x52ff ./synergy/ssp/src/bsp/mcu/s7g2/bsp_fmi_R7FS7G27G3A01CFB.o .debug_str 0x0000dc0b 0x368 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_group_irq.o 0x5851 (size before relaxing) .debug_str 0x0000df73 0x135e ./synergy/ssp/src/bsp/mcu/s7g2/bsp_hw_locks.o 0x6657 (size before relaxing) .debug_str 0x0000f2d1 0x2da ./synergy/ssp/src/bsp/mcu/s7g2/bsp_module_stop.o 0x61ea (size before relaxing) .debug_str 0x0000f5ab 0x57 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_rom_registers.o 0x534b (size before relaxing) .debug_str 0x0000f602 0xcb ./synergy/ssp/src/bsp/mcu/all/bsp_common.o 0x53d6 (size before relaxing) .debug_str 0x0000f6cd 0xb3 ./synergy/ssp/src/bsp/mcu/all/bsp_delay.o 0x4d7a (size before relaxing) .debug_str 0x0000f780 0x84 ./synergy/ssp/src/bsp/mcu/all/bsp_irq.o 0x5792 (size before relaxing) .debug_str 0x0000f804 0x126 ./synergy/ssp/src/bsp/mcu/all/bsp_locking.o 0x5487 (size before relaxing) .debug_str 0x0000f92a 0xa7 ./synergy/ssp/src/bsp/mcu/all/bsp_register_protection.o 0x6011 (size before relaxing) .debug_str 0x0000f9d1 0xb8 ./synergy/ssp/src/bsp/mcu/all/bsp_sbrk.o 0x50d9 (size before relaxing) .debug_str 0x0000fa89 0x93 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/startup_S7G2.o 0x5391 (size before relaxing) .debug_str 0x0000fb1c 0x2bf ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/system_S7G2.o 0x7535 (size before relaxing) .debug_str 0x0000fddb 0xd2 ./src/synergy_gen/common_data.o 0x72ca (size before relaxing) .debug_str 0x0000fead 0x29 ./src/synergy_gen/hal_data.o 0x6c1e (size before relaxing) .debug_str 0x0000fed6 0x837 ./src/synergy_gen/main.o 0x5f75 (size before relaxing) .debug_str 0x0001070d 0x143 ./src/synergy_gen/new_thread0.o 0x8f7e (size before relaxing) .debug_str 0x00010850 0x1fc ./src/synergy_gen/pin_data.o 0x6c25 (size before relaxing) .debug_str 0x00010a4c 0x58 ./src/new_thread0_entry.o 0x85d4 (size before relaxing) .debug_str 0x00010aa4 0x41e F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_create.o) 0x10e3 (size before relaxing) .debug_str 0x00010ec2 0x51 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_get.o) 0x101f (size before relaxing) .debug_str 0x00010f13 0x45 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_put.o) 0xd4e (size before relaxing) .debug_str 0x00010f58 0xab F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_thread_create.o) 0x104c (size before relaxing) .debug_str 0x00011003 0x68d F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) 0x163a (size before relaxing) .debug_str 0x00011690 0x69 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_kernel_enter.o) 0xf5e (size before relaxing) .debug_str 0x000116f9 0x33 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_end.o) 0x618 (size before relaxing) .debug_str 0x0001172c 0x2e F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_start.o) 0x61c (size before relaxing) .debug_str 0x0001175a 0x48 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_create.o) 0xdb9 (size before relaxing) .debug_str 0x000117a2 0x5c F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_get.o) 0xef4 (size before relaxing) .debug_str 0x000117fe 0x4b F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_put.o) 0xef0 (size before relaxing) .debug_str 0x00011849 0x84 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_create.o) 0xef8 (size before relaxing) .debug_str 0x000118cd 0x50 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) 0xda4 (size before relaxing) .debug_str 0x0001191d 0x4e F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_shell_entry.o) 0xdc3 (size before relaxing) .debug_str 0x0001196b 0x3d F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_sleep.o) 0xf69 (size before relaxing) .debug_str 0x000119a8 0xa6 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_preempt_check.o) 0xe98 (size before relaxing) .debug_str 0x00011a4e 0x74 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_resume.o) 0x1072 (size before relaxing) .debug_str 0x00011ac2 0x6f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_suspend.o) 0x1096 (size before relaxing) .debug_str 0x00011b31 0x54 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_timeout.o) 0xf6f (size before relaxing) .debug_str 0x00011b85 0x35 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) 0xeee (size before relaxing) .debug_str 0x00011bba 0x6a F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_activate.o) 0x91d (size before relaxing) .debug_str 0x00011c24 0x3c F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_deactivate.o) 0x8fa (size before relaxing) .debug_str 0x00011c60 0xd4 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_low_level.o) 0x1173 (size before relaxing) .debug_str 0x00011d34 0xdb F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_schedule.o) 0x1ea2 (size before relaxing) .debug_str 0x00011e0f 0x4c F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_stack_build.o) 0xd77 (size before relaxing) .debug_str 0x00011e5b 0x6f F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_interrupt.o) 0xf7f (size before relaxing) .debug_str 0x00011eca 0x4c F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_cleanup.o) 0xf0c (size before relaxing) .debug_str 0x00011f16 0x36 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_time_slice.o) 0xf2a (size before relaxing) .debug_str 0x00011f4c 0x6b F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_expiration_process.o) 0xfae (size before relaxing) .debug_frame 0x00000000 0x1a00 .debug_frame 0x00000000 0x298 ./synergy/ssp/src/driver/r_ioport/r_ioport.o .debug_frame 0x00000298 0xac ./synergy/ssp/src/driver/r_fmi/r_fmi.o .debug_frame 0x00000344 0x9c ./synergy/ssp/src/driver/r_elc/r_elc.o .debug_frame 0x000003e0 0x4e0 ./synergy/ssp/src/driver/r_cgc/r_cgc.o .debug_frame 0x000008c0 0x240 ./synergy/ssp/src/driver/r_adc/r_adc.o .debug_frame 0x00000b00 0x30 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_cache.o .debug_frame 0x00000b30 0x70 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_clocks.o .debug_frame 0x00000ba0 0x114 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_feature.o .debug_frame 0x00000cb4 0x60 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_group_irq.o .debug_frame 0x00000d14 0xb4 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_module_stop.o .debug_frame 0x00000dc8 0x40 ./synergy/ssp/src/bsp/mcu/all/bsp_common.o .debug_frame 0x00000e08 0x58 ./synergy/ssp/src/bsp/mcu/all/bsp_delay.o .debug_frame 0x00000e60 0x3c ./synergy/ssp/src/bsp/mcu/all/bsp_irq.o .debug_frame 0x00000e9c 0xa0 ./synergy/ssp/src/bsp/mcu/all/bsp_locking.o .debug_frame 0x00000f3c 0x58 ./synergy/ssp/src/bsp/mcu/all/bsp_register_protection.o .debug_frame 0x00000f94 0x28 ./synergy/ssp/src/bsp/mcu/all/bsp_sbrk.o .debug_frame 0x00000fbc 0x38 ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/startup_S7G2.o .debug_frame 0x00000ff4 0x5c ./synergy/ssp/src/bsp/cmsis/Device/RENESAS/S7G2/Source/system_S7G2.o .debug_frame 0x00001050 0x20 ./src/synergy_gen/common_data.o .debug_frame 0x00001070 0x20 ./src/synergy_gen/hal_data.o .debug_frame 0x00001090 0x84 ./src/synergy_gen/main.o .debug_frame 0x00001114 0x5c ./src/synergy_gen/new_thread0.o .debug_frame 0x00001170 0x4c ./src/new_thread0_entry.o .debug_frame 0x000011bc 0x3c F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_create.o) .debug_frame 0x000011f8 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_get.o) .debug_frame 0x00001218 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_semaphore_put.o) .debug_frame 0x00001238 0x58 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(txe_thread_create.o) .debug_frame 0x00001290 0x30 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_high_level.o) .debug_frame 0x000012c0 0x2c F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_kernel_enter.o) .debug_frame 0x000012ec 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_end.o) .debug_frame 0x0000130c 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_isr_start.o) .debug_frame 0x0000132c 0x30 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_create.o) .debug_frame 0x0000135c 0x30 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_get.o) .debug_frame 0x0000138c 0x2c F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_put.o) .debug_frame 0x000013b8 0x38 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_create.o) .debug_frame 0x000013f0 0x2c F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_initialize.o) .debug_frame 0x0000141c 0x34 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_shell_entry.o) .debug_frame 0x00001450 0x2c F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_sleep.o) .debug_frame 0x0000147c 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_preempt_check.o) .debug_frame 0x0000149c 0x30 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_resume.o) .debug_frame 0x000014cc 0x30 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_system_suspend.o) .debug_frame 0x000014fc 0x38 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_timeout.o) .debug_frame 0x00001534 0x2c F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_initialize.o) .debug_frame 0x00001560 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_activate.o) .debug_frame 0x00001580 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_system_deactivate.o) .debug_frame 0x000015a0 0x2c F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_initialize_low_level.o) .debug_frame 0x000015cc 0x68 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_schedule.o) .debug_frame 0x00001634 0x20 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_stack_build.o) .debug_frame 0x00001654 0x28 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_interrupt.o) .debug_frame 0x0000167c 0x2c F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_semaphore_cleanup.o) .debug_frame 0x000016a8 0x34 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_thread_time_slice.o) .debug_frame 0x000016dc 0x40 F:\proj3\adc.zip_expanded\adc\synergy\ssp\src\framework\el\tx\cm4_gcc\libtx.a(tx_timer_expiration_process.o) .debug_frame 0x0000171c 0x20 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-errno.o) .debug_frame 0x0000173c 0x2c c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-memcmp.o) .debug_frame 0x00001768 0x20 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-memset.o) .debug_frame 0x00001788 0x48 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-rand.o) .debug_frame 0x000017d0 0x30 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-malloc.o) .debug_frame 0x00001800 0x2c c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-nano-mallocr.o) .debug_frame 0x0000182c 0x2c c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-sbrkr.o) .debug_frame 0x00001858 0x30 c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-mlock.o) .debug_frame 0x00001888 0x5c c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libg_nano.a(lib_a-reent.o) .debug_frame 0x000018e4 0x11c c:/renesas/synergy/e2studio_v7.5.1_ssp_v1.7.8/toolchains/gcc_arm/7.2.1_2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc_nano.a(lib_a-findfp.o)
  • Unfortunately your map file does not give any information about the memory mapping (or I don't find it).
    From the S7G2 address space I guess your bin file includes data for program flash and data for E2 data flash or option setting memory. In a´bin file all addresses in between are filled with 0x00 or 0xFF. This results in a 1GB file size.
    Make sure only data for program flash or only data for E2 data flash is output to the bin file.
  • It is the .id_code_1 section that is causing the large size of the binary file. The code flash starts at 0x0, and the .id_code_1 section is located at address 0x40120050 :-
    .id_code_1      0x40120050       0x10
                    0x40120050                __ID_Codes_Start = .
     *(.id_code_1*)
     .id_code_1     0x40120050       0x10 ./synergy/ssp/src/bsp/mcu/s7g2/bsp_rom_registers.o
                    0x40120060                __ID_Codes_End = .
    To get objcopy to remove the .id_code_1 section from the binary, add -R .id_code_1 to the "Other flags" in GNU ARM Cross Create Flash Image->General
    This will of cource remove the id_codes section from the binary, so if you have set an ID code, it won't be used.
    renesasrulz.com/.../download
  • Thanks a lot jeremy. Thanks to frank and roberto for sharing.   @jeremy U  were right at the start . it was the ID_CODES. I removed ID_CODES , even after removing ,  the prog executed functionality as expected.
    1. But I dont get a clear picture of as to wat  is ID_CODE and why does it take so much memory.
    2. Is it appropriate to remove ID_CODES for all the future projects I create to reduce the bin file size?
