ISL69144 at minus Temperature
We use ISL69144IRAZ-T7A on the AMD GPU board. ISL69144IRAZ-T7A works normally at room temperature but it takes long time for PGOOD signals of  ISL69144IRAZ-T7A to arrive at minus temperature.
ISL69144IRAZ-T7A and AMD GPU connected via SVI2 interface.  ISL69144IRAZ-T7A has NVM. We are programming NVM with "Production Config Tool 5.4.139.0". Can NVM  cause problems at minus temperature? Is there any known erreta document of  ISL69144IRAZ-T7A?
Marking of ISL69144IRAZ-T7A at top side;
*intersil
ISL69144
IRZ
W1706AADG
Thanks.
  • We apologize but we cannot answer questions on a public forum for these parts since their datasheets are confidential.
    For any further support on this you will need to submit a Technical Support ticket by going to our support portal from the following link: https://en-support.renesas.com
    You will need to sign in with your company email address, and if you don't have an account you will need to register with one. https://www.renesas.com/register
    Cindy Huberty
    Renesas Electronics
    Online Applications Support Engineer
