MCU - S5D9, SSP - 1.7.0, IDE - E2Studio
I want to save real-time data (say an array of data) as a PDF/Image/Text in external memory storage and send it via ethernet
How this conversion will happen in this microcontroller? Is there a way to do it? if possible guide me.
Thank you very much
Hello ivok,Can you confirm what memory storage you are going to utilize? Are you going to use an external USB mass storage device or an external memory card like an SD Card?
Kindly also see this application note FileX Port Block Media Framework Module Guide as this guide on implementing and configuring your own system correctly on the Synergy MCU.
Hope this helps!
Regards,JefIf this response, or one provided by another user, answers your question, please verify the answer. Thank you!Renesas Engineering Community Moderatorshttps://community.renesas.com/https://academy.renesas.com/en-support.renesas.com/.../
