RA6T2 IIC clock
Hi all,
I'm using the I2C module of RA6T2, and I was wondering that how to set the IICCLK?
For example, if I used the stander mode I2C (100kbps), what is the minimum request of IICCLK?
I had checked the spec, and the only description of limitation about IICCLK is
IICCLK/2 <= PCLKA <= IICCLK
but how can I calculate the minimum value for the specific transfer rate?
Thanks.
Cooper.
[locked by: Sai (SWF) at 16:56 (GMT 0) on 12 Dec 2022]
