* File Name : https_client_thread_entry.c
* Description : Contains entry function of HTTPS Client.
* Copyright (c) 2020 - 2024 Renesas Electronics Corporation and/or its affiliates
* SPDX-License-Identifier: BSD-3-Clause
/* Include Header Files. */
#include "https_client_thread.h"
#include "common_utils.h"
#include "https_client_app.h"
#include "adc_app.h"
#include "user_app.h" // or another relevant file for g_sf_el_nx
#include "r_ether_api.h"
* @addtogroup NetX_https_client_ep
/* Auto generated global variables */
/* Packet pool instance. */
NX_PACKET_POOL g_packet_pool0;
/* Web HTTP Client instance. */
NX_WEB_HTTP_CLIENT g_web_http_client0;
/* IP instance */
NX_IP g_ip0;
/* DNS instance. */
NX_DNS g_dns0;
NX_PACKET *gp_response_ptr = NULL;
/* Stack memory for g_ip0. */
uint8_t g_ip0_stack_memory[G_IP0_TASK_STACK_SIZE] BSP_PLACE_IN_SECTION(".stack.g_ip0") BSP_ALIGN_VARIABLE(BSP_STACK_ALIGNMENT);
/* ARP cache memory for g_ip0. */
uint8_t g_ip0_arp_cache_memory[G_IP0_ARP_CACHE_SIZE] BSP_ALIGN_VARIABLE(4);
/* Packet Pool Memory for g_packet_pool0. */
uint8_t g_packet_pool0_pool_memory[G_PACKET_POOL0_PACKET_NUM * (G_PACKET_POOL0_PACKET_SIZE + sizeof(NX_PACKET))] BSP_ALIGN_VARIABLE(4) ETHER_BUFFER_PLACE_IN_SECTION;
/* Buffer to read Response from server. */
extern UCHAR g_receive_buffer[DATA_SIZE];
/* variable to capture invalid input state */
volatile bool g_invalid_input = false;
/* IPv4 Address structure for server. */
static NXD_ADDRESS server_ip_address;
static ULONG server_addr = 0xC0A81FA0;
static ULONG dns_server_addr = 0xC0A81F01;
static void nx_common_init0(void);
static UINT web_http_client0_init(void);
static UINT ip0_init(void);
static UINT packet_pool0_init0(void);
static UINT dns_client_init(void);
static UINT Process_InputRequest(uint8_t input_data);
#define SERVER_IP_ADDRESS 0xC0A81F01 // For 192.168.31.1 in hex
NX_INTERFACE g_sf_el_nx;
* @brief This is the User Thread Entry for the EP.
* @param[in] Thread specific parameters
* @retval None
void https_client_thread_entry(void)
/* To capture the status(Success/Failure) of each Function/API. */
UINT status = NX_SUCCESS;
UINT err = TX_SUCCESS;
fsp_err_t adc_err = FSP_SUCCESS;
/* Client IP address and Network Mask. */
ULONG client_ip_address = RESET_VALUE;
ULONG network_mask = RESET_VALUE;
uint8_t read_data = RESET_VALUE;
float init_adc_val = RESET_VALUE;
/* Initialize the RTT Thread.*/
rtt_thread_init_check();
/* Print EP and Banner info. */
app_rtt_print_data(RTT_OUTPUT_MESSAGE_BANNER, RESET_VALUE, NULL);
/* Initialize the ADC. */
adc_err = hal_adc_init();
if(FSP_SUCCESS != adc_err)
PRINT_ERR_STR("hal_adc_init() Function failed.");
ERROR_TRAP(adc_err);
/* Initialize NetX. */
nx_common_init0();
/* Initialize Packet Pool. */
status = packet_pool0_init0();
if(NX_SUCCESS != status)
PRINT_ERR_STR("packet_pool0_init0() Function failed.");
ERROR_TRAP(status);
/* Initialize IP with manual settings. */
status = ip0_init();
PRINT_ERR_STR("ip0_init() Function failed.");
/* Initialize DNS Client. */
status = dns_client_init();
PRINT_ERR_STR("dns_client_init() Function failed.");
/* Initialize Web HTTPS Client. */
status = web_http_client0_init();
PRINT_ERR_STR("web_http_client0_init() Function failed.");
/* Initialize the TLS Component. */
nx_secure_tls_initialize();
/* Add Server IP address and IPv4 info in structure. */
server_ip_address.nxd_ip_address.v4 = server_addr;
server_ip_address.nxd_ip_version = NX_IP_VERSION_V4;
/* Connect to the HTTPS server. */
status = nx_web_http_client_secure_connect(&g_web_http_client0, &server_ip_address, NX_WEB_HTTPS_SERVER_PORT,
tls_setup_callback, SECURE_CONNECT_WAIT_TIME);
PRINT_ERR_STR("nx_web_http_client_secure_connect API failed.");
deinit_https_client();
PRINT_INFO_STR("HTTPS Client is connected to the server successfully!");
/* Retrieve the IP Address. */
status = nx_ip_address_get(&g_ip0, &client_ip_address, &network_mask);
PRINT_ERR_STR("nx_ip_address_get API failed.");
/* Print the client IP address. */
app_rtt_print_data(RTT_OUTPUT_MESSAGE_APP_PRINT_CLIENT_IP, sizeof(ULONG *), &client_ip_address);
/* Post Request with initial data. */
PRINT_INFO_STR("Adding an initial data on the feed...");
init_adc_val = adc_data_read();
status = processPostRequest(init_adc_val);
PRINT_ERR_STR("processPostRequest() Function failed.");
PRINT_INFO_STR("Posted initial data on the feed successfully!");
/* Print the Menu Options */
app_rtt_print_data(RTT_OUTPUT_MESSAGE_APP_PRINT_MENU, RESET_VALUE, NULL);
/* Process the data as per the user selected option from the menu. */
while (true)
do
err = check_for_rtt_user_ip(&read_data);
}while (err != TX_SUCCESS);
status = Process_InputRequest(read_data);
PRINT_ERR_STR("Process_InputRequest() function failed.");
if (!g_invalid_input)
status = readResponsefromServer();
PRINT_ERR_STR("readResponsefromServer() function failed.");
else
APP_PRINT("Received data: %s\n", g_receive_buffer);
PRINT_INFO_STR("Read the response from server Successfully!");
tx_thread_sleep(1);
* @brief This function initializes the NetX System.
* @param[IN] None
/* Initialize the NetX system. */
nx_system_initialize();
* @brief This function creates the packet pool.
status = nx_packet_pool_create(&g_packet_pool0, "g_packet_pool0 Packet Pool",
G_PACKET_POOL0_PACKET_SIZE, &g_packet_pool0_pool_memory[0],
G_PACKET_POOL0_PACKET_NUM * (G_PACKET_POOL0_PACKET_SIZE + sizeof(NX_PACKET)));
PRINT_ERR_STR("nx_packet_pool_create API failed.");
return status;
* @brief This function initializes the Web HTTPS Client.
status = nx_web_http_client_create(&g_web_http_client0, "g_web_http_client0",
&g_ip0, &g_packet_pool0, G_WEB_HTTP_CLIENT0_WINDOW_SIZE);
PRINT_ERR_STR("nx_web_http_client_create API failed.");
* @brief This function creates the ip instance with manual IP settings.
ULONG current_state = RESET_VALUE;
/* Manual IP configuration */
ULONG manual_ip_address = 0xC0A80A36; /* 192.168.10.54 */
ULONG subnet_mask = 0xFFFFFF00; /* 255.255.255.0 */
ULONG gateway_address = 0xC0A80A01; /* 192.168.10.1 */
/* Create the IP instance */
status = nxe_ip_create(&g_ip0, "g_ip0 IP Instance", manual_ip_address, subnet_mask,
&g_packet_pool0, g_ether0, g_ip0_stack_memory,
G_IP0_TASK_STACK_SIZE, G_IP0_TASK_PRIORITY);
PRINT_ERR_STR("nx_ip_create API failed.");
/* Set the gateway address */
status = nx_ip_gateway_address_set(&g_ip0, gateway_address);
PRINT_ERR_STR("nx_ip_gateway_address_set API failed.");
/* Enable ARP and supply ARP cache memory */
status = nx_arp_enable(&g_ip0, g_ip0_arp_cache_memory, G_IP0_ARP_CACHE_SIZE);
PRINT_ERR_STR("nx_arp_enable API failed.");
/* Enable ICMP (ping) */
status = nx_icmp_enable(&g_ip0);
PRINT_ERR_STR("nx_icmp_enable API failed.");
/* Enable TCP traffic */
status = nx_tcp_enable(&g_ip0);
PRINT_ERR_STR("nx_tcp_enable API failed.");
/* Enable UDP traffic */
status = nx_udp_enable(&g_ip0);
PRINT_ERR_STR("nx_udp_enable API failed.");
/* Check for interface link status */
status = nx_ip_interface_status_check(&g_ip0, 0U, NX_IP_LINK_ENABLED, ¤t_state, LINK_ENABLE_WAIT_TIME);
PRINT_ERR_STR("nx_ip_interface_status_check API failed.");
* @brief This function creates the DNS Client.
/* Create a DNS instance for the Client */
status = nx_dns_create(&g_dns0, &g_ip0, (UCHAR *)"g_dns0");
PRINT_ERR_STR("nx_dns_create API failed.");
/* Initialize DNS Client to point to a DNS Server */
dns_server_addr = SERVER_IP_ADDRESS;
status = nx_dns_server_add(&g_dns0, dns_server_addr);
PRINT_ERR_STR("nx_dns_server_add API failed.");
* @} (end addtogroup NetX_https_client_ep)
how to update this code for manual ip set this program has some errors can you help to solve this error?
You can use the nx_ip_address_set function. You can refer to download.microsoft.com/.../Azure_RTOS_NetX_Duo_User_Guide.pdf
