RL78 L13 R5F10WMG PFDL Problems
I am trying to use the user memory on the RL78 - R5F10WMG. I am using IAM Embedded Workbench 1.40.5 due to the fact that my company has a license for this version. I downloaded the latest PFDL library, and I believe I modified the linker file correctly, however I must be doing something wrong as the processor appears to lock up when PFDL_Execute(); is called when attempting to either read or write to the flash memory. I have used this library on other parts such as the G10, G12 and G13 and never have had a problem. Thanks in advance!
  • The R5F10WMG is subject to the so-called "Self-RAM" restrictions - see document R20UT2944 RL78 Family Self RAM list of Flash Self Programming Library:
    Do you block the start of RAM from allocation to the application?
  • No, I did not, this could be the issue, thank you! To be honest I'm not very knowledgeable when it comes to linker files, how would I go about doing this?
  • Edit the linker config-file according to the requirement:
    For the PFDL the restricted RAM is smaller:
    Here are the linker files for v1.40.6, original and modified for PFDL, I assume v1.40.5 is the same.
    lnkr5f10wmg-Orig.xcl.txt
    //      XLINK command file template for RL78 microcontroller R5F10WMG.
    //      This file can be used to link object files from the RL78
    //      Assembler, ARL78, and the C/C++ compiler ICCRL78.
    //          This file is generated from the device file:
    //          DR5F10WMG.DVF
    //          Copyright(C) 2012 Renesas
    //          Format version V3.00, File version E1.00d
    //      The following segments are defined in this template link file:
    //      INTVEC      -- Interrupt vectors.
    //      CLTVEC      -- Calltable vectors.
    //      RCODE       -- Code used by C/C++ startup and run-time library.
    //      CODE        -- Code used by __near_func, __interrupt and __callt functions.
    //      XCODE       -- Code used by __far_func functions.
    //      NEAR_CONST_ -- Constants used by __near const.
    //      FAR_CONST   -- Constants used by __far const.
    //      SADDR_x     -- Variables used by __saddr.
    //      NEAR_x      -- Variables used by __near.
    //      FAR_x       -- Variables used by __far.
    //      NEAR_HEAP   -- The heap used by near data model.
    //      FAR_HEAP    -- The heap used by far data model.
    //      SWITCH      -- Switch tables used by near code model.
    //      FSWITCH     -- Switch tables used by far model.
    //      DIFUNCT     -- Dynamic initialization vector used by C++
    //      Where _x could be one of:
    //      _Z      -- Initialized data (initvalue = 0 or without init value).
    //      _I      -- Initialized data (initvalue != 0).
    //      _ID     -- The initial values of _I.
    //      _N      -- Uninitialized data, used by __no_init.
    //      Define CPU
    -cRL78
    //      Size of the stack.
    //      Remove comment and modify number if used from command line.
    //-D_CSTACK_SIZE=80
    //      Size of the heaps.
    //-D_NEAR_HEAP_SIZE=400
    //-D_FAR_HEAP_SIZE=4000
    //      Near constant location.
    //      0 -> 0xF0000-0xFFFFF mirrored in rom area 0x00000 - 0x0FFFF
    //      1 -> 0xF0000-0xFFFFF mirrored in rom area 0x10000 - 0x1FFFF
    //      2 -> Writeable constants
    //      Remove comments and modify number if used from command line.
    //-D_NEAR_CONST_LOCATION=0
    //-D_NEAR_CONST_LOCATION_START=02000
    //-D_NEAR_CONST_LOCATION_END=0DEFF
    //      Define the format functions used by printf/scanf.
    //      Default is auto formatting.
    //      Remove appropriate comment(s) to get desired formatting
    //      if used from command line.
    //-e_PrintfTiny=_Printf
    //-e_PrintfSmall=_Printf
    //-e_PrintfLarge=_Printf
    //-e_PrintfFull=_Printf
    //-e_ScanfSmall=_Scanf
    //-e_ScanfLarge=_Scanf
    //-e_ScanfFull=_Scanf
    //      Define replacement of the default library math functions.
    //      Choose either of:
    //      1) smaller and faster versions
    //      2) more accurate versions
    //      Remove appropriate comment(s) from either
    //      1) or 2), but not both, if used from command line.
    // 1) Smaller and faster versions
    //-e__iar_sin_small=sin
    //-e__iar_cos_small=cos
    //-e__iar_tan_small=tan
    //-e__iar_log_small=log
    //-e__iar_log10_small=log10
    //-e__iar_exp_small=exp
    //-e__iar_pow_small=pow
    //-e__iar_Sin_small=__iar_Sin
    //-e__iar_sin_smallf=sinf
    //-e__iar_cos_smallf=cosf
    //-e__iar_tan_smallf=tanf
    //-e__iar_log_smallf=logf
    //-e__iar_log10_smallf=log10f
    //-e__iar_exp_smallf=expf
    //-e__iar_pow_smallf=powf
    //-e__iar_Sin_smallf=__iar_Sinf
    //-e__iar_sin_smalll=sinl
    //-e__iar_cos_smalll=cosl
    //-e__iar_tan_smalll=tanl
    //-e__iar_log_smalll=logl
    //-e__iar_log10_smalll=log10l
    //-e__iar_exp_smalll=expl
    //-e__iar_pow_smalll=powl
    //-e__iar_Sin_smalll=__iar_Sinl
    // 2) More accurate versions
    //-e__iar_sin_accurate=sin
    //-e__iar_cos_accurate=cos
    //-e__iar_tan_accurate=tan
    //-e__iar_pow_accurate=pow
    //-e__iar_Sin_accurate=__iar_Sin
    //-e__iar_Pow_accurate=__iar_Pow
    //-e__iar_sin_accuratef=sinf
    //-e__iar_cos_accuratef=cosf
    //-e__iar_tan_accuratef=tanf
    //-e__iar_pow_accuratef=powf
    //-e__iar_Sin_accuratef=__iar_Sinf
    //-e__iar_Pow_accuratef=__iar_Powf
    //-e__iar_sin_accuratel=sinl
    //-e__iar_cos_accuratel=cosl
    //-e__iar_tan_accuratel=tanl
    //-e__iar_pow_accuratel=powl
    //-e__iar_Sin_accuratel=__iar_Sinl
    //-e__iar_Pow_accuratel=__iar_Powl
    //      Define if row buffering should be used by terminal output.
    //      Default is no buffering.
    //      Remove comment to get buffered terminal output if used from command line.
    //-e__write_buffered=__write
    //      Allocate the read only segments that are mapped to ROM.
    //      Interrupt vector segment.
    -Z(CODE)INTVEC=00000-0007F
    //      CALLT vector segment.
    -Z(CODE)CLTVEC=00080-000BD
    //      OPTION BYTES segment.
    -Z(CODE)OPTBYTE=000C0-000C3
    //      SECURITY_ID segment.
    -Z(CODE)SECUID=000C4-000CD
    //      Reserved ROM areas for OCD Firmware: 000CE-000D7
    //                                           1FC00-1FFFF
    //      Near constant segments.
    --segment_mirror @NEAR_CONST=NEAR_CONST_ID
    -Z(CONST)NEAR_CONST_ID=_NEAR_CONST_LOCATION_START-_NEAR_CONST_LOCATION_END
    -Z(DATA)NEAR_CONST=(_NEAR_CONST_LOCATION_START+F0000)-(_NEAR_CONST_LOCATION_END+F0000)
    //      Startup, Runtime-library, Near, Interrupt
    //      and CALLT functions code segment and near switch.
    -Z(CODE)RCODE,CODE=000D8-0FFFF
    -Z(CONST)SWITCH=000D8-0FBFF
    //      Near data initializer segments.
    -Z(CONST)NEAR_ID=[000D8-0FBFF]/10000
    -Z(CONST)SADDR_ID=[000D8-0FBFF]/10000
    -Z(CONST)DIFUNCT=[000D8-0FBFF]/10000
    //      Huge data segments.
    -Z(CONST)HUGE_ID=0DF00-1FBFF
    -Z(DATA)HUGE_I=FDF00-FFE1F
    //      Far constant segments and far switch.
    -Z(CONST)FAR_ID=[0DF00-1FBFF]/10000
    -Z(DATA)FAR_I=[FDF00-FFE1F]/10000
    -P(CONST)FAR_CONST,FSWITCH=[000D8-1FBFF]/10000
    //      Far functions code segment.
    -P(CODE)XCODE=[000D8-1FBFF]/10000
    //      Allocate the read/write segments that are mapped to RAM.
    //      EEPROM segment.
    //      Note: This segment will not be automatically created
    //            and it will not be initialised by CSTARTUP!
    -Z(DATA)EEPROM=F1000-F1FFF
    //      Short address data and workseg segments.
    -Z(DATA)WRKSEG=FFE20-FFEDF
    -Z(DATA)SADDR_I,SADDR_Z,SADDR_N=FFE20-FFEDF
    //      Near data segments.
    -Z(DATA)NEAR_I,NEAR_Z,NEAR_N=FDF00-FFE1F
    //      Stack segment.
    -Z(DATA)CSTACK+_CSTACK_SIZE=FDF00-FFE1F
    //      Heap segments.
    -Z(DATA)NEAR_HEAP+_NEAR_HEAP_SIZE=FDF00-FFE1F
    -Z(DATA)FAR_HEAP+_FAR_HEAP_SIZE=[FDF00-FFE1F]/10000
    -Z(DATA)HUGE_Z=FDF00-FFE1F
    -P(DATA)HUGE_N=FDF00-FFE1F
    //      Far data segments.
    -Z(DATA)FAR_Z=[FDF00-FFE1F]/10000
    -P(DATA)FAR_N=[FDF00-FFE1F]/10000
    //      Select the output file format if used from command line.
    //      Remove comment to select the file format if used from command line.
    //-Fdebug
    //      End of File
    lnkr5f10wmg-PFDL.xcl.txt
    //          DR5F10WMG.DVF
    //      Define CPU
    -cRL78
    //-D_CSTACK_SIZE=80
    //                                           1FC00-1FFFF
    -Z(DATA)HUGE_I=FDF88-FFE1F
    -Z(DATA)FAR_I=[FDF88-FFE1F]/10000
    //      EEPROM segment.
    -Z(DATA)NEAR_I,NEAR_Z,NEAR_N=FDF88-FFE1F
    //      Stack segment.
    -Z(DATA)CSTACK+_CSTACK_SIZE=FDF88-FFE1F
    //      Heap segments.
    -Z(DATA)NEAR_HEAP+_NEAR_HEAP_SIZE=FDF88-FFE1F
    -Z(DATA)FAR_HEAP+_FAR_HEAP_SIZE=[FDF88-FFE1F]/10000
    -Z(DATA)HUGE_Z=FDF88-FFE1F
    -P(DATA)HUGE_N=FDF88-FFE1F
    -Z(DATA)FAR_Z=[FDF88-FFE1F]/10000
    -P(DATA)FAR_N=[FDF88-FFE1F]/10000
    //-Fdebug
    //      End of File
  • Thank you for the help! Also I had to add the following line to the new linker:
    -Z(CODE)PFDL_COD=[01000-01FFE]/10000
    I updated the linker file and now it appears that the execute function no longer causes a lockup/reset when doing a read command however when I attempt to write the chip locks up.
  • Timing is much more critical for write / erase operations than a read, check your descriptor values for valid info.  Also double-check your request data being passed to the lib.
    I have never used the T04/Pico lib type, have always needed to have EEL which is not supported by this lib.  Your 128KB L13 device should have adequate resources to support T02/Tiny FDL and also corresponding EEL if needed.
    Using the v1 IAR tools for RL78 you are a bit limited, as newer (v2, v3, v4) have pretty significant improvements with code generation and optimization, and support for the newer on-chip debuggers E2 & E2-Lite.  v1 maintains backward compatibility with 78K tools but for any non-migrating application I would recommend the latest and greatest.
  • Alright, we may switch over to IAR 4.10.1. I see the linker file format is different, I'm assuming I couldn't use the modified linker file that you provided me the other day?
  • Yes, the linker file format changed with v2, as the linker changed.
    Same type of file edits - have to modify the RAM start address to skip the Self-RAM and add the section for the FDL code.
  • The issue appears to have been resolved. I modified the linker for for IAR 4.10.5 and all is well. Thank you for all of the help!
  • I seem to have spoken too soon. It appeared to be working for a while but I am seeing some eratic behavior. Can you double check the changes I made to the linker?
    Original:
    //      ILINK command file template for RL78 microcontroller R5F10WMG.
    //      Assembler, IASMRL78, and the C/C++ compiler ICCRL78.
    //          DR5F10WMG.DVF
    //          Copyright(C) 2013 Renesas
    //          Core type: s2
    //          Format version 3.00, File version 1.01
    define exported symbol __link_file_version_2 = 1;
    initialize by copy with simple ranges, packing = auto { rw, R_DATA, R_BSS, R_DATAF, R_BSSF, R_SDATA, R_SBSS };
    do not initialize   { section *.noinit };
    define memory mem with size = 1M;
    // Set the symbol __RESERVE_OCD_ROM to 1 to reserve the OCD area for debugging.
    // IDE: Symbol can be defined within the project settings here:
    //      "Project"-->"Options..."->"Linker"-->"Config"-->"Configuration file symbol definitions"
    //      Symbol definition: __RESERVE_OCD_ROM=1
    // Command line: --config_def __RESERVE_OCD_ROM=1
    if (isdefinedsymbol(__RESERVE_OCD_ROM))
      if (__RESERVE_OCD_ROM == 1)
        reserve region "OCD ROM area" = mem:[from 0x1FE00 size 0x0200];
    define region ROM_near = mem:[from 0x000D8 to 0x0FFFF];
    define region ROM_far  = mem:[from 0x000D8 to 0x0FFFF] | mem:[from 0x10000 to 0x1FFFF];
    define region ROM_huge = mem:[from 0x000D8 to 0x1FFFF];
    define region SADDR    = mem:[from 0xFFE20 to 0xFFEDF];
    define region RAM_near = mem:[from 0xFDF00 to 0xFFE1F];
    define region RAM_far  = mem:[from 0xFDF00 to 0xFFE1F];
    define region RAM_huge = mem:[from 0xFDF00 to 0xFFE1F];
    define region VECTOR   = mem:[from 0x00000 to 0x0007F];
    define region CALLT    = mem:[from 0x00080 to 0x000BF];
    define region EEPROM   = mem:[from 0xF1000 to 0xF1FFF];
    define block NEAR_HEAP  with alignment = 2, size = _NEAR_HEAP_SIZE {  };
    define block FAR_HEAP   with alignment = 2, size = _FAR_HEAP_SIZE {  };
    define block HUGE_HEAP  with alignment = 2, size = _HUGE_HEAP_SIZE {  };
    define block CSTACK     with alignment = 2, size = _STACK_SIZE { rw section CSTACK };
    define block INIT_ARRAY with alignment = 2, fixed order { ro section .preinit_array,
                                                              ro section .init_array };
    define block INIT_ARRAY_TLS with alignment = 2, fixed order { ro section .preinit_array_tls,
        ro section .init_array_tls };
    define block OPT_BYTE with size = 4  { R_OPT_BYTE,
                                           ro section .option_byte,
                                           ro section OPTBYTE };
    define block SECUR_ID with size = 10 { R_SECUR_ID,
                                           ro section .security_id,
                                           ro section SECUID };
    place at address mem:0x00000       { ro section .reset };
    place at address mem:0x00004       { ro section .intvec };
    place at address mem:0x000C0       { block OPT_BYTE };
    place at address mem:0x000C4       { block SECUR_ID };
    if ( _NEAR_CONST_LOCATION_SIZE > 0 )
      "MIRROR": place in [from _NEAR_CONST_LOCATION_START size _NEAR_CONST_LOCATION_SIZE] with mirroring to (_NEAR_CONST_LOCATION_START | 0xF0000) { ro R_CONST,
        ro section .const,
        ro section .switch };
    "CALLT":place in CALLT             { R_CALLT0, ro section .callt0 };
    "ROMNEAR":place in ROM_near        { R_TEXT, ro section .text};
    "ROMFAR":place in ROM_far          { block INIT_ARRAY,
                                         block INIT_ARRAY_TLS,
                                         R_TEXTF_UNIT64KP,
                                         ro section .textf_unit64kp,
                                         ro section .constf,
                                         ro section .switchf,
                                         ro };
    "ROMHUGE":place in ROM_huge        { ro section .consth,
                                         R_TEXTF,
                                         ro section .textf };
    "RAMNEAR":place in RAM_near        { block NEAR_HEAP,
                                         block CSTACK,
                                         zi section .iar.dynexit,
                                         R_DATA,
                                         rw section .data,
                                         R_BSS,
                                         rw section .bss*,
                                         rw };
    "RAMFAR":place in RAM_far          { block FAR_HEAP,
                                         R_DATAF,
                                         rw section .dataf,
                                         rw section .data_unit64kp,
                                         rw section .bss_unit64kp,
                                         R_BSSF,
                                         rw section .bssf* };
    "RAMHUGE":place in RAM_huge        { block HUGE_HEAP,
                                         rw section .hdata,
                                         rw section .hbss* };
    "SADDRMEM":place in SADDR          { rw section .sdata,
                                         R_SDATA,
                                         rw section .sbss*,
                                         R_SBSS,
                                         rw section .wrkseg };
    Modified:
    //          DR5F10WMG.DVF
    //          Core type: s2
    define region RAM_near = mem:[from 0xFDF88 to 0xFFE1F];
    define region RAM_far  = mem:[from 0xFDF88 to 0xFFE1F];
    define region RAM_huge = mem:[from 0xFDF88 to 0xFFE1F];
        ro section .const,
                                         R_TEXTF_UNIT64KP,
                                         ro section PFDL_COD,
                                         ro section .constf,
                                         ro };
                                         R_TEXTF,
                                         block CSTACK,
                                         R_DATA,
                                         rw section .data,
                                         R_BSS,
                                         rw section .bss*,
                                         rw };
                                         R_DATAF,
                                         rw section .dataf,
                                         R_BSSF,
                                         rw section .hdata,
                                         R_SDATA,
                                         rw section .sbss*,
                                         R_SBSS,
  • The changes look fine.  What do you mean by erratic behavior?
