IAR bat file
hello,
I am doing App+Boot code in single project in IAR (16K limit, no licenced).My application is not exeeding the 16KB memory size because it is a reference code.
I want to generates symbols of bootloader file using batch file as below.
"bootloader.bat"
set TARGET_DIR=%1
set PROJ_DIR=%2
set TOOLKIT_DIR=%3
copy %TARGET_DIR%\Boot_rl78g13.out "C:\Users\My_Project\Desktop\IAR\Project_rl78g13\Bootloader\Image"
%TOOLKIT_DIR%\bin\ielftool.exe %TARGET_DIR%\Boot_rl78g13.out %PROJ_DIR%\Boot_rl78g13.srec --srec
%TOOLKIT_DIR%\bin\ielftool.exe %TARGET_DIR%\Boot_rl78g13.out %PROJ_DIR%\Boot_rl78g13.bin --bin
%TOOLKIT_DIR%\bin\isymexport.exe %TARGET_DIR%\Boot_rl78g13.out %PROJ_DIR%\Boot_rl78g13.symbols --edit %PROJ_DIR%\Boot_rl78g13.edit
post build command is:
"$PROJ_DIR$\bootloader.bat" "$TARGET_DIR$" "$PROJ_DIR$" "$TOOLKIT_DIR$"
Below 4th command is not executing and compilation fails due to below line and all others is okay and generates the files.
I have also cheked TOOLKIT directory, isymexport.exe is available at that location.
Please help. why? 4th command is not executing.
Top Replies
  • Hi
    This seems to be something related to the path names expansion in your batch script.
    I tried to run the same commands you have in a similar way without errors.
    You can take advantage of the…
  • Hi Santanu,
    I think IAR Technical Support can help you more regarding this issue: https://www.iar.com/knowledge/support/request-technical-support/
    JB
    https://academy.renesas.com/
  • Hi
    You can take advantage of the argument variables available from the IDE to simplify your script.
    Search for "argument variables" in the Help ~> IDE Project Management and Building Guide for further information.
    @echo off
    rem File: post_build.bat
    rem IDE Post-Build command-line:
    rem $PROJ_DIR$/post_build.bat "$TOOLKIT_DIR$" "$PROJ_DIR$" "$TARGET_PATH$" "$TARGET_BPATH$"
    rem -----
    rem Description:
    rem   $TOOLKIT_DIR$  ~> <install-dir>/rl78
    rem   $PROJ_DIR$     ~> Project directory
    rem   $TARGET_PATH$  ~> Full path of primary output file
    rem   $TARGET_BPATH$ ~> Full path of primary output file without extension
    rem -----
    rem In the Build Window, set "Filter ~> All" to display the echo commands
    set TOOLKIT_DIR=%1
    set PROJ_DIR=%2
    set TARGET_PATH=%3
    set TARGET_BPATH=%4
    echo -- Copying ELF to the Bootloader Image dir...
    copy %TARGET_PATH% %USERPROFILE%\Desktop\IAR\Project_rl78g13\Bootloader\Image > NUL
    echo -- Converting ELF to SREC...
    %TOOLKIT_DIR%\bin\ielftool --silent --srec %TARGET_PATH% %TARGET_BPATH%.srec
    echo -- Converting ELF to BIN...
    %TOOLKIT_DIR%\bin\ielftool --silent --bin %TARGET_PATH% %TARGET_BPATH%.bin
    echo -- Exporting ELF symbols (using $PROJ_DIR$/my-steering-file.txt)...
    %TOOLKIT_DIR%\bin\isymexport %TARGET_PATH% %TARGET_BPATH%.symbols --edit "%PROJ_DIR%\my-steering-file.txt"
  • Hi Felipe
    a lot of thanks to solve my problem. Now its working fine.
