hello everyone,I am using the official program "Vector Control of Three-Phase Induction Motor Used in Driving a Pump RX66T Implementation Rev.1.10 - Sample Code". Currently, in order to test whether the unique value of my AD CONVERTER is correct, I give the voltage to the corner of the control board P62/AN208, but the value read from the register is not very close to the value I calculated. The current power supply is 5v, so I want to ask how to solve this problem?
RR
Hello, I think the resolution MTR_VDC_SCALING does not match.Hope this helps!
Regards,JefIf this response, or one provided by another user, answers your question, please verify the answer. Thank you!Renesas Engineering Community Moderatorshttps://community.renesas.com/https://academy.renesas.com/en-support.renesas.com/.../
Hello Jef,What do you mean by "MTR_VDC_SCALING does not match"? The circuit design of the inverter is indeed calculated in this way.Regards,RR
