I am going to use secure key installation, encryption function for RX140. So I need r_tsip_rx driver, as I understood.
These three files are included in the folder FITModules:
r_tsip_rx_v1.18.I.xml
r_tsip_rx_v1.18.I.zip
r_tsip_rx_v1.18.I_extend.mdf
But I can't find the driver inside the "Software component configuration", there is no r_tsip_rx to be added.
Hello dear Siva, Do you use a network or the internet on your device? The TSIP is designed to utilize the encryption engine to enhance the security of the IP.
Does it apply to your case? if not, Kindly introduce your application for secure key installation.
Regards,Hossein.
Hello Hossein,
No I don't use network or internet on my device, and I have found that I don't need TSIP. I have to use AES encryption as I understood. My goal is to encrypt the output file of my application and program the encrypted file by using my own custom bootloader.
Thank you
My question is how I can use secure key? any help?
I understand your purpose of using AES, just a heads up, AES is a symmetric encryption algorithm, and if somehow the key has been revealed your data will be vulnerable, I recommend using RX series with a cryptography engine that contains both RSA and AES.
By the way, it seems the AES Library and related user's manual aren't made public in this RX series and you'll need special access (If it is physically supported on your device). let me discuss this with our internal team, and they'll get back to you ASAP. Kind regards,
Hossein.
Thank you Hossein,
Looking forward to your update.
