Hello sir, I am using Misra "c" standard in my project but the the problem is i am using your FIT module code generator API and so that's why they are giving me lot's of error.you have any solution for that. I am attaching the error screen shot plz check and suggest me the solution.I am using misra c 2012.
Hi sir,
Can you please check in build tool that you have enabled the Misra c rules:
BR,
NP_Renesas
Hello sir, i want to use this rule.just tell me that your FTI module code are follow the misra 'C' 2012 standard or NOT ?if you have any solution for FIT module code then tell how to do this.
I can find no reference to conformance to MISRA-C in the FIT documentation, and considering your experience with the warnings I would assume the FIT does not conform.
Hello sir, We have taken the professional license software as one of your renesas employee suggestion and they told us Misra 'C' is support to our FIT and now you are saying that our FIT does not support the Misra "C" standard.so what can i do and give me the solution.Thanks and Regard's
Perhaps you should take this issue up with the Renesas employee who suggested to you that MISRA-C is supported by the FIT.
I am not a Renesas employee, I can only tell you what info I can find, and I find no reference to MISRA-C in any of the FIT documents, which tells me it was not considered for support with the FIT. Maybe I am wrong.
Hello NP_Renesas We have taken the professional license software as one of your renesas employee suggestion and they told us Misra 'C' is support to our FIT and now you are saying that our FIT does not support the Misra "C" standard.so what can i do and give me the solution.Thanks and Regard's
AK
