I am using CC-RX Compiler (IDE: CS+, MPU: RX64M).
I want to change the optimization level for only one function in a file. Is it possible?
I remember that it was possible in the old Hew Compiler because of the "#pragma option speed" keyword. However,
it seems that CS+ can only set the level on a per-file basis. If you know how, please help me.
Hello,Indeed, #pragma option directive is no longer available.An alternative would be to change the Optimization settings per-file. Open Property of the desired file and change the Set Individual Compile Option to YESThen, you can modify the Optimization settings for this file.Thank you,Panos
