I want to avoid external pull-up resistor on all my input pins because size of board.
I'm using RA6M4. I cannnot find the value of internal pull-up or pull-down of any pin in the datsheet of the MCU.
Can you tell me these values or where can I find them?
Thanks.
Did anyone ever get a response? I'm also looking for this information.
It's probably implemented as a depletion mode MOSFET with Idss of between 10uA and 300uA.
That's a huge range - if the actual value is important to your circuit, then disable it and add a resistor of known value.
