FreeRTOS ist Running and the LED1 ist brinking now I try to implement a PCDC Connection an the Device USBThe Stack are defined and the SMART Configurator is generated the Files for IAR Compiler JLink RTT View ShowHave you any idea why the USB Driver and Registred correct Cabel and Eval Board works fine if I Set the Bood Config Jumper and RA USB Boot is visible Do you have any idea why windows make Unknown USB device (Failed to request a device description.)I change VID & PID %DESCRIPTION%=DriverInstall, USB\VID_045B&PID_5300&MI_00but also with the same behaviour. My guess is on Windows side but maybe a setting is not correct in the Configurator Therefore the Configuration file is enclosed. Fullscreen 3264.configuration.xml Download <?xml version="1.0" encoding="UTF-8" standalone="no"?> <raConfiguration version="9"> <generalSettings> <option key="#Board#" value="board.ra6m1ek"/> <option key="CPU" value="RA6M1"/> <option key="Core" value="CM4"/> <option key="#TargetName#" value="R7FA6M1AD3CFP"/> <option key="#TargetARCHITECTURE#" value="cortex-m4"/> <option key="#DeviceCommand#" value="R7FA6M1AD"/> <option key="#RTOS#" value="rtos.awsfreertos"/> <option key="#pinconfiguration#" value="R7FA6M1AD3CFP.pincfg"/> <option key="#FSPVersion#" value="5.7.0"/> <option key="#ConfigurationFragments#" value="Renesas##BSP##Board##ra6m1_ek##"/> <option key="#SELECTED_TOOLCHAIN#" value="iar.arm.toolchain"/> </generalSettings> <raBspConfiguration> <config id="config.bsp.ra6m1.R7FA6M1AD3CFP"> <property id="config.bsp.part_number" value="config.bsp.part_number.value"/> <property id="config.bsp.rom_size_bytes" value="config.bsp.rom_size_bytes.value"/> <property id="config.bsp.rom_size_bytes_hidden" value="524288"/> <property id="config.bsp.ram_size_bytes" value="config.bsp.ram_size_bytes.value"/> <property id="config.bsp.data_flash_size_bytes" value="config.bsp.data_flash_size_bytes.value"/> <property id="config.bsp.package_style" value="config.bsp.package_style.value"/> <property id="config.bsp.package_pins" value="config.bsp.package_pins.value"/> <property id="config.bsp.irq_count_hidden" value="96"/> </config> <config id="config.bsp.ra6m1"> <property id="config.bsp.series" value="config.bsp.series.value"/> </config> <config id="config.bsp.ra6m1.fsp"> <property id="config.bsp.fsp.inline_irq_functions" value="config.bsp.common.inline_irq_functions.enabled"/> <property id="config.bsp.fsp.OFS0.iwdt_start_mode" value="config.bsp.fsp.OFS0.iwdt_start_mode.disabled"/> <property id="config.bsp.fsp.OFS0.iwdt_timeout" value="config.bsp.fsp.OFS0.iwdt_timeout.2048"/> <property id="config.bsp.fsp.OFS0.iwdt_divisor" value="config.bsp.fsp.OFS0.iwdt_divisor.128"/> <property id="config.bsp.fsp.OFS0.iwdt_window_end" value="config.bsp.fsp.OFS0.iwdt_window_end.0"/> <property id="config.bsp.fsp.OFS0.iwdt_window_start" value="config.bsp.fsp.OFS0.iwdt_window_start.100"/> <property id="config.bsp.fsp.OFS0.iwdt_reset_interrupt" value="config.bsp.fsp.OFS0.iwdt_reset_interrupt.Reset"/> <property id="config.bsp.fsp.OFS0.iwdt_stop_control" value="config.bsp.fsp.OFS0.iwdt_stop_control.stops"/> <property id="config.bsp.fsp.OFS0.wdt_start_mode" value="config.bsp.fsp.OFS0.wdt_start_mode.register"/> <property id="config.bsp.fsp.OFS0.wdt_timeout" value="config.bsp.fsp.OFS0.wdt_timeout.16384"/> <property id="config.bsp.fsp.OFS0.wdt_divisor" value="config.bsp.fsp.OFS0.wdt_divisor.128"/> <property id="config.bsp.fsp.OFS0.wdt_window_end" value="config.bsp.fsp.OFS0.wdt_window_end.0"/> <property id="config.bsp.fsp.OFS0.wdt_window_start" value="config.bsp.fsp.OFS0.wdt_window_start.100"/> <property id="config.bsp.fsp.OFS0.wdt_reset_interrupt" value="config.bsp.fsp.OFS0.wdt_reset_interrupt.Reset"/> <property id="config.bsp.fsp.OFS0.wdt_stop_control" value="config.bsp.fsp.OFS0.wdt_stop_control.stops"/> <property id="config.bsp.fsp.OFS1.voltage_detection0.start" value="config.bsp.fsp.OFS1.voltage_detection0.start.disabled"/> <property id="config.bsp.fsp.OFS1.voltage_detection0_level" value="config.bsp.fsp.OFS1.voltage_detection0_level.280"/> <property id="config.bsp.fsp.OFS1.hoco_osc" value="config.bsp.fsp.OFS1.hoco_osc.disabled"/> <property id="config.bsp.fsp.mpu_pc0_enable" value="config.bsp.fsp.mpu_pc0_enable.disabled"/> <property id="config.bsp.fsp.mpu_pc0_start" value="0xFFFFFFFC"/> <property id="config.bsp.fsp.mpu_pc0_end" value="0xFFFFFFFF"/> <property id="config.bsp.fsp.mpu_pc1_enable" value="config.bsp.fsp.mpu_pc1_enable.disabled"/> <property id="config.bsp.fsp.mpu_pc1_start" value="0xFFFFFFFC"/> <property id="config.bsp.fsp.mpu_pc1_end" value="0xFFFFFFFF"/> <property id="config.bsp.fsp.mpu_reg0_enable" value="config.bsp.fsp.mpu_reg0_enable.disabled"/> <property id="config.bsp.fsp.mpu_reg0_start" value="0x00FFFFFC"/> <property id="config.bsp.fsp.mpu_reg0_end" value="0x00FFFFFF"/> <property id="config.bsp.fsp.mpu_reg1_enable" value="config.bsp.fsp.mpu_reg1_enable.disabled"/> <property id="config.bsp.fsp.mpu_reg1_start" value="0x200FFFFC"/> <property id="config.bsp.fsp.mpu_reg1_end" value="0x200FFFFF"/> <property id="config.bsp.fsp.mpu_reg2_enable" value="config.bsp.fsp.mpu_reg2_enable.disabled"/> <property id="config.bsp.fsp.mpu_reg2_start" value="0x407FFFFC"/> <property id="config.bsp.fsp.mpu_reg2_end" value="0x407FFFFF"/> <property id="config.bsp.fsp.mpu_reg3_enable" value="config.bsp.fsp.mpu_reg3_enable.disabled"/> <property id="config.bsp.fsp.mpu_reg3_start" value="0x400DFFFC"/> <property id="config.bsp.fsp.mpu_reg3_end" value="0x400DFFFF"/> <property id="config.bsp.fsp.hoco_fll" value="config.bsp.fsp.hoco_fll.disabled"/> <property id="config.bsp.fsp.autodrven" value="config.bsp.fsp.autodrven.disabled"/> <property id="config.bsp.common.main_osc_wait" value="config.bsp.common.main_osc_wait.wait_8163"/> <property id="config.bsp.fsp.mcu.adc.max_freq_hz" value="60000000"/> <property id="config.bsp.fsp.mcu.sci_uart.max_baud" value="20000000"/> <property id="config.bsp.fsp.mcu.adc.sample_and_hold" value="1"/> <property id="config.bsp.fsp.mcu.adc.sensors_are_exclusive" value="0"/> <property id="config.bsp.fsp.mcu.sci_spi.max_bitrate" value="30000000"/> <property id="config.bsp.fsp.mcu.spi.max_bitrate" value="30000000"/> <property id="config.bsp.fsp.mcu.iic_master.rate.rate_fastplus" value="1"/> <property id="config.bsp.fsp.mcu.iic_master.fastplus_channels" value="0x1"/> <property id="config.bsp.fsp.mcu.iic_slave.rate.rate_fastplus" value="1"/> <property id="config.bsp.fsp.mcu.iic_slave.fastplus_channels" value="0x1"/> <property id="config.bsp.fsp.mcu.sci_uart.cstpen_channels" value="0x0"/> <property id="config.bsp.fsp.mcu.gpt.pin_count_source_channels" value="0xFFFF"/> <property id="config.bsp.common.id_mode" value="config.bsp.common.id_mode.unlocked"/> <property id="config.bsp.common.id_code" value="FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF"/> <property id="config.bsp.common.id1" value=""/> <property id="config.bsp.common.id2" value=""/> <property id="config.bsp.common.id3" value=""/> <property id="config.bsp.common.id4" value=""/> <property id="config.bsp.common.id_fixed" value=""/> </config> <config id="config.bsp.ra"> <property id="config.bsp.common.main" value="0x400"/> <property id="config.bsp.common.heap" value="0x400"/> <property id="config.bsp.common.vcc" value="3300"/> <property id="config.bsp.common.checking" value="config.bsp.common.checking.disabled"/> <property id="config.bsp.common.assert" value="config.bsp.common.assert.none"/> <property id="config.bsp.common.error_log" value="config.bsp.common.error_log.none"/> <property id="config.bsp.common.soft_reset" value="config.bsp.common.soft_reset.disabled"/> <property id="config.bsp.common.main_osc_populated" value="config.bsp.common.main_osc_populated.enabled"/> <property id="config.bsp.common.pfs_protect" value="config.bsp.common.pfs_protect.enabled"/> <property id="config.bsp.common.c_runtime_init" value="config.bsp.common.c_runtime_init.enabled"/> <property id="config.bsp.common.early_init" value="config.bsp.common.early_init.enabled"/> <property id="config.bsp.common.main_osc_clock_source" value="config.bsp.common.main_osc_clock_source.crystal"/> <property id="config.bsp.common.subclock_populated" value="config.bsp.common.subclock_populated.enabled"/> <property id="config.bsp.common.subclock_drive" value="config.bsp.common.subclock_drive.standard"/> <property id="config.bsp.common.subclock_stabilization_ms" value="1000"/> </config> </raBspConfiguration> <raClockConfiguration> <node id="board.clock.xtal.freq" mul="12000000" option="_edit"/> <node id="board.clock.pll.source" option="board.clock.pll.source.xtal"/> <node id="board.clock.hoco.freq" option="board.clock.hoco.freq.20m"/> <node id="board.clock.loco.freq" option="board.clock.loco.freq.32768"/> <node id="board.clock.moco.freq" option="board.clock.moco.freq.8m"/> <node id="board.clock.subclk.freq" option="board.clock.subclk.freq.32768"/> <node id="board.clock.pll.div" option="board.clock.pll.div.1"/> <node id="board.clock.pll.mul" option="board.clock.pll.mul.200"/> <node id="board.clock.pll.display" option="board.clock.pll.display.value"/> <node id="board.clock.clock.source" option="board.clock.clock.source.pll"/> <node id="board.clock.iclk.div" option="board.clock.iclk.div.2"/> <node id="board.clock.iclk.display" option="board.clock.iclk.display.value"/> <node id="board.clock.pclka.div" option="board.clock.pclka.div.2"/> <node id="board.clock.pclka.display" option="board.clock.pclka.display.value"/> <node id="board.clock.pclkb.div" option="board.clock.pclkb.div.4"/> <node id="board.clock.pclkb.display" option="board.clock.pclkb.display.value"/> <node id="board.clock.pclkc.div" option="board.clock.pclkc.div.4"/> <node id="board.clock.pclkc.display" option="board.clock.pclkc.display.value"/> <node id="board.clock.pclkd.div" option="board.clock.pclkd.div.2"/> <node id="board.clock.pclkd.display" option="board.clock.pclkd.display.value"/> <node id="board.clock.bclk.div" option="board.clock.bclk.div.2"/> <node id="board.clock.bclk.display" option="board.clock.bclk.display.value"/> <node id="board.clock.bclkout.div" option="board.clock.bclkout.div.2"/> <node id="board.clock.bclkout.display" option="board.clock.bclkout.display.value"/> <node id="board.clock.uclk.div" option="board.clock.uclk.div.5"/> <node id="board.clock.uclk.display" option="board.clock.uclk.display.value"/> <node id="board.clock.fclk.div" option="board.clock.fclk.div.4"/> <node id="board.clock.fclk.display" option="board.clock.fclk.display.value"/> <node id="board.clock.clkout.source" option="board.clock.clkout.source.disabled"/> <node id="board.clock.clkout.div" option="board.clock.clkout.div.1"/> <node id="board.clock.clkout.display" option="board.clock.clkout.display.value"/> </raClockConfiguration> <raComponentSelection> <component apiversion="" class="Projects" condition="" group="all" subgroup="freertos_blinky" variant="" vendor="Renesas" version="5.7.0"> <description>Simple application that blinks an LED using FreeRTOS.</description> <originalPack>Renesas.RA_freertos_blinky.5.7.0.pack</originalPack> </component> <component apiversion="" class="Common" condition="" group="all" subgroup="fsp_common" variant="" vendor="Renesas" version="5.7.0"> <description>Board Support Package Common Files</description> <originalPack>Renesas.RA.5.7.0.pack</originalPack> </component> <component apiversion="" class="HAL Drivers" condition="" group="all" subgroup="r_ioport" variant="" vendor="Renesas" version="5.7.0"> <description>I/O Port</description> <originalPack>Renesas.RA.5.7.0.pack</originalPack> </component> <component apiversion="" class="RTOS" condition="" group="FreeRTOS" subgroup="all" variant="" vendor="AWS" version="10.6.1+fsp.5.7.0"> <description>FreeRTOS</description> <originalPack>Amazon.FreeRTOS-Kernel.10.6.1+fsp.5.7.0.pack</originalPack> </component> <component apiversion="" class="CMSIS" condition="" group="CMSIS5" subgroup="CoreM" variant="" vendor="Arm" version="6.1.0+fsp.5.7.0"> <description>Arm CMSIS Version 6 - Core (M)</description> <originalPack>Arm.CMSIS6.6.1.0+fsp.5.7.0.pack</originalPack> </component> <component apiversion="" class="Middleware" condition="" group="all" subgroup="rm_freertos_port" variant="" vendor="Renesas" version="5.7.0"> <description>FreeRTOS Port</description> <originalPack>Renesas.RA.5.7.0.pack</originalPack> </component> <component apiversion="" class="BSP" condition="" group="ra6m1" subgroup="device" variant="R7FA6M1AD3CFP" vendor="Renesas" version="5.7.0"> <description>Board support package for R7FA6M1AD3CFP</description> <originalPack>Renesas.RA_mcu_ra6m1.5.7.0.pack</originalPack> </component> <component apiversion="" class="BSP" condition="" group="ra6m1" subgroup="device" variant="" vendor="Renesas" version="5.7.0"> <description>Board support package for RA6M1</description> <originalPack>Renesas.RA_mcu_ra6m1.5.7.0.pack</originalPack> </component> <component apiversion="" class="BSP" condition="" group="ra6m1" subgroup="fsp" variant="" vendor="Renesas" version="5.7.0"> <description>Board support package for RA6M1 - FSP Data</description> <originalPack>Renesas.RA_mcu_ra6m1.5.7.0.pack</originalPack> </component> <component apiversion="" class="BSP" condition="" group="ra6m1" subgroup="events" variant="" vendor="Renesas" version="5.7.0"> <description>Board support package for RA6M1 - Events</description> <originalPack>Renesas.RA_mcu_ra6m1.5.7.0.pack</originalPack> </component> <component apiversion="" class="BSP" condition="" group="Board" subgroup="ra6m1_ek" variant="" vendor="Renesas" version="5.7.0"> <description>RA6M1-EK Board Support Files</description> <originalPack>Renesas.RA_board_ra6m1_ek.5.7.0.pack</originalPack> </component> <component apiversion="" class="HAL Drivers" condition="" group="all" subgroup="r_dmac" variant="" vendor="Renesas" version="5.7.0"> <description>Direct Memory Access Controller</description> <originalPack>Renesas.RA.5.7.0.pack</originalPack> </component> <component apiversion="" class="HAL Drivers" condition="" group="all" subgroup="r_sci_uart" variant="" vendor="Renesas" version="5.7.0"> <description>SCI UART</description> <originalPack>Renesas.RA.5.7.0.pack</originalPack> </component> <component apiversion="" class="HAL Drivers" condition="" group="all" subgroup="r_usb_basic" variant="" vendor="Renesas" version="5.7.0"> <description>USB Basic</description> <originalPack>Renesas.RA.5.7.0.pack</originalPack> </component> <component apiversion="" class="Heaps" condition="" group="FreeRTOS" subgroup="heap_4" variant="" vendor="AWS" version="10.6.1+fsp.5.7.0"> <description>FreeRTOS - Memory Management - Heap 4</description> <originalPack>Amazon.FreeRTOS-Kernel.10.6.1+fsp.5.7.0.pack</originalPack> </component> <component apiversion="" class="HAL Drivers" condition="" group="all" subgroup="r_usb_pcdc" variant="" vendor="Renesas" version="5.7.0"> <description>USB Peripheral Communications Device Class</description> <originalPack>Renesas.RA.5.7.0.pack</originalPack> </component> </raComponentSelection> <raElcConfiguration/> <raIcuConfiguration/> <raModuleConfiguration> <module id="module.driver.ioport_on_ioport.0"> <property id="module.driver.ioport.name" value="g_ioport"/> <property id="module.driver.ioport.elc_trigger_ioport1" value="_disabled"/> <property id="module.driver.ioport.elc_trigger_ioport2" value="_disabled"/> <property id="module.driver.ioport.elc_trigger_ioport3" value="_disabled"/> <property id="module.driver.ioport.elc_trigger_ioport4" value="_disabled"/> <property id="module.driver.ioport.pincfg" value="g_bsp_pin_cfg"/> </module> <module id="module.middleware.rm_freertos_port.0"/> <module id="module.driver.uart_on_sci_uart.898063114"> <property id="module.driver.uart.name" value="g_uart"/> <property id="module.driver.uart.channel" value="0"/> <property id="module.driver.uart.data_bits" value="module.driver.uart.data_bits.data_bits_8"/> <property id="module.driver.uart.parity" value="module.driver.uart.parity.parity_off"/> <property id="module.driver.uart.stop_bits" value="module.driver.uart.stop_bits.stop_bits_1"/> <property id="module.driver.uart.baud" value="115200"/> <property id="module.driver.uart.baudrate_modulation" value="module.driver.uart.baudrate_modulation.disabled"/> <property id="module.driver.uart.baudrate_max_err" value="5"/> <property id="module.driver.uart.flow_control" value="module.driver.uart.flow_control.rts"/> <property id="module.driver.uart.pin_control_port" value="module.driver.uart.pin_control_port.PORT_DISABLE"/> <property id="module.driver.uart.pin_control_pin" value="module.driver.uart.pin_control_pin.PIN_DISABLE"/> <property id="module.driver.uart.clk_src" value="module.driver.uart.clk_src.int_clk"/> <property id="module.driver.uart.rx_edge_start" value="module.driver.uart.rx_edge_start.falling_edge"/> <property id="module.driver.uart.noisecancel_en" value="module.driver.uart.noisecancel_en.disabled"/> <property id="module.driver.uart.rx_fifo_trigger" value="module.driver.uart.rx_fifo_trigger.max"/> <property id="module.driver.uart.irda.ire" value="module.driver.uart.irda.ire.disabled"/> <property id="module.driver.uart.irda.irrxinv" value="module.driver.uart.irda.irrxinv.disabled"/> <property id="module.driver.uart.irda.irtxinv" value="module.driver.uart.irda.irtxinv.disabled"/> <property id="module.driver.uart.rs485.de_enable" value="module.driver.uart.rs485.de_enable.disabled"/> <property id="module.driver.uart.rs485.de_polarity" value="module.driver.uart.rs485.de_polarity.high"/> <property id="module.driver.uart.rs485.de_port_number" value="module.driver.uart.rs485.de_port_number.PORT_DISABLE"/> <property id="module.driver.uart.rs485.de_pin_number" value="module.driver.uart.rs485.de_pin_number.PIN_DISABLE"/> <property id="module.driver.uart.callback" value="user_uart_callback"/> <property id="module.driver.uart.rxi_ipl" value="board.icu.common.irq.priority12"/> <property id="module.driver.uart.txi_ipl" value="board.icu.common.irq.priority12"/> <property id="module.driver.uart.tei_ipl" value="board.icu.common.irq.priority12"/> <property id="module.driver.uart.eri_ipl" value="board.icu.common.irq.priority12"/> </module> <module id="module.freertos.heap.4.2124487684"/> <module id="module.driver.pcdc_on_usb.1795914684"> <property id="module.driver.pcdc.name" value="g_pcdc0"/> </module> <module id="module.driver.basic_on_usb.319634493"> <property id="module.driver.basic.name" value="g_basic"/> <property id="module.driver.usb_basic.usb_mode" value="module.driver.usb_basic.usb_mode.host"/> <property id="module.driver.usb_basic.usb_speed" value="module.driver.usb_basic.usb_speed.fs"/> <property id="module.driver.usb_basic.usb_modulenumber" value="module.driver.usb_basic.usb_modulenumber.0"/> <property id="module.driver.usb_basic.usb_classtype" value="module.driver.usb_basic.usb_classtype.pcdc"/> <property id="module.driver.usb_basic.p_usb_reg" value="g_usb_descriptor"/> <property id="module.driver.usb_basic.complience_cb" value="NULL"/> <property id="module.driver.usb_basic.ipl" value="board.icu.common.irq.priority12"/> <property id="module.driver.usb_basic.ipl_r" value="board.icu.common.irq.priority12"/> <property id="module.driver.usb_basic.ipl_d0" value="board.icu.common.irq.priority12"/> <property id="module.driver.usb_basic.ipl_d1" value="board.icu.common.irq.priority12"/> <property id="module.driver.usb_basic.hsipl" value="_disabled"/> <property id="module.driver.usb_basic.hsipl_d0" value="_disabled"/> <property id="module.driver.usb_basic.hsipl_d1" value="_disabled"/> <property id="module.driver.usb_basic.rtos_callback" value="usb_pcdc_callback"/> <property id="module.driver.usb_basic.other_context" value="NULL"/> </module> <module id="module.driver.transfer_on_dmac.222273596"> <property id="module.driver.transfer.name" value="g_transfer0"/> <property id="module.driver.transfer.channel" value="0"/> <property id="module.driver.transfer.mode" value="module.driver.transfer.mode.mode_normal"/> <property id="module.driver.transfer.size" value="module.driver.transfer.size.size_2_byte"/> <property id="module.driver.transfer.dest_addr_mode" value="module.driver.transfer.dest_addr_mode.addr_mode_fixed"/> <property id="module.driver.transfer.src_addr_mode" value="module.driver.transfer.src_addr_mode.addr_mode_fixed"/> <property id="module.driver.transfer.repeat_area" value="module.driver.transfer.repeat_area.repeat_area_source"/> <property id="module.driver.transfer.length" value="1"/> <property id="module.driver.transfer.num_blocks" value="0"/> <property id="module.driver.transfer.activation_event" value="_signal.event.usbfs.fifo.1"/> <property id="module.driver.transfer.p_callback" value="NULL"/> <property id="module.driver.transfer.ipl" value="_disabled"/> <property id="module.driver.transfer.interrupt" value="module.driver.transfer.interrupt.interrupt_end"/> <property id="module.driver.transfer.offset" value="1"/> <property id="module.driver.transfer.src.buffer" value="1"/> </module> <module id="module.driver.transfer_on_dmac.58726906"> <property id="module.driver.transfer.name" value="g_transfer1"/> <property id="module.driver.transfer.channel" value="2"/> <property id="module.driver.transfer.mode" value="module.driver.transfer.mode.mode_normal"/> <property id="module.driver.transfer.size" value="module.driver.transfer.size.size_2_byte"/> <property id="module.driver.transfer.dest_addr_mode" value="module.driver.transfer.dest_addr_mode.addr_mode_fixed"/> <property id="module.driver.transfer.src_addr_mode" value="module.driver.transfer.src_addr_mode.addr_mode_fixed"/> <property id="module.driver.transfer.repeat_area" value="module.driver.transfer.repeat_area.repeat_area_source"/> <property id="module.driver.transfer.length" value="1"/> <property id="module.driver.transfer.num_blocks" value="0"/> <property id="module.driver.transfer.activation_event" value="_signal.event.usbfs.fifo.0"/> <property id="module.driver.transfer.p_callback" value="NULL"/> <property id="module.driver.transfer.ipl" value="_disabled"/> <property id="module.driver.transfer.interrupt" value="module.driver.transfer.interrupt.interrupt_end"/> <property id="module.driver.transfer.offset" value="1"/> <property id="module.driver.transfer.src.buffer" value="1"/> </module> <object id="rtos.awsfreertos.object.mutex.680981051"> <property id="rtos.awsfreertos.object.mutex.symbol" value="g_uart_tx_mutex"/> <property id="rtos.awsfreertos.object.mutex.type" value="rtos.awsfreertos.object.mutex.type.recursive_mutex"/> <property id="rtos.awsfreertos.object.mutex.allocation" value="rtos.awsfreertos.object.mutex.allocation.static"/> </object> <object id="rtos.awsfreertos.object.binary_semaphore.74685187"> <property id="rtos.awsfreertos.object.binary_semaphore.symbol" value="g_usb_tx_semaphore"/> <property id="rtos.awsfreertos.object.binary_semaphore.allocation" value="rtos.awsfreertos.object.binary_semaphore.allocation.dynamic"/> </object> <object id="rtos.awsfreertos.object.queue.1345654037"> <property id="rtos.awsfreertos.object.queue.symbol" value="g_usb_tx_x2_queue"/> <property id="rtos.awsfreertos.object.queue.item_size" value="2"/> <property id="rtos.awsfreertos.object.queue.queue_length" value="512"/> <property id="rtos.awsfreertos.object.queue.allocation" value="rtos.awsfreertos.object.queue.allocation.dynamic"/> </object> <object id="rtos.awsfreertos.object.queue.743175010"> <property id="rtos.awsfreertos.object.queue.symbol" value="g_event_queue"/> <property id="rtos.awsfreertos.object.queue.item_size" value="2"/> <property id="rtos.awsfreertos.object.queue.queue_length" value="512"/> <property id="rtos.awsfreertos.object.queue.allocation" value="rtos.awsfreertos.object.queue.allocation.static"/> </object> <object id="rtos.awsfreertos.object.queue.1556856096"> <property id="rtos.awsfreertos.object.queue.symbol" value="g_usb_tx_queue"/> <property id="rtos.awsfreertos.object.queue.item_size" value="2"/> <property id="rtos.awsfreertos.object.queue.queue_length" value="512"/> <property id="rtos.awsfreertos.object.queue.allocation" value="rtos.awsfreertos.object.queue.allocation.static"/> </object> <context id="_hal.0"> <stack module="module.driver.ioport_on_ioport.0"/> <stack module="module.middleware.rm_freertos_port.0"/> <stack module="module.driver.uart_on_sci_uart.898063114"/> </context> <context id="rtos.awsfreertos.thread.0"> <property id="_symbol" value="blinky_thread"/> <property id="rtos.awsfreertos.thread.name" value="Blinky Thread"/> <property id="rtos.awsfreertos.thread.stack" value="128"/> <property id="rtos.awsfreertos.thread.priority" value="1"/> <property id="rtos.awsfreertos.thread.context" value="NULL"/> <property id="rtos.awsfreertos.thread.allocation" value="rtos.awsfreertos.thread.allocation.dynamic"/> <property id="rtos.awsfreertos.thread.secure_context" value="rtos.awsfreertos.thread.secure_context.disable"/> </context> <context id="rtos.awsfreertos.thread.2127650538"> <property id="_symbol" value="pcdc_thread"/> <property id="rtos.awsfreertos.thread.name" value="PCDC Thread"/> <property id="rtos.awsfreertos.thread.stack" value="384"/> <property id="rtos.awsfreertos.thread.priority" value="2"/> <property id="rtos.awsfreertos.thread.context" value="NULL"/> <property id="rtos.awsfreertos.thread.allocation" value="rtos.awsfreertos.thread.allocation.dynamic"/> <property id="rtos.awsfreertos.thread.secure_context" value="rtos.awsfreertos.thread.secure_context.disable"/> <stack module="module.freertos.heap.4.2124487684"/> <stack module="module.driver.pcdc_on_usb.1795914684"> <stack module="module.driver.basic_on_usb.319634493" requires="module.driver.basic_on_usb.requires.basic"> <stack module="module.driver.transfer_on_dmac.222273596" requires="module.driver.basic_on_usb.requires.transfer_tx"/> <stack module="module.driver.transfer_on_dmac.58726906" requires="module.driver.basic_on_usb.requires.transfer_rx"/> </stack> </stack> </context> <config id="config.driver.usb_basic"> <property id="config.driver.usb_basic.param_checking_enable" value="config.driver.usb_basic.param_checking_enable.bsp"/> <property id="config.driver.usb_basic.pll_clock_frequency" value="config.driver.usb_basic.pll_clock_frequency.24mhz"/> <property id="config.driver.usb_basic.buswait" value="config.driver.usb_basic.buswait.0"/> <property id="config.driver.usb_basic.bc_function" value="config.driver.usb_basic.bc_function.disable"/> <property id="config.driver.usb_basic.power_source" value="config.driver.usb_basic.power_source.high"/> <property id="config.driver.usb_basic.dcp_function" value="config.driver.usb_basic.dcp_function.disable"/> <property id="config.driver.usb_basic.request" value="config.driver.usb_basic.request.enable"/> <property id="config.driver.usb_basic.dblb" value="config.driver.usb_basic.dblb.enable"/> <property id="config.driver.usb_basic.cntmd" value="config.driver.usb_basic.cntmd.disable"/> <property id="config.driver.usb_basic.ldo_regulator" value="config.driver.usb_basic.ldo_regulator.disable"/> <property id="config.driver.usb_basic.type_c" value="config.driver.usb_basic.type_c.disable"/> <property id="config.driver.usb_basic.dma" value="config.driver.usb_basic.dma.enable"/> <property id="config.driver.usb_basic.source_address" value="config.driver.usb_basic.source_address.fs_use"/> <property id="config.driver.usb_basic.dest_address" value="config.driver.usb_basic.dest_address.fs_use"/> <property id="config.driver.usb_basic.compliance_mode" value="config.driver.usb_basic.compliance_mode.disable"/> <property id="config.driver.usb_basic.tpl_table" value="NULL"/> </config> <config id="config.driver.dmac"> <property id="config.driver.dmac.param_checking_enable" value="config.driver.dmac.param_checking_enable.bsp"/> </config> <config id="config.driver.sci_uart"> <property id="config.driver.sci_uart.param_checking_enable" value="config.driver.sci_uart.param_checking_enable.bsp"/> <property id="config.driver.sci_uart.fifo_support" value="config.driver.sci_uart.fifo_support.disabled"/> <property id="config.driver.sci_uart.dtc_support" value="config.driver.sci_uart.dtc_support.disabled"/> <property id="config.driver.sci_uart.flow_control" value="config.driver.sci_uart.flow_control.disabled"/> <property id="config.driver.sci_uart.rs485" value="config.driver.sci_uart.rs485.disabled"/> <property id="config.driver.sci_uart.irda" value="config.driver.sci_uart.irda.disabled"/> </config> <config id="config.driver.usb_pcdc"> <property id="config.driver.usb_pcdc.bulk_in" value="config.driver.usb_pcdc.bulk_in.pipe1"/> <property id="config.driver.usb_pcdc.bulk_out" value="config.driver.usb_pcdc.bulk_out.pipe2"/> <property id="config.driver.usb_pcdc.int_in" value="config.driver.usb_pcdc.int_in.pipe6"/> </config> <config id="config.driver.usb_pcdc_class"/> <config id="config.driver.ioport"> <property id="config.driver.ioport.checking" value="config.driver.ioport.checking.system"/> </config> <config id="config.awsfreertos.thread"> <property id="config.awsfreertos.custom_freertosconfig" value=""/> <property id="config.awsfreertos.thread.configuse_preemption" value="config.awsfreertos.thread.configuse_preemption.enabled"/> <property id="config.awsfreertos.thread.configuse_port_optimised_task_selection" value="config.awsfreertos.thread.configuse_port_optimised_task_selection.enabled"/> <property id="config.awsfreertos.thread.configuse_tickless_idle" value="config.awsfreertos.thread.configuse_tickless_idle.enabled"/> <property id="config.awsfreertos.thread.configuse_idle_hook" value="config.awsfreertos.thread.configuse_idle_hook.enabled"/> <property id="config.awsfreertos.thread.configuse_malloc_failed_hook" value="config.awsfreertos.thread.configuse_malloc_failed_hook.disabled"/> <property id="config.awsfreertos.thread.configuse_daemon_task_startup_hook" value="config.awsfreertos.thread.configuse_daemon_task_startup_hook.disabled"/> <property id="config.awsfreertos.thread.configuse_tick_hook" value="config.awsfreertos.thread.configuse_tick_hook.disabled"/> <property id="config.awsfreertos.thread.configcpu_clock_hz" value="SystemCoreClock"/> <property id="config.awsfreertos.thread.configtick_rate_hz" value="1000"/> <property id="config.awsfreertos.thread.configmax_priorities" value="5"/> <property id="config.awsfreertos.thread.configminimal_stack_size" value="128"/> <property id="config.awsfreertos.thread.configmax_task_name_len" value="16"/> <property id="config.awsfreertos.thread.configuse_trace_facility" value="config.awsfreertos.thread.configuse_trace_facility.disabled"/> <property id="config.awsfreertos.thread.configuse_stats_formatting_functions" value="config.awsfreertos.thread.configuse_stats_formatting_functions.disabled"/> <property id="config.awsfreertos.thread.configuse_16_bit_ticks" value="config.awsfreertos.thread.configuse_16_bit_ticks.disabled"/> <property id="config.awsfreertos.thread.configidle_should_yield" value="config.awsfreertos.thread.configidle_should_yield.enabled"/> <property id="config.awsfreertos.thread.configuse_task_notifications" value="config.awsfreertos.thread.configuse_task_notifications.enabled"/> <property id="config.awsfreertos.thread.configtask_notifications_array_enteries" value="1"/> <property id="config.awsfreertos.thread.configuse_mutexes" value="config.awsfreertos.thread.configuse_mutexes.enabled"/> <property id="config.awsfreertos.thread.configuse_recursive_mutexes" value="config.awsfreertos.thread.configuse_recursive_mutexes.enabled"/> <property id="config.awsfreertos.thread.configuse_counting_semaphores" value="config.awsfreertos.thread.configuse_counting_semaphores.enabled"/> <property id="config.awsfreertos.thread.configcheck_for_stack_overflow" value="config.awsfreertos.thread.configcheck_for_stack_overflow.disabled"/> <property id="config.awsfreertos.thread.configqueue_registry_size" value="10"/> <property id="config.awsfreertos.thread.configuse_queue_sets" value="config.awsfreertos.thread.configuse_queue_sets.disabled"/> <property id="config.awsfreertos.thread.configuse_time_slicing" value="config.awsfreertos.thread.configuse_time_slicing.disabled"/> <property id="config.awsfreertos.thread.configuse_newlib_reentrant" value="config.awsfreertos.thread.configuse_newlib_reentrant.disabled"/> <property id="config.awsfreertos.thread.configenable_backward_compatibility" value="config.awsfreertos.thread.configenable_backward_compatibility.disabled"/> <property id="config.awsfreertos.thread.confignum_thread_local_storage_pointers" value="5"/> <property id="config.awsfreertos.thread.configstack_depth_type" value="uint32_t"/> <property id="config.awsfreertos.thread.configmessage_buffer_length_type" value="size_t"/> <property id="config.awsfreertos.thread.configheap_clear_memory_on_free" value="config.awsfreertos.thread.configheap_clear_memory_on_free.enabled"/> <property id="config.awsfreertos.thread.configsupport_static_allocation" value="config.awsfreertos.thread.configsupport_static_allocation.enabled"/> <property id="config.awsfreertos.thread.configsupport_dynamic_allocation" value="config.awsfreertos.thread.configsupport_dynamic_allocation.enabled"/> <property id="config.awsfreertos.thread.configtotal_heap_size" value="0x2000"/> <property id="config.awsfreertos.thread.configapplication_allocated_heap" value="config.awsfreertos.thread.configapplication_allocated_heap.enabled"/> <property id="config.awsfreertos.thread.configgenerate_run_time_stats" value="config.awsfreertos.thread.configgenerate_run_time_stats.disabled"/> <property id="config.awsfreertos.thread.configuse_timers" value="config.awsfreertos.thread.configuse_timers.enabled"/> <property id="config.awsfreertos.thread.configtimer_task_priority" value="3"/> <property id="config.awsfreertos.thread.configtimer_queue_length" value="10"/> <property id="config.awsfreertos.thread.configtimer_task_stack_depth" value="128"/> <property id="config.awsfreertos.thread.configlibrary_max_syscall_interrupt_priority" value="board.icu.common.irq.priority1"/> <property id="config.awsfreertos.thread.configassert" value="assert(x)"/> <property id="config.awsfreertos.thread.configinclude_application_defined_privileged_functions" value="config.awsfreertos.thread.configinclude_application_defined_privileged_functions.disabled"/> <property id="config.awsfreertos.thread.include_vtaskpriorityset" value="config.awsfreertos.thread.include_vtaskpriorityset.enabled"/> <property id="config.awsfreertos.thread.include_uxtaskpriorityget" value="config.awsfreertos.thread.include_uxtaskpriorityget.enabled"/> <property id="config.awsfreertos.thread.include_vtaskdelete" value="config.awsfreertos.thread.include_vtaskdelete.enabled"/> <property id="config.awsfreertos.thread.include_vtasksuspend" value="config.awsfreertos.thread.include_vtasksuspend.enabled"/> <property id="config.awsfreertos.thread.include_xresumefromisr" value="config.awsfreertos.thread.include_xresumefromisr.enabled"/> <property id="config.awsfreertos.thread.include_vtaskdelayuntil" value="config.awsfreertos.thread.include_vtaskdelayuntil.enabled"/> <property id="config.awsfreertos.thread.include_vtaskdelay" value="config.awsfreertos.thread.include_vtaskdelay.enabled"/> <property id="config.awsfreertos.thread.include_xtaskgetschedulerstate" value="config.awsfreertos.thread.include_xtaskgetschedulerstate.enabled"/> <property id="config.awsfreertos.thread.include_xtaskgetcurrenttaskhandle" value="config.awsfreertos.thread.include_xtaskgetcurrenttaskhandle.enabled"/> <property id="config.awsfreertos.thread.include_uxtaskgetstackhighwatermark" value="config.awsfreertos.thread.include_uxtaskgetstackhighwatermark.disabled"/> <property id="config.awsfreertos.thread.include_xtaskgetidletaskhandle" value="config.awsfreertos.thread.include_xtaskgetidletaskhandle.disabled"/> <property id="config.awsfreertos.thread.include_etaskgetstate" value="config.awsfreertos.thread.include_etaskgetstate.disabled"/> <property id="config.awsfreertos.thread.include_xeventgroupsetbitfromisr" value="config.awsfreertos.thread.include_xeventgroupsetbitfromisr.enabled"/> <property id="config.awsfreertos.thread.include_xtimerpendfunctioncall" value="config.awsfreertos.thread.include_xtimerpendfunctioncall.enabled"/> <property id="config.awsfreertos.thread.include_xtaskabortdelay" value="config.awsfreertos.thread.include_xtaskabortdelay.disabled"/> <property id="config.awsfreertos.thread.include_xtaskgethandle" value="config.awsfreertos.thread.include_xtaskgethandle.disabled"/> <property id="config.awsfreertos.thread.include_xtaskresumefromisr" value="config.awsfreertos.thread.include_xtaskresumefromisr.enabled"/> <property id="config.awsfreertos.thread.include_hw_stack_monitor" value="config.awsfreertos.thread.include_hw_stack_monitor.disabled"/> <property id="config.awsfreertos.thread.print_function" value="vLoggingPrint(x)"/> <property id="config.awsfreertos.thread.include_time_and_task" value="config.awsfreertos.thread.include_time_and_task.disabled"/> <property id="config.awsfreertos.thread.debug_logging_name" value="Log Name"/> <property id="config.awsfreertos.thread.logging_level" value="config.awsfreertos.thread.logging_level.log_none"/> </config> </raModuleConfiguration> <raPinConfiguration> <pincfg active="true" name="RA6M1-EK.pincfg" selected="true" symbol="g_bsp_pin_cfg"> <configSetting altId="adc1.an00.p004" configurationId="adc1.an00"/> <configSetting altId="adc1.mode.custom" configurationId="adc1.mode"/> <configSetting altId="ctsu0.mode.enabled" configurationId="ctsu0.mode"/> <configSetting altId="ctsu0.ts02.p207" configurationId="ctsu0.ts02"/> <configSetting altId="ctsu0.tscap.p205" configurationId="ctsu0.tscap"/> <configSetting altId="debug0.mode.jtag" configurationId="debug0.mode"/> <configSetting altId="debug0.tck.p300" configurationId="debug0.tck"/> <configSetting altId="debug0.tdi.p110" configurationId="debug0.tdi"/> <configSetting altId="debug0.tdo.p109" configurationId="debug0.tdo"/> <configSetting altId="debug0.tms.p108" configurationId="debug0.tms"/> <configSetting altId="p004.asel" configurationId="p004"/> <configSetting altId="p004.gpio_mode.gpio_mode_an" configurationId="p004.gpio_mode"/> <configSetting altId="p100.spi0.miso" configurationId="p100"/> <configSetting altId="p100.gpio_mode.gpio_mode_peripheral" configurationId="p100.gpio_mode"/> <configSetting altId="p101.spi0.mosi" configurationId="p101"/> <configSetting altId="p101.gpio_mode.gpio_mode_peripheral" configurationId="p101.gpio_mode"/> <configSetting altId="p102.spi0.rspck" configurationId="p102"/> <configSetting altId="p102.gpio_mode.gpio_mode_peripheral" configurationId="p102.gpio_mode"/> <configSetting altId="p103.spi0.ssl0" configurationId="p103"/> <configSetting altId="p103.gpio_mode.gpio_mode_peripheral" configurationId="p103.gpio_mode"/> <configSetting altId="p104.sci8.rxd" configurationId="p104"/> <configSetting altId="p104.gpio_mode.gpio_mode_peripheral" configurationId="p104.gpio_mode"/> <configSetting altId="p105.sci8.txd" configurationId="p105"/> <configSetting altId="p105.gpio_mode.gpio_mode_peripheral" configurationId="p105.gpio_mode"/> <configSetting altId="p106.output.low" configurationId="p106"/> <configSetting altId="p106.gpio_mode.gpio_mode_out.low" configurationId="p106.gpio_mode"/> <configSetting altId="p107.output.low" configurationId="p107"/> <configSetting altId="p107.gpio_mode.gpio_mode_out.low" configurationId="p107.gpio_mode"/> <configSetting altId="p108.debug0.tms" configurationId="p108"/> <configSetting altId="p108.gpio_mode.gpio_mode_peripheral" configurationId="p108.gpio_mode"/> <configSetting altId="p109.debug0.tdo" configurationId="p109"/> <configSetting altId="p109.gpio_mode.gpio_mode_peripheral" configurationId="p109.gpio_mode"/> <configSetting altId="p110.debug0.tdi" configurationId="p110"/> <configSetting altId="p110.gpio_mode.gpio_mode_peripheral" configurationId="p110.gpio_mode"/> <configSetting altId="p112.output.low" configurationId="p112"/> <configSetting altId="p112.gpio_mode.gpio_mode_out.low" configurationId="p112.gpio_mode"/> <configSetting altId="p201.input" configurationId="p201"/> <configSetting altId="p201.gpio_mode.gpio_mode_in" configurationId="p201.gpio_mode"/> <configSetting altId="p205.ctsu0.tscap" configurationId="p205"/> <configSetting altId="p205.gpio_mode.gpio_mode_peripheral" configurationId="p205.gpio_mode"/> <configSetting altId="p207.ctsu0.ts02" configurationId="p207"/> <configSetting altId="p207.gpio_mode.gpio_mode_peripheral" configurationId="p207.gpio_mode"/> <configSetting altId="p300.debug0.tck" configurationId="p300"/> <configSetting altId="p300.gpio_mode.gpio_mode_peripheral" configurationId="p300.gpio_mode"/> <configSetting altId="p407.usbfs0.vbus" configurationId="p407"/> <configSetting altId="p407.gpio_mode.gpio_mode_peripheral" configurationId="p407.gpio_mode"/> <configSetting altId="sci8.mode.asynchronous.free" configurationId="sci8.mode"/> <configSetting altId="sci8.rxd.p104" configurationId="sci8.rxd"/> <configSetting altId="sci8.txd.p105" configurationId="sci8.txd"/> <configSetting altId="spi0.miso.p100" configurationId="spi0.miso"/> <configSetting altId="spi0.mode.enabled.a" configurationId="spi0.mode"/> <configSetting altId="spi0.mosi.p101" configurationId="spi0.mosi"/> <configSetting altId="spi0.rspck.p102" configurationId="spi0.rspck"/> <configSetting altId="spi0.ssl0.p103" configurationId="spi0.ssl0"/> <configSetting altId="usbfs0.mode.device" configurationId="usbfs0.mode"/> <configSetting altId="usbfs0.vbus.p407" configurationId="usbfs0.vbus"/> </pincfg> <pincfg active="false" name="R7FA6M1AD3CFP.pincfg" selected="false" symbol=""> <configSetting altId="debug0.mode.jtag" configurationId="debug0.mode"/> <configSetting altId="debug0.tck.p300" configurationId="debug0.tck"/> <configSetting altId="debug0.tdi.p110" configurationId="debug0.tdi"/> <configSetting altId="debug0.tdo.p109" configurationId="debug0.tdo"/> <configSetting altId="debug0.tms.p108" configurationId="debug0.tms"/> <configSetting altId="p108.debug0.tms" configurationId="p108"/> <configSetting altId="p108.gpio_mode.gpio_mode_peripheral" configurationId="p108.gpio_mode"/> <configSetting altId="p109.debug0.tdo" configurationId="p109"/> <configSetting altId="p109.gpio_mode.gpio_mode_peripheral" configurationId="p109.gpio_mode"/> <configSetting altId="p110.debug0.tdi" configurationId="p110"/> <configSetting altId="p110.gpio_mode.gpio_mode_peripheral" configurationId="p110.gpio_mode"/> <configSetting altId="p300.debug0.tck" configurationId="p300"/> <configSetting altId="p300.gpio_mode.gpio_mode_peripheral" configurationId="p300.gpio_mode"/> </pincfg> </raPinConfiguration> </raConfiguration> Thanks for your help Daniel
I check the my hardware with a binary from renesas github github.com/.../USBX_pcdc_acm_ek_ra6m1_ep.hexnot my Source code and the RTT said everything is ok But Windows hat the same behaviourIt is possible that I have hardware Problem on my eval board? It is nessesary to make a hw config on the board open or close a jumper ?Thanks for your help Daniel
Hello Daniel ,
If you would like to go through a HW review of your custom board you could refer to the ek-ra6m1 design package and check the schematics as reference.
https://www.renesas.com/en/document/sch/ek-ra6m1v1-design-package?r=1168076
Otherwise since you are an identified customer you could submit in our private ticketing system. Where you can share in private your schematics to go through a review and also share your project. The link to submit the ticket is shown below:
https://en-support.renesas.com/createticket
Thanks and Regards,
IK
Unfortunately, I can't get any further on this topic. I have examined the source code again and the binary from the Renesas examples also gives the same effect on the Windows side. So first of all: No USB but good old UART and control my Project from Host. I would write something in this topic again if I have new insights.
Do you have any ideas what I have set wrong as to why the board is not logging on to Windows? Do I need to trace something in the debugger or are there system tools with which I can trace even more in Windows?I check my Source Code use different binarys from https://github.com/renesas/ra-fsp-examples/tree/master/example_projects/ek_ra6m1, always with the same result Failt Enumeration The RA USB Boot of the eval board works Best regards
Daniel
Hello I solved my Problem by my self Old Settings with EK-RA6M1 Eval Board and the PIPE Broken I the Forum of an other µC Competitor I found a entry that the customer change clock input and I try it also New Settings in Smart ConfiguratorWith the ResultThe Problem ist Solved and the topic is closed
