Currently using RH850_1647(RH850/F1KM-S4) Micon with GHS 2015.1.7,Multi 7.1.6
During the execution of software, getting continuously below error,kindly give suggestion to sort out the issue.
CPU1 CPU status (0x10): RESET
Are you using the device file packages from:
https://www.renesas.com/en/document/dfp/rh850f1km-s4-ghs-df-package?r=25431621
There is obiously a reset on the device, you can evaluate the cause of the RESET in the RESF register.
Thanks,cant able to find RESF Register in Multi,Kindly tell me the procedure to find the register.
You can check its address with Memory View:
