CCRX and the use of #pragma, _Pragma or __pragma to set datastructures at specific addresses in flash.
I have a lot of data structures that I need to place on calculated addresses in flash memory.
The same code will be used on many different RX devices, but the calculations can be performed using numbers in the r_flash_rx header file.
My expectation was to calculate the addresses using the preprocessor, but it appear the #pragma address implementation is limited to literal hex string values. :-(
Reading in the forum, I find several mentions of using the C99 pragma extension, or the Microsoft specific pragma extension, and it seems to resolve some problems.
However specifically for the #pragma address appear to fall short. Please see my tests below, which indicates that they all suffer from the same problem:
#define INFO_ADDRESS_X 	0xFFFE0000
#define INFO_ADDRESS_XX  (INFO_ADDRESS_X+2)
/// Please only enable one of the below pragma statements at a time.
/// Orginary pragma implementation, set with defines.
#pragma address VersionInFlash=0xFFFE0000			// ok	- address is a hex string.
#pragma address VersionInFlash=4294836224			// E0523005:Invalid pragma declaration  - so the address can not be decimal.
#pragma address VersionInFlash=(0xFFFE0000+2)		// E0523005:Invalid pragma declaration	- My guess is this is also a decimal address problem?
#pragma address VersionInFlash=INFO_ADDRESS_X		// ok	- address is still a hex string.
#pragma address VersionInFlash=INFO_ADDRESS_XX		// E0523005:Invalid pragma declaration	- My guess is this is also a decimal address problem.
/// C99 pragma extension - The string-literal is the input to _Pragma. Outer quotes and leading/trailing whitespace are removed. \" is replaced with " and \\ is replaced with \.  Must not be inside #if's
_Pragma ("address VersionInFlash=0xFFFE0000")		// ok	- address is a hex string.
_Pragma ("address VersionInFlash=4294836224")		// E0523005:Invalid pragma declaration  - so the address can not be decimal.
_Pragma ("address VersionInFlash=INFO_ADDRESS_X")	// ok	- address is still a hex string.
_Pragma ("address VersionInFlash=INFO_ADDRESS_XX")	// E0523005:Invalid pragma declaration	- My guess is this is also a decimal address problem.
///Microsoft pragma extension
__pragma (address VersionInFlash=0xFFFE0000)		// ok  = Compiles correctly - But E2Studio complains "Type 'address' could not be resolved"
__pragma (address VersionInFlash=4294836224)		// E0523005:Invalid pragma declaration  - so again the address can not be decimal.
__pragma (address VersionInFlash=INFO_ADDRESS_X)	// E0523005:Invalid pragma declaration	- My guess is this is also a decimal address problem.
__pragma (address VersionInFlash=INFO_ADDRESS_XX)	// E0523005:Invalid pragma declaration	- My guess is this is also a decimal address problem.
const uint32_t VersionInFlash = { 42 };
For now this means I need to calculate all the addresses by hand every time we add a new MCU, which isn't optimal.
Alternatively I need to place the calculations in an external script, which is called during the pre_build stage, but that's not optimal either.
Are there other alternatives that I have missed?
I'd like to make a feature request, so that addresses such as this in the future can be calculated using preprocessor macros.
Added a comment to the code example.
[edited by: fsteff at 9:18 (GMT 0) on 24 Jul 2024]
