Hello all,
I'm searching for an S7G2 project from some years ago, Reset_sources.zip that was in the Media Gallery, but I cannot find the Media Gallery for Synergy microcontrollers. Please, where was it moved?
Thank you in advance.
I usually search for the specific part and then go to the section that has the example project downloads. Most of the the original projects are still present. I don't think new processors are being added to the Synergy line - I switched most projects over to RA over the last few years - switching to FSP is fairly quick. Unfortunately the free IAR option is no longer present.
Try this for S7G2...
www.renesas.com/.../s7g2-240-mhz-arm-cortex-m4-cpu
Thanks for the hint, but unfortunately this zip file (Reset_sources.zip) isn't there.
I have searched the archived files and have not been able to locate this file. So it was not kept.
Thank you.
