HELLO all
i need programmer DA9062 no have Evaluation Kit and i need firmware for ARM-Based Flash MCU SAM3U4E to making pcb
please help no found kit or SAM3U4E form list parts
please thanks
Hello, I am also looking for a DA9061_2_3 ICP KIT, or if there's another solution, to be pointed in that direction. All distributors are out of stock
Please check https://app.na4.teamsupport.com/dc/1/attachments/e19b831f-0e72-4571-b13d-bd9d1885dcd8
You can check distributer on lead time basis .
AB
hello maybe no understand me i need programmer DA9062 i see the kit have ic number SAM3U4E i can find it but need flash file for this ic to connect usn as i/o please
Hi ,
You can buy programmer kit. Unfortunately firmware is impossible to share .
Thank you
Every distributor I've contacted about this kit has told me I cannot backorder or give a quote for lead time. It would be great if I could buy this directly from renesas or at least place an order for backorder
hello no find it any dealer can send to me link for any have it and if no find it how can do ?
and i see cable name dialog from where can pay this cable
thanks
Please connect with local sales for further commercial support.
hello what different between DA9062-21 , DA9062-21AM2 and abut DA9062-21 this programmed before or need programmer ? thanks
Kindly find below details
The “xx” represents a placeholder for the specific OTP variant
If its DA9062-21AM2 , means 21 is OTP variant programmed as per that customer requirement.
HI i have device have DA9062-21 and the ic dead i replaced it from same working device working fine and i replace with new one DA9062-21AM2 no working what problem
