Hello, thank you for providing access to the power navigator of the required version.Unfortunately, the following problem was found during use (see screenshots). As you can see, this version of the software refuses to support this controller(RAA229126), although it is in the library. Please tell me a way to solve this problem, thank you!
It should support . .Kindly recheck connection and procedure for same
AB
Thanks for advise, but nothing has changed.
Maybe I have the wrong version of the program or I need to do something?
