Currently I am working on RAJ240090 Development kit. Basically I have got some sample code and datasheet for the same but it is not included with Hardware reference manual which contains all the data register with all the details about individual functionalities.
Please help me with the hardware reference manual or the document which contains data about the registers so that I can write the bare metal code and drivers accordingly.
Thanks,
Kunal
HI,
To get best support on Battery Fuel Gauge IC products , kindly submit a Technical Support ticket by going to our support portal from the following link: https://en-support.renesas.com
You will need to sign in with your company email address, and if you don't have an account you will need to register with one. https://www.renesas.com/register .
AB
