ISL70024SEH thermal management
Hi, I got a question regarding the thermal resistance(K/W) of the GaN Power Transistor ISL70024SEH. It is stated in the datasheet that the typical thermal resistance from junction to case is 18.7 K/W and it is to my understanding that this value is for the bottom side of the package. Is it possible for you to provide the information regarding the thermal resistance from junction to the top of the case? In other words, what would be the thermal resistance from junction to case top if we use the 2resistor model?
  • We apologize but we cannot answer questions on a public forum for our space parts unless the information is already posted on our public website. In this case, the information is not publicly released and must be given to approved customers only.
    For any further support on this you will need to submit a Technical Support ticket by going to our support portal from the following link: https://en-support.renesas.com
    You will need to sign in with your company email address, and if you don't have an account you will need to register with one. https://www.renesas.com/register
    Please make sure you select “Space & Harsh Environment” instead of another product category when you fill out the online form to submit your questions.
    Best regards, Cindy, Renesas Electronics, Online Applications Support Engineer
