What's the maximum output current under Vin=3.0V and Vout=5.0V? Thanks.
Hi Andy,
I'll get back to you on that shortly.
Avinash Kumar
For VIN = 3.0V and VOUT = 5.0V, the ISL91127IRAZ in boost mode is expected to deliver a maximum output current of approximately 1.6 A. (Typical performance curves- page 8 of the data sheet)
However, the actual performance may slight vary depending on factors like component tolerances and thermal management.
