I am designing a board using the Renesas DA9080 multistage buck + LDO IC. The VDDIO pin requires a 3.3V level for I2C communication, and I was wondering if it is possible to power this line with the LDO output pin from the chip itself, or if I need a separate, dedicated 3.3V power supply for this pin.Thanks,Soumav
Hi ,
You cant use LDO output to power the I2C. You need dedicated power supply for same .
AB
