I have a problem about programming QSPI flash with either e2 studio or .bat file command system. I use Stream It kit.
it gives result succesfull download to QSPI flash but application not running.
also I couldn't see any drivers and sample example for SPI multi IO bu controller.
any idea about these?
thanks.
Hi yzcifci,
Have you already solved this problem? Please wait until RZ experts respond to your issue. Thank you.
JBRenesasRulz Forum Moderator
https://renesasrulz.com/https://academy.renesas.com/https://en-us.knowledgebase.renesas.com/
tried settings but nothing changed. images above is stream it kit that ı use, thanks
right, SPANSION chip mounted on board, I can not program the QSPI chip ; so if I edited the correct settings , how will I download to the flash ?. chip on board is R7S7210121VC .
