Dear Team,
We are using goodix gt9271 touch ic in our custom rzg2l board. We are experiencing a problem, ie sometimes goodix fails in i2c communication with error described in the following.
[ 2.006416] Goodix-TS 4-005d: i2c test failed attempt 1: -6
[ 2.041424] Goodix-TS 4-005d: i2c test failed attempt 2: -6
[ 2.073360] Goodix-TS 4-005d: I2C communication failure: -6
The below listed is our code in dtsi,
i2c2_pins: i2c2 { pinmux = <RZG2L_PORT_PINMUX(42, 3, 1)>, /* SDA */ <RZG2L_PORT_PINMUX(42, 4, 1)>; /* SCL */ }; &i2c2 { pinctrl-0 =<&i2c2_pins>; pinctrl-names = "default"; clock-frequency = <400000>; status = "okay"; gt9271: gt9271@5d { compatible = "goodix,gt9271"; reg = <0x5d>; avdd28-supply = <&avdd_2v8>; vddio-supply = <®_3p3v>; interrupt-parent = <&pinctrl>; interrupts = <RZG2L_GPIO(45, 3) IRQ_TYPE_EDGE_FALLING>; reset-gpios = <&pinctrl RZG2L_GPIO(45, 2) GPIO_ACTIVE_HIGH>; touchscreen-inverted-x; touchscreen-inverted-y; status = "okay"; }; };
sometimes goodix touch is working and sometimes it fails in i2c communication. Please help.
Try changing you clock frequency to 100k instead of 400k.
Hi Eldhose,Did you resolve your issue? Is there anything else to assist you? Would you like to verify the suggested answer if it was resolved? Thank you.Kind Regards.
