I would like to access a single SPI flash from the QSPI0 interface of the R9A07G043 processor.
Is this possible?
If yes, could you please help me for the device tree declaration, is there is a special descriptor to add to the dts node?
Thanks in advance
Hi jaiunequestion,Yes, it is possible. You can use RSPI channel for your use case. You can check this ( r01us0481ej0108-rz-g_SPI_UME.pdf ) document for your reference.Kind Regards.
