How to implement I2C read write functions for M33 in RZ/V2L
Below is the sensor driver header function #ifndef _MLX90641_I2C_Driver_H_#define _MLX90641_I2C_Driver_H_
#include <stdint.h>
void MLX90641_I2CInit(void); int MLX90641_I2CGeneralReset(void); int MLX90641_I2CRead(uint8_t slaveAddr,uint16_t startAddress, uint16_t nMemAddressRead, uint16_t *data); int MLX90641_I2CWrite(uint8_t slaveAddr,uint16_t writeAddress, uint16_t data); void MLX90641_I2CFreqSet(int freq);#endif
This what I tried.
void MLX90641_I2CSetup(){ R_RIIC_MASTER_Open(i2c_ctrl, &cfg);}
void MLX90641_I2CInit(){
MLX90641_I2CSetup();}
Not sure if this approach is correct as I have defined comms_i2c_callback_IR_sensor callback function not sure when it will be used
My hal_data.c looks like this:
/* generated HAL source file - do not edit */#include "hal_data.h"/* I2C Communication Device */#define FSP_NOT_DEFINED (1)rm_comms_i2c_instance_ctrl_t g_comms_i2c_device0_ctrl;
/* Lower level driver configuration */const i2c_master_cfg_t g_comms_i2c_device0_lower_level_cfg ={ .slave = 0x33, .addr_mode = I2C_MASTER_ADDR_MODE_7BIT, };
const rm_comms_cfg_t g_comms_i2c_device0_cfg ={ .semaphore_timeout = 0xFFFFFFFF, .p_lower_level_cfg = (void*) &g_comms_i2c_device0_lower_level_cfg, .p_extend = (void*) &g_comms_i2c_bus0_extended_cfg, .p_callback = comms_i2c_callback_IR_sensor,#if defined(NULL) .p_context = NULL,#else .p_context = (void*) &NULL,#endif };
const rm_comms_instance_t g_comms_i2c_device0 ={ .p_ctrl = &g_comms_i2c_device0_ctrl, .p_cfg = &g_comms_i2c_device0_cfg, .p_api = &g_comms_on_comms_i2c, };iic_master_instance_ctrl_t g_i2c_master0_ctrl;const riic_master_extended_cfg_t g_i2c_master0_extend ={ .timeout_mode = IIC_MASTER_TIMEOUT_MODE_SHORT, /* Actual calculated bitrate: 98425. Actual calculated duty cycle: 50%. */.clock_settings.brl_value = 28, .clock_settings.brh_value = 28, .clock_settings.cks_value = 4, .noise_filter_stage = 1, .naki_irq = RIIC0_NAKI_IRQn, .spi_irq = RIIC0_SPI_IRQn, .sti_irq = RIIC0_STI_IRQn, .ali_irq = RIIC0_ALI_IRQn, .tmoi_irq = RIIC0_TMOI_IRQn, };const i2c_master_cfg_t g_i2c_master0_cfg ={ .channel = 0, .rate = I2C_MASTER_RATE_STANDARD, .slave = 0x00, .addr_mode = I2C_MASTER_ADDR_MODE_7BIT,#define FSP_NOT_DEFINED (1)#undef FSP_NOT_DEFINED .p_callback = NULL, .p_context = NULL, .rxi_irq = RIIC0_RI_IRQn, .txi_irq = RIIC0_TI_IRQn, .tei_irq = RIIC0_TEI_IRQn, .ipl = 12, .p_extend = &g_i2c_master0_extend, };/* Instance structure to use this module. */const i2c_master_instance_t g_i2c_master0 ={ .p_ctrl = &g_i2c_master0_ctrl, .p_cfg = &g_i2c_master0_cfg, .p_api = &g_i2c_master_on_iic };
is there any sample implementation?
PS: above hal_data.c is auto generated by e2studio.
> not sure when it will be usedYou should read FSP manual:https://renesas.github.io/rzv-fsp/index.htmlAbout callback, see:https://renesas.github.io/rzv-fsp/group___r_i_i_c___m_a_s_t_e_r.htmlstated as:A user callback function must be provided. This will be called from the interrupt service routine (ISR) upon RIIC transaction completion reporting the transaction status.
Thanks, for pointing to the document.
is this implementation correct?
/** Read the register_address value from the mlx90632 * * i2c read is processor specific and this function expects to have address of mlx90632 known, as it operates purely on * register addresses. * * @note Needs to be implemented externally * @param[in] register_address Address of the register to be read from * @param[out] *value pointer to where read data can be written
* @retval 0 for success * @retval <0 for failure */
int32_t mlx90632_i2c_read(int16_t register_address, uint16_t *value) { uint16_t data_buffer = register_address;
// Prepare the parameters for the write-read operation rm_comms_write_read_params_t write_read_params = { .p_write_data = (uint8_t *)&data_buffer, .write_data_bytes = sizeof(data_buffer), .p_read_data = (uint8_t *)value, .read_data_bytes = sizeof(*value) };
// Perform the combined write-read operation fsp_err_t err = RM_COMMS_I2C_WriteRead(&g_comms_i2c_ctrl, write_read_params);
if (err != FSP_SUCCESS) { return -1; // fail } return 0; // success}
________________________________________________
// 2 times i2c write(one for register addr another for value)
int32_t mlx90632_i2c_write(int16_t register_address, uint16_t value)
{ // Write the register address fsp_err_t err = RM_COMMS_I2C_Write(&g_comms_i2c_ctrl, (uint8_t *)®ister_address, sizeof(register_address));
// Write the 16-bit value err = RM_COMMS_I2C_Write(&g_comms_i2c_ctrl, (uint8_t *)&value, sizeof(value));
Where can I can set the clock parameters for i2c. while doing a i2c_read() getting error in function : "
static fsp_err_t iic_master_run_hw_master (iic_master_instance_ctrl_t * const p_ctrl)
uint32_t iic_clk = p0_clk / (1U << p_ctrl->p_reg->ICMR1_b.CKS);
Looking the fsp documentation it says i2c clk is derived from P0 clk.
