Rzv2l M33 i2c error undefined reference to `xSemaphoreTakeRecursive
I 'm  facing compilation error on M33-FreeRTOS code for communicating a IR sensor on RZ/V2L board.
 After integrating Sensor driver code(mlx90632 driver files)
I am getting a error in a completely different file  rm_comms_i2c_driver_rz.c.
Building target: rzv2l_cm33_rpmsg_demo.elf
c:/program files (x86)/gnu tools arm embedded/9 2019-q4-major/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: ./rzv/fsp/src/rm_comms_i2c/rm_comms_i2c_driver_rz.o: in function `rm_comms_i2c_os_recursive_mutex_acquire':
C:\Users\Abhinav\OneDrive\Documents\Rzv2l\r01an6238ej0111-rzv2l-cm33-multi-os-pkg\rzv2l_cm33_rpmsg_demo\Debug/../rzv/fsp/src/rm_comms_i2c/rm_comms_i2c_driver_rz.c:355: undefined reference to `xSemaphoreTakeRecursive'
c:/program files (x86)/gnu tools arm embedded/9 2019-q4-major/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: ./rzv/fsp/src/rm_comms_i2c/rm_comms_i2c_driver_rz.o: in function `rm_comms_i2c_os_recursive_mutex_release':
C:\Users\Abhinav\OneDrive\Documents\Rzv2l\r01an6238ej0111-rzv2l-cm33-multi-os-pkg\rzv2l_cm33_rpmsg_demo\Debug/../rzv/fsp/src/rm_comms_i2c/rm_comms_i2c_driver_rz.c:376: undefined reference to `xSemaphoreGiveRecursive'
collect2.exe: error: ld returned 1 exit status
make: *** [makefile:111: rzv2l_cm33_rpmsg_demo.elf] Error 1
"make -r -j8 all" terminated with exit code 2. Build might be incomplete.
Below is my configuration.xml
Also dtsi file has 3 i2c interfaces marked as "disabled". Do I need to remove these dtsi entries completely.
