Hi all,for one of our products we planned to use RZ/T2M with its TSN features and its switch. Because of special needs we have to use the cut-through feature of the T2M Switch. Unfortuantely I have seen, that there is an errata with the RX FIFO and the workaround recommands not to use cut-through (at least at RX FIFO).
This recommendation simply means that this feature cut-through that is essential for our application is not usable.
So my questions:
- Is there an other workaround to use cut-through anyway?
- Is there anything a user can do to not have this problem while using cut-through?
- Is there a plan to fix this problem with a newer revision of the chip?
Thank you very much in advance for answering.
Best Regards
Daniele
Hi Daniele,Our team is investigating your issue and will reach to you soon.Kind Regarads.
