hello
What I am using is R7S910035,I can download the program to the chip(It's just a way of not saving the power-off program).
But I cannot burn programs onto chips(It's just a way of saving the power-off program).
report errors:GDB action 'Finished download', has failed with error report, failed to down
Thank you
Connecting to R7S910015, ARM Target
GDBServer endian : little
Target power from emulator : Off
Starting target connection
Finished target connection
GDB: 59030
Target connection status - OK
Starting download
Finished download
GDB action 'Finished download', has failed with error report, failed to download
Hardware breakpoint set at address 0xce14
Disconnected from the Target Debugger.
I use e2studio
Hi chen,Our team is investigating your issue and will reach to you soon.Kind Regards
Hi chen,You have configured a different part number for the GDB debugger.Please go to Debug configurations > Renesas GDB Hardware Debugging > (Select your project - HardwareDebug) > Debugger > Change your Target Device to R7S910035.Kind Regards.
