Hi Nitish,For the DDR memory you should follow the PCB design guideline DDR4. You will find also a tool which helps you generate your DDR parameters to a file.For the RAA241200, I suppose you will use the I2C interface to interact with the RZG3S and/or UART.Please post your query on Power products forum for driver support.Kind Regards.
Hello Sir, Thanks for the reply, we have the PCB design for the DDR but we need to know if there is an extra driver requirement as we are changing from LPDDR
Hi Nitish,Please contact with your local FAE for more info about the DDR memory.Kind Regards.
