I have a RZN1D Eval Board, and I am trying to get Zephyr to run on it. I notice that currently the only RZN board currently supported officially in the main Zephyr project is RZN2L.
Question1: is there a RZN1D Eval Board board definition for Zephyr available with you that I can use?
Question2: If I have to make my own Board Definition, what would be a good starting point? i.e. which existing board definition would be easy to copy and modify? RZN2L uses a different core, so it may not be a good starting point, I feel.
Thanks in advance your your help
Best Regards
PNC
Hi pnc,No there is not any board definition for RZN1D for Zephyr.You should start by reading the Board Porting Guide — Zephyr Project Documentation and you can have as a staring point a CM3 board.Please note that it's not an easy task and requires advanced know knowledge and skills.Kind Regards.
