GUIX rotation
I'm trying to rotate the whole screen in GUIX. I updated GUIX library to 6.1.3 and enabled Rotation in GUIX studio. Then i modified the rz_graphics_driver_setup_565rgb() to call _gx_display_driver_565rgb_rotated_setup instead of _gx_display_driver_565rgb_setup.
The screen is displayed rotated, however, only the top half of the screen is being displayed.
Parents
  • Please check the following changes.
    All changes are in rz_display_driver_565rgb.c.
    Change 1:
    #define DISPLAY_XRES 800
    #define DISPLAY_YRES 480
    #define DISPLAY_XRES 480
    #define DISPLAY_YRES 800
    Change 2:
    Change the following part of ConfigureGUIXDisplayHardware565rgb().
    fb_stride       = (uint32_t)(DISPLAY_XRES * 2);     /* bytes per pixel */
    fb_stride       = (uint32_t)(DISPLAY_YRES * 2);     /* bytes per pixel */
    Change 3:
    Change the following part of rz_graphics_driver_setup_565rgb().
    _gx_display_driver_565rgb_setup(display, GX_NULL,
    _gx_display_driver_565rgb_rotated_setup(display, GX_NULL,
    I'm checking with Azure_RTOS_6.1_Renesas_RZA1_RSK_IAR_Samples_2021_04_28.zip on Microsoft's GitHub.
  • Hi,
    Thank you for your reply! I have it working now. The issue was with settings in the GUIX Studio Project.
Reply Children
No Data
