Software delay with Azure Rtos
I'm currently porting an application from Synergy S7 to RZA1H.
In the process used to run our application, we have a call to the R_BSP_Software_Delay function. While looking for a function that could behave the same way, i found in the blinky example a function named osDelay, but i couldn't find its definition and it isn't know when i call it from my azure project.
Would anyone know of an equivalent funtion or do I have to port the R_BSP_Software_Delay function and its assembly code to the RZA1?
[locked by: Sai (SWF) at 11:43 (GMT 0) on 13 Jun 2022]
