ZMOD4410 programming
Hello, I want to use ZMOD4410 for my project, but I am confused with the programming method of the sensor. The datasheet did not mention any specific register for gas measurements. Is it possible to program  ZMOD4410 without using RENESAS API or Library? I am using NXP kinetics MCU with NXP MCUxpresso IDE.
If I can work without using RENESAS API or Library, How can I do it? please provide me specific register for each measurement.
Or if I need to use RENESAS API or Library how I will get it. I am requesting sufficient resources to use the ZMOD4410 gas sensor.
THANK YOU.
With Regards
Raduan
