Hello
Hi Diogo,
Thanks for the request and reaching to the online support team. Yes, it is possible to use one wire interface through level shifter. I think there is something wrong with the level shifter. Your level shifter is unable to drive the load (slave device)/not able to communicate. So, could you please use another lever shifter and update us?
For one wire interface I have also attached one documents please go through that.
ZMID4200 Technical Brief OWI Interface (renesas.com)
Regards:
Raja.
Thank you for the answer, I've solved my signal problem. I was missing the Command Mode message during tAUTHORIZATION
Thanks for the update. Good to hear that you have resolved your query. Have a good Day!
